Straight and Curved Cuts on the Bandsaw
Bandsaw Class
Enroll
Lesson 3: Straight and Curved Cuts on the Bandsaw
Ask a Question Download
Introduction: Straight and Curved Cuts on the Bandsaw
Making Curved Cuts
Blades have a minimum cut radius depending on the width of the blade.
Forcing a blade to make too tight of a radius will result in friction that heats the work and blade, causing damage to both.
Make relief cuts to create a small radius.
When making relief cuts you must stop the blade completely before backing it out.
Making Straight Cuts
Every band saw has some amount of drift. While cutting straight with the blade, it will pull to one side or the other.
  • Adjust the angle of your work to make a straight cut.
  • Using the fence can help to make a straight cut.
CLASS PROJECT
Share a photo of your finished project with the class!
Nice work! You've completed the class project
