Zombie Pack
1,433
52
15
Posted
Introduction: Zombie Pack
have you ever needed to mack a pack for surviving the zombie apocalypse?
of course you have!
please vote in apocalypse preparedness contest!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Step 1: Supplies
1 foot of PVC pipe
1 PVC pipe cap
1 PVC pipe screw in lid
1 can of primer
1 piece of sandpaper
optional:
3 feet of rope
Step 2: Prep
sandpaper the end of the PVC pipe on both sides
Step 3: Adhesive
put some primer in the cap and hole thing for the screw and let it dry then add the thin layer of cement in the cap and hole
Step 4: Combine
put the hole and cap on and let dry you should be able to put the screw in the hole and unscrew it also should be water proof
Step 5: Finish
if you want you can tie the rope around the pipe
fill it with essential needs like batteries water knife bandages cloth Twinkie pocket-radios lighter
please comment!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
please follow!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
please vote!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
15 Comments
You should add Teflon tape (available at Loews, Home Depot or any hardware store) to keep the threads water tight. Great for burying in the back 40.
If you keep m small enough, you can store m in your (wooden) doors inside your house! Find a drill the same diameter as your widest part of the container and drill a hole in the top of your door, deep enough so that the container will fit inside. Put the container in and close the door; voila!
that is good thank you will try
anyone know how to submit it to the contest apocalypse preparedness?
i
the contest button is next to the post button. contest must be entered there. it claims the ible must be made after the contest is created.
DERP. Sorry for that second messege
