METAL ABRASIVES CLASS : LESSON 4
Operating Metal Abrasive Tools
Introduction: Operating Metal Abrasive Tools
The following outlines basic operation and etiquette when for shaping and buffing parts on the grinders and wheels.
Using the Disc and Belt Sander
- Turn on the power and wait for the sander to come up to speed.
- Keep the material flat on the table.
- If you can’t do this, use a hand-held tool to shape your work.
- Slowly push the material into the sandpaper.
- Let the machine do the work for you; excessive force is not required.
- Do not sand on one spot; move the workpiece back and forth on the table.
- Stay in control of material - use two hands.
- Small parts require locking pliers.
- Turn off the power.
Using the Deburring or Wire Wheel
- Turn on the power and wait for the machine to come up to speed.
- Only work in the 3:00 to 6:00 position.
- Slowly push the material into the wheel.
- Avoid exposing an edge to the wheel.
- Keep work slightly pointed down.
Using the Polishing Wheel
- Add compound to the wheel, using the block.
- Keep material slightly pointed down.
Cleanup
- Brush off the table and clean up the area.
- Recycle scraps and put reusable pieces in the storage bin in the metal shop.
Print Out This Guide
This course is available as a PDF that is attached to this step. Enjoy the grinders and buffers safely!
CLASS PROJECT
Share a photo of your finished project with the class!
Nice work! You've completed the class project
