Ziplock Box Speaker.
Published
Introduction: Ziplock Box Speaker.
ok here is how to make a really easy speaker that I got out of a old stereo.
Step 1: Getting Started
first you will need a.
speaker,
ziplock box any size will do,
soldering iron,
solder,
wires,
input plug for your ipod/computer,
hot glue gun,
axzato knife and
paint if you so choose.
if you don't know what a input plug looks like look at the pictures bellow.
Step 2:
1. First put your speaker on the ziplock box and with a pen or pencil trace the shape of the speaker on the box when your done draw in the inside the same thing, the reason your doing this is so the the speaker doesn't go through the hole you will make later on.
2. Now cut the line on the in side of what you traced earlier.
3. Now it is time to do some soldering, okay take two wires and solder one too the positive end of the speaker and one too negative end of the speaker, now take the positive and solder it to the positive end of the input plug and do the same thing with the negative end.
4. You are all most done, now it is time for some installment put the wires in the hole you made earlier then take the hot glue gun and put hot glue around the edges of the hole then put the speaker over the hole to glue it down.
5. Now make another hole right by your speaker and glue in your input plug now.
Step 3:
now that your done it should look like the picture down bellow.
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    8 Comments
    i did it just as you said, but it still won't work. my brother said that it needs a power source, like a battery or a power outlet plug. what should i do to make it work?
    How many of you have built my speaker?
    You might want to change the title of your Instructable, as this is made from a ziplog bag box, not the bag itself as the name suggests.
    Thanks man I glad you like it!!!!
    It is not water proof so don't put it in water. and yes I did use a webcam to take those pictures so im sorry about the poor quality.
    3 questions: you didn't make a speaker but an enclosure, right? Why did you use amirror to take the pictures? And: Does ANYONE on here use spellcheck?
    sorry I had to use the computer to take the pictures. ya I took that speaker out of a stereo and did some soldering so my ipod would work.
