Getting Started With the ShopBot
Introduction: Getting Started With the ShopBot
Allowed Materials for the ShopBot CNC Router
Allowed Materials
  • Wood
  • Some plastics
  • Some foams
Banned Materials
  • Metal
  • Carbon ber and composites
If at Pier 9, see Shop Staff first before using these materials:
  • All other materials
If you are working from another studio or workshop, refer to the tool's instruction manual to see if your desired material is suitable for tool use.
Safety
Our most important safety callouts are highlighted in yellow throughout this course.
Machine Specifications
The ShopBot CNC router is a large 3 axis router with the following specifications:
  • 3 horsepower spindle
  • 18,000 RPM maximum spindle speed
  • Work envelope of 8' x 4' x 12" (X, Y & Z)
Required Knowldege
Before you start your work, make sure you understand
the following skills:
  • Types of cutting tools
    • Which cutting tools you can use, and how they work
  • Tool holding
    • The correct way to attach a cutting tool to the ShopBot
  • Workholding
    • How to hold your workpiece to the ShopBot bed
  • ShopBot software interface
    • Operating the computer that controls the ShopBot
Required Materials
Before you start your work, make sure you have the following materials:
  • An .sbp file from your completed CAM file.
  • A thumb drive to copy the .sbp file to the router.
  • Setup Sheets from your CAM software.
  • A copy of this Quick Start Guide.
Steps for Successful Use
To make a part, you need to complete each step in order.
  1. Start up the controller & router.
  2. Secure the workpiece to the table
  3. Install the rst tool.
  4. Set Z zero.
  5. Set the XY Home.
  6. Load the program.
  7. Make an air pass.
  8. Reset Z sero
  9. Run the program.
  10. Clean up.
Measuring Material
After preparing your material for the router, measure it carefully and change the setup in your CAM program if needed.
CLASS PROJECT
Share a photo of your finished project with the class!
Nice work! You've completed the class project
