Introduction: Π (PI) Day Whole Wheat Bread (No Knead)
This recipe will produce circular delicious, spongy PI day bread.
You will need:
- 2 cups whole wheat flour
- 1 cup white flour
- 2 teaspoons salt
- 2 cups water
- 2 teaspoons active dry yeast
- 3 teaspoons sugar
- olive oil
Tools needed:
- liquid measure
- 1 cup measure
- a teaspoon
- a tablespoon
- 1 smaller bowl for yeast blooming ( a cereal bowl is fine)
- 1 larger bowl for the bread mixing itself.
- 2-3 glass or ceramic bowls or pie tins to cook the bread in.
No kneading is required.
Step 1: Start With 2 Cups of Warm Water and a Big Empty Bowl
The warm water will be to bloom the yeast.
If you're like me you've always wondered what a good temperature is for warm water. If your finger can't stay in it, it's far too hot.
If you're looking for more specifics: boil water in a kettle, add about 1.5 cups of lukewarm tap water, and about 0.5 cups of the boiled water.
Step 2: Add 3.14 TSP Sugar
Add 3.14 rounded teaspoons of white sugar to the warm water.
Or just 3, it's all good.
Stir the sugar into the water.
Step 3: Add 2 TSP Active Dry Yeast
Add 2 teaspoons of active dry yeast to the water and sugar mixture.
Do not mix this up, just let the yeast float on top of the water.
Put this aside for about 15 minutes while you move onto the next step of the dry ingredients. Set a timer.
Step 4: 2 Cups of Whole Wheat Flour
In a new, bigger bowl, add 2 level cups of whole wheat flour.
This means as you scoop it, either level it off with a straight edge (spoon handle, knife, etc...), or just scoop into the flour bucket and pull up along a flat side.
Step 5: Add 1 Cup White Flour
Add 1 cup of white flour, levelled, along with the other flour.
Step 6: Add 2 TSP Salt
Add 2 teaspoons of Kosher salt to the other dry ingredients.
Step 7: Mix Up the Dry Ingredients
At this point in your big bowl you should have 2 cups of whole wheat flour, 1 cup of white flour, and 2 teaspoons of salt.
Stir it all up.
Step 8: "Ding", 15 Minute Timer Went Off for the Yeast
You'll have a few minutes to wash hands or read a book while you're waiting for your yeast to bloom.
After your 15 minute timer your yeast in the water+sugar mixture should look similar to the picture.
If you're using older yeast, or colder water, give it some more time.
If you're in a cooler climate like me, warm your oven for a minute or two, you'll need a place for the dough to rise later.
Step 9: Mix Wet Ingredients Into Dry Ingredients
Pour the wet ingredients bowl ( yeast, water, sugar) into the dry ingredients bowl (2 cups whole wheat flour, 1 cup white flour, 2 teaspoons salt ).
Mix it all up, the dough will be sticky like the video shows. This is fine.
Step 10: First Rise, in a Warm Place (1 Hour)
If you're in a warmer climate you can probably just rise on your counter, or in a sunny window.
I wouldn't know, it's cold up here.
Up here, in winter, you warm your oven for a couple of minutes then shut it off.
Put the mixture in the oven with the door slightly ajar.
Rise for about 1 hour.
If it looks like the second picture, you can move on.
If it's not done rising yet, just cover it up, give it another hour, and try again.
If you've done that, and it still hasn't risen, you can choose to have either a denser bread or check the expiry date on your yeast.
Step 11: Oil Destination Pie Plates or Dishes
With olive oil or butter, oil the destination pie plates or dishes.
My significant other seems to have broken all of our pie dishes, so we'll use oven friendly circular ceramic dishes for our PI day bread.
I have a food brush always available in a small cup of olive oil, you can do something similar to brush the pans.
Alternatively, just use a stick of butter and rub it on the inside of the dishes.
This step is important. Our dough is sticky, and without oil or butter you will have a difficult time getting the dough out when it's done.
In my scenario I'm using 3.14 ceramic dishes (well... 3 dishes, but 1 is a bit bigger than the other).
Step 12: Split Up the Dough
The dough will be very sticky as the video shows, but just use a spoon or two to split it up into the cooking containers.
Step 13: Preheat Oven 425 F, Cover Dough ( About 31.4 Min), Then Put in Oven.
Preheat your oven to 425 F.
Cover your dough for the second rise, 20-31.4 minutes, easiest place is on top of the stove while the oven is warming up.
Once the oven has warmed up, put the dough in the oven.
Step 14: Cook It, 425 F @15 Minutes, 375 F @ 16.4 Minutes
Put it in the oven that has been been warmed up to 425 F.
Cook it for 15 minutes.
When the timer goes off, lower the temperature to 375 F and cook it for another 16.4 min.
(15+16.4 = 31.4 minutes total cooking time )
Step 15: Take Bread Out of the Oven
Take the bread out of the oven.
At this point the top should have a nice golden brown.
Step 16: (optional) Oil the Top(now)/bottom(later) of the Circular PI Bread
You have a couple of choices. Since this bread is going to be flipped upside down, the top (what you see now in the dish) will become the bottom.
If you'd like a crispy bottom, skip this step.
If you'd like a soft bottom, then lightly oil (or butter) the bread.
Step 17: Cool and Loosen the Bread
Take a knife and go around the edges of the container for each bread, and just loosen it.
Once that's done, turn it upside down onto a breadboard or clean surface.
After a few minutes you should be able to just flip the bread out.
Step 18: Eat It Up
You're done.
Lots of small steps, but pretty simple. No kneading, fairly flexible ingredients, and most important it produces circular bread.
If your significant other has not broken the pie pans I advise you to try this recipe in pie pans, otherwise use "Pi" pans with any oven friendly circular cooking vessel.
Happy eating.
Pi Day Challenge 2016
