3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
zombie surivial kit
zombie surivial kit
This is a simple kit for the Armageddon to come. I personally made this kit based on the zombie survival guide's requirements.
oh yeah read this!
92% of teens have moved on to rap.
If you are part of the 8% who still listen to "real music",
copy and paste this some where...
Step 1FOOD
FOOD
This is a must for anytime if your traveling or have a temporary barricade.
the best foods to pack are non-perishables and make sure that the zombies didnt touch your food
that means the food is contaminated and should not be eaten.
196 comments
1-40 of 196next »
Mar 7, 2012. 4:55 PMcarneasada21 says:
i would not use a k-bar my wepon is base ball bat with nails or ninga stars installed
Aug 10, 2010. 9:19 PMPittcrew says:
I think you're all forgetting that zombies don't exist :) but if they did a large bludgeoning weapon or a crowbar for sure. Why? well in most movies/ games i've played were there are zombie, the best way to "kill" them is to completely knock them to pieces in which case a bludgeon weapon is your best bet.
Feb 22, 2012. 2:34 PMguerrilafighter says:
games are fake and so are movies. the only time youd want a bludgeon weapon is if you cant use a sword or machete without cutting your own arm off.
Jan 9, 2012. 5:30 PMoud25 says:
i mean they are illegal but if zombies come then laws dont matter anymore just have a bayonet on your gun cause then you have a few extra feet between you and it and more leverage istead of a couple inches from you and undeadness
Dec 23, 2011. 3:31 AM16kuokhc1 says:
Can you use a kitchen knife? If no, then I'm screwed
Dec 23, 2011. 3:29 AM16kuokhc1 says:
PLEASE DON'T USE SHOTGUN! (because one zombie killed will attract a 1 mile radius of zombies to kill, I don't want anyone getting killed because of this.)
Dec 14, 2011. 8:03 PMvopo says:
Ok, about your comment that machine guns are bad for lack of head shots, that is stupid. If you are a good shot, you will hit the head. An LMG accurately fired in bursts is more dangerous that any other weapon (against groups). Since zombies never hunt alone, a bolt action is relatively useless, a shotgun good, but still you're gonna be let down when 50 odd zombies run at you. A modified .22 automatic with 100 round drum loaded with.22 long rifle (NOT short rounds) has virtually no kickback, is light, ammo easy to find and can fire for long time without needing reload. Also, .22's need little repair and cleaning, and are easy to find.
Sep 2, 2009. 2:29 PMtabler1010 says:
One I don’t have a blimp. Two, I no clue how to operate a blimp. Three, How is petroleum jelly loud? Four the Hindenburg was not filled with helium. Five, I can park a car in place I can’t get a blimp. Six you can fire a gun from a car and I can guess it would be mildly difficult to do a drive by on a blimp. Seven, how are cars a nuisance to man kind?
Oct 25, 2011. 5:51 PMTimmyMiller says:
like the others said you can make an makeshift exsplosive liquid, spray it all over the zombies, make an air proof igniter and BURN BABY BURN!!!!!!!!
Oct 25, 2011. 6:43 PMTimmyMiller says:
air proof so it doesn't go out when it falls through the air
Oct 25, 2011. 5:53 PMTimmyMiller says:
i might make an instructable on how to make a specialized ignighter that can be dropped and hit desinated target area
Oct 12, 2009. 1:49 PMchurchisashizno44 says:
 Cars can be loud and possibly attract attention not to mention in a zday scenario it might be difficult to find gas for car and even then when you do get there to fill it you leave yourself exposed, and even then theres another problem for most pumps it take electricity to operate the pump, can not count on electricity  being there, Blimp is a good idea if you can find one if not get to a boat, Blimps are still around although can be rare, a dridgeable, a smaller blimp might be able to make one yourself, if taken that route i would suggest makeing a few smaller prototypes, mock scale sort of thing, and as for a weapon being used from a vehicle a blimb is slow enough moving and out of reach where you can adjust your altitude and take careful aim and pick off Zombies at your leisure, as well as you could make your own molotov cocktail concoction
Aug 26, 2010. 4:17 PMTragicSnowfall says:
Is this some kind of bad joke? With all the deserted cars laying around you can't find one with a tank of gas?
Sep 15, 2010. 9:44 PMCapt. Kidd says:
what, and hotwire it if you knew how, leaving yourself out in the open for 5 minutes? then making a massive sound that echoes once you start it? huh?
Oct 12, 2009. 5:35 PMtabler1010 says:
I realize the gas issue on account of I have seen all the mad max movies, however, the whole blimp idea is total bullshit because where I live I have never seen a blimp just lying around, I still don’t know how to fly a blimp, and did you stop to think what fuel blimps use? Also I don’t know if you understand this but you’re never going single handedly build a blimp that will actually take you exactly where you want to go.
Oct 12, 2009. 9:47 PMchurchisashizno44 says:
Blimps can use a number of diffrent fuel types, between gas for the old style blimps and as well as solar for the newer forms, as for not seeing any blimps in your area, im truly sorry for that, i havent either, does not make it invalid for people that have access to it, and as for building your own, you can build a class of duridgable, IE a hot air balloon, and i have seen plenty of those around here.  Like i said in my past one, if you cannot get to a Blimp a boat is also a very good option, not trying to start an argument but merley discussing options and ideas in an open forum for the hope of survivalist to take some ideas away from this. as for the Blimp or your own homemade hot air balloon, who says you want to go anywhere but up, a high high is a safe way to be off the ground and away from teh chompin zombies. Not to mention a very nice sentry post. There was a man who made a lawn chair Balloon in his own backyard. Mythbusters did an episode on it.
Oct 25, 2011. 6:33 PMTimmyMiller says:
http://www.ahausa.com/
is a good source for blimps/ airships
Mar 31, 2009. 6:13 PMmsifan says:
I was wondering if anyone has made a airship with solar panels on the top half of one of those to power electric motors?
Oct 25, 2011. 5:48 PMTimmyMiller says:
EXACTLY!!!!!
Oct 25, 2011. 5:42 PMTimmyMiller says:
when i say electric i mean for the propellers. though where to find extra/replacement helium
Oct 25, 2011. 5:40 PMTimmyMiller says:
A.) good movie pic. choice
B.) where am I sopposed to find one
C.) where to find an electric one
p.s. stock up on cheap solar panels and a long wire(maybe some alligator clips)
and BOOM power source
Sep 22, 2010. 1:22 PMzombiesurvival says:
a shotgun is an awfull weapon against zombies for its lack of aim and that it shoots shots, you also have to reload it more often. iow if you run out of ammo on your turn to be rambo, your screwed.
Sep 25, 2010. 4:11 PMpokerstud001 says:
Obviously never handled a shotgun, have you? It's nothing like it is in call of duty. In fact, they are pretty accurate. Not like a rifle, of course, but it won't spray apart a bunch if you're just 10 feet away.
Oct 29, 2010. 9:38 AMjellybean10122 says:
Correct, A tight choke barrel firing #00 buckshot would be very lethal, provided you aim around the head area. The use of a solid slug in a rifled shotgun barrel would provide excellent accuracy aswell.
Oct 3, 2010. 6:15 AMzombiesurvival says:
ive handeld multiple shotguns, and if i was killing zombies, i would use a high
powerd rifle, or a 22 because a 22 will go into the skull and bounce around shreding the brain, and it can shoot a mile
Oct 31, 2010. 4:47 PMpokerstud001 says:
Yeah, deer slugs are beastly
Oct 17, 2010. 11:00 AMzombiesurvival says:
if u are good at this type of thing, a hunting bow would be a good choise cause its next to silent
Oct 17, 2010. 10:58 AMzombiesurvival says:
good point, but, a shotgun would only wound them,u would have 2 shoot them wultiple times before they died (again) lol, plus the shot gun is loud and zombies are atracted to sound, other guns are loud 2, but not like a shotgun.
Sep 18, 2011. 9:34 PMjnichols4 says:
ive got to call B.S. go to any walmart and you can buy as many rounds as you want all day long i know b/c that is my primary/hunting rifle(sighted in at 1in drop at 300yd )and around october-november most of the time you dont even have to ask a sales manager, they put them out on a shelf.
Oct 21, 2010. 9:24 AMzombiesurvival says:
yeah, true, a machine gun is on of the worst choices becaus of the fact that they are illigal in the public so ther is no way u could find ammo, a shot gun would be awsome, WOULD, the only thing is, if you run out of ammo on your turn to be "legend" (i am legend) yuor screwed, mabie as a sideweapon though
Apr 7, 2011. 5:30 PMzombiesurvival says:
a 300wsm will kill anything in america, i bet they culd kill a zombie too, but they r rlly frikin loud
Jun 17, 2011. 12:14 PMFred the evil puppet says:
Dude, if you can get your hands on a metalstorm, you'd be taking out continents filled with zombies, man! (but, at 1,000,000 rounds per second, god help the ammo store)
Oct 29, 2010. 9:44 AMjellybean10122 says:
The SAW isn't a weapon, it is a class of weapon. The weapon I think you are referring to is the m249, which is chambered in 5.56/.223, and is the American armies' current Squad Automatic Weapon.There are plenty of SAW's which are chambered in larger rounds, with one of the first SAW's, the m1919 browning being chambered in .30 browning.
Oct 25, 2010. 6:16 AMzombiesurvival says:
my primary wold be either a 44 cal or a nerf gun (lol), my secondary would be a 12 gauge shotgun, or a nine mil, both easy to find ammo for and pretty powrful...
1-40 of 196next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:repear9
