loading
Making Leather Braids
Once you've learned how to make fringe, it's easy to move on to learning another great leather detailing technique: braiding. Standard leather braids also have a very specific aesthetic but the basic techniques you use to make braids are the foundation for some much more complex and interesting woven and braided leather designs.
I'll show you a few of my favorite braid patterns here and then you'll have the option to add one to your bag.
In this lesson I'll be using:
  • the bag design you've been working on
  • scrap leather for creating braids
  • x-acto knife
  • leather lace
  • clear and metal ruler
  • awl
  • cutting mat
  • strong sharp scissors
  • rope cord core for a round braid
  • thick waxed thread
  • stitching chisels
  • rotary punch
  • quartz slab and poundo board
  • double sided tape
  • leather needles
  • binder clips, pins or thumbtacks and a surface to pin into to hold your leather while braiding
  • Standard 3 Strand Braid
    To make leather braids, one of the easiest ways is to start by using one of the fringe cutting techniques we just learned, and then braiding the cut strips together. This is a nice way to create a braid, because it means that, on one end of the braid, the individual strips are already attached and won't need to be held in place by another finishing method.
    To create the basic 3 strand braid this way, first decide how long and wide you need your braid to be. Braiding will take up some of the length of your leather, so you need to account for that. Braiding usually causes a length shrinkage of around 1/4 depending on the thickness of the leather and the width of your strips. So if you want a 9" long braid, you need to start by cutting strips about 12" long.
    Braiding also causes a width shrinkage which varies with the thickness of the leather, but a braid like the one I'm making shrinks about 1/4" in width.
    To make the basic braid, cut a three stranded fringe, then find a way to hold the top end in place so you can braid more easily. I like to use a binder clip and then loop the handles around something.
    Now make your braid the way you would a normal braid, by alternating sides taking a strip from the outside and crossing it over into the middle. Don't let your strips flip upside down, make sure the grain side is always facing up.
    3 Strand Trick Braid
    The 3 strand trick braid looks like a regular braid, but it is closed at both ends which makes it look impossible in an intriguing way, and also means you don't have to find a way to finish either end. It's a fun braid to have in your repertoire, especially for creating small accessories like bracelets.
    To make this braid, start by cutting three strands out of a strip of leather like you did for the 3 strand braid, but leave them connected at both ends. If you are using thick or stiff leather, it is a good idea to punch a hole at the beginning of each cut to make them cross over each other more smoothly.
    Take your strands and braid as follows: first pull the center of the right hand strip over the center strip and under the left hand strip all the way to the left side. You've basically created the beginning of a braid, but since the bottom of the strands are connected, they are crossed too, and you need to untangle them.
    To do this, grab the bottom right hand corner of the leather, fold it up and thread it between the two strands that are currently farthest to the right.
    Pull it all the way through and twist it so the grain side is facing up again. You will have created something that looks a bit messy, with a lot of twists in the strands. Don't panic.
    Now fold the bottom right corner of the leather up again and pass it through the space between the far left and center strands as shown below.
    Again, you will end up with something very messy looking, but there is order under the chaos, I promise.
    Working from the top down, untwist each strand with your fingers so the braid lays flat.
    See! It's starting to look like a braid! Now start the process all over again to continue the braid. The last bit of the braid can be a bit tricky because there isn't a lot of room to weave the strands.
    4 Strand Braid
    There are all kinds of variations on the standard 3 strand braid. As you add more and more strands, the structure of the braids begins to look a bit more like weaving, and you can create some wide strips with interesting patterns. I'm not going to dive too deep into the world of multi strand braids here, but if you are interested in learning more, the book Leather Braiding is an excellent resource for all kinds of weaving and braid variations.
    I do want to show you a 4 strand braid though, because there is something very useful about braids with an even number of strands as opposed to an odd number. You can use them as straps that go through buckles because they have gaps in the exact middle of the braid which can serve as holes for the buckle tongue!
    The 4 strand braid is almost as simple as the 3 strand. For this braid, just start out with 4 cut strips instead of 3.
    To make the braid, start by crossing the two center strips, right over left. Then bring the far left strip over the center right strip.
    Next cross the far right strip under the center left strip and over the far left strip. Continue in the same rhythm to create the rest of the braid. You will always be bringing the strand on the left side into the center by going over, and then the strand on the right side into the center by going under then over.
    As with the 3 strand braid, keep the grain side up and the tension on your strands equal as you braid so the weave looks even.
    4 Strand Round Braid
    To give you one more example of the variety of braids you can create, here's another one of my favorite patterns: the 4 strand round braid.
    The finished braid has a really nice effect that is distinctly different from a traditional braid. It is especially good to use in places where you will be able to see both sides of the braid, because the round braid looks good from any angle. The four strand braid will reduce the original length of your laces by about 1/3, so you need to take that into account when planning your braid.
    Also, In order for the braid to hide the rope properly, the combined width of the laces needs to be about the same as the circumference of the rope. For example, if your rope is 2" around, you need to use 1/2" wide strips of lacing.
    As you can see below, you start the four strand braid by attaching 4 lengths of lacing around a central rope core with their grain sides facing out. A good way to do this is by wrapping thread around the tops of the laces.
    Again, secure your rope to something to leave your hands free to braid. Orient the rope so there are two strands in front and two strands in back. To make the braid, start by crossing the front left strand over the front right.
    Next, take the far left strand and bring it around the back of the rope, under the far right strand and over the next strand to the left, so it is resting in the very middle of the front. Tug and tighten the strands around the rope so they begin to form the braid.
    Now do the same from the right: take the far right strand (the highest strand), and bring it around the back of the rope, under the far left strand and over the next strand to the right, so it is resting in the very middle of the front. Tug the strands to tighten the braid.
    As you can see, you are basically always taking the highest strand from alternating sides, and wrapping it around the back of the rope to the other side and under the next highest strand. Keep working in this pattern to make the rest of the braid. Always keep the grain sides of the lacing facing out and don't let them twist.
    This braid is really quite easy once you get the pattern, but here's a diagram in case you're still feeling confused:
    Finishing Braids
    If you want to incorporate a free hanging braid into your project you need to find a way to finish the end of the braid so it won't unravel. There are a few different ways to do this. They are all a little tricky, so if you can find a way to incorporate braiding into a project where both ends are hidden inside seams (like we are going to do with the bag) it will make things simpler.
    If you do want to try a hanging braid, you can either keep the strands of the braid free at the end or cap the braid so you don't see the loose ends. If you are ok with seeing the ends of the lacing, you can wrap thread or another piece of lacing around the end of the braid almost the way you would with a hair tie at the end of a hair braid.
    If you use lacing or a strip of leather here, you need to sew together or glue down the ends of the lacing.
    It can look a bit more professional, however, to cap the ends of the braid with a larger piece of leather. You can do this with a two piece cap if you want to create a shaped end, or one piece folded over to create a flat end.
    First apply glue to the individual strands of the braid, or punch holes in them and sew them together.
    Then trim the ends to a neat shape.
    Cut one or two pieces of leather to form the cap you want to create. If you are using one piece, glue the cap down over the end of the braid, sandwiching the laces, then use one of the punching methods we've learned to punch sewing holes through all three layers. If you are making a two piece cap, sew the front edge of the cap first, glue it over the braid and punch the rest of the holes.
    Sew the cap onto the braid with a saddle stitch.
    Braiding Quiz
        "id": "quiz-1",
        "question": "True or False: You can only make braids with three strands.",
        "answers": [
                "title": "false",
                "correct": true
                "title": "true",
                "correct": false
        "correctNotice": "You're right!  There are many kinds of braids that use different numbers of strands.",
        "incorrectNotice": "Sorry, take another guess."
        "id": "quiz-2",
        "question": "If you were making a 4 strand round braid around a rope core with a 1 inch circumference, how wide should each of your 4 leather strips be?",
        "answers": [
                "title": "1 inch",
                "correct": false
                "title": "1/4 inch",
                "correct": true
                "title": "1/2 inch",
                "correct": false
        "correctNotice": "Yes! The width of the 4 strips combined should add up to the circumference of the core.",
        "incorrectNotice": "Nope. Try again."
        "id": "quiz-3",
        "question": "True or False: It's impossible to make a braid with two closed ends.",
        "answers": [
                "title": "false",
                "correct": true
                "title": "true",
                "correct": false
        "correctNotice": "You're right! There are several kinds of trick braids that can be made with leather strips that remain attached on both sides. We learned the 3 strand version here.",
        "incorrectNotice": "Oops, are you sure that's what you meant?"
    Make a Braided Cross Strap for Your Bag
    I incorporated a braid into my bag design by adding a four strand braided strap across the front that holds the flap of the bag in place.
    To make a braided strap I cut a 1 1/4" wide strip of the same thicker black leather I'm using for the straps. The final braid needs to be 10 1/2" long with 1/4" seam allowance on each side to go around the front of the bag from back side seam to back side seam.
    So allowing for how much the leather will shrink, the unbraided leather strip should be about 14" long.
    Cut the braid into 4 equal strips, leaving 1/2" attached on one end. Then braid a four strand braid following the method I've shown you. When you get to 10 1/2", arrange the strands of the braid so they are sitting very close to each other, then stick a piece of tape across the flesh side to hold them together.
    Use your stitch punch to punch a row of sewing holes through the strands of the braid. Try to situate the punch so all the tongs are making solid holes in the leather, not punching through the edges. Trim off the ends of the strands leaving about 1/4" seam allowance.
    Punch another set of sewing holes in the un-cut leather at the other end of the braid.
    Sewing in the Braided Strap and Fringed Trim
    Now you can sew both the fringed trim you prepped in the last lesson, and the braided fringe we just made, into the back seam of your bag.
    Take the front of your bag with the turned edge seam, and line it up over the back piece with the fringe taped on. Make sure the grain side of your fringe is facing up and the flesh side of the back piece is on the inside of the bag. I started sewing in the bottom center to make sure everything was lining up right. Sew through all three layers, sandwiching the fringe between the gusset and the back.
    When you get to the place where you want to attach your braided strap, (I attached mine 4" up from the bottom, but you could place it higher) sandwich the end of the braid into the seam so that it will loop over the front of the bag with the grain side facing out.
    If your are sewing with one needle like I am, start back down the seam when you reach the top, filling in the other stitches. Repeat on the other side.
    What We Learned
    In this lesson we've learned 4 different braid variations that I hope give you a good idea of the possibilities of leather braiding and weaving. One of my favorite things about these kinds of techniques is that they create subtle variations in texture that add a lot of visual interest to a design. I've seen some amazingly creative versions of these patterns, and quick search on the internet will give you some great inspiration.
    If you've created any braids, or chosen to add one to your project, feel free to share photos in the discussion section below.
    In the next lesson we'll add even more character to our bag designs by adding some metal hardware.
    CLASS PROJECT
    Share a photo of your finished project with the class!
    Nice work! You've completed the class project
