Introduction: Tools of the Trade
What's in a Lamp Making Tool Kit?
Most of the tools you'll need for this class are things you'd find in any toolbox or workshop, but there are a few specialized items that are necessary – and some that will just make lamp building a whole lot easier.
When buying new tools, I recommend leaning towards quality brands. They don't have to be the most expensive, but I wouldn't look to the dollar store to find them. Poor quality tools are frustrating to work with and can slow down the process. I'll provide links to the exact tools I suggest investing in, but of course feel free to go with whatever tools look good to you. Especially if they are found in your grandparent's tool box. (They don't make 'em like they used to!)
TIP: Ordering specialty tools and parts from the online lamp suppliers can take up to 2 weeks, so I recommend reading through the whole class before placing an order, so you can purchase all parts and any tools you need at the same time.
Mandatory Tools & Supplies
Optional Tools & Supplies
The following tools are handy to have when making your own lamps – especially when turning found objects into lamp bases or shades. You'll see the below tools used in the pendant and table lamp projects I link to in Lessons 7 & 8.
Mandatory Tools of the Trade
Wire Stripper
There are two main types of wire strippers available on the market: manual and automatic. The manual versions require some wrist action + elbow grease and come with a built in cutter. If you don't plan on making a ton of lamps, this is the one I'd recommend getting, as it's the least expensive. If you think you'll be making all of your relatives lamps for the holidays, do yourself a favor and invest in an automatic stripper. Your wrist will thank you.
Manual Stripper
Automatic Stripper
Wire Cutters
I like having two sizes of wire cutters. The larger pair is for the grunt work of cutting the cord and the smaller one is for the finesse work of cutting the wire. If you end up buying the manual wire stripping tool, it will already have a wire cutter built in which will be adequate for the cord cutting, so in that case, I would just get the smaller pair and not both.
Large Wire Cutters
Small Wire Cutters
Box Cutter & Scissors
For general purpose good measure.
Box Cutter With Fresh Blades
Channellock Pliers
I like having both of these sizes of pliers in my toolbox, but if you only want to invest in one, I would go with the smaller (4.5) pair, as it the perfect size for the size of nuts that are most commonly used in lamp making. For securing the center rod on table lamps, you will need two tools for tightening (one for each end), but an adjustable wrench or vise grips will work in place of the larger Channellock pliers if you already have one of those in your tool box.
4.5" Channellock pliers
6.5" Channellock pliers
Small Flathead Screwdriver
This is one of the most important tools in a lamp making tool kit. I use it to tuck twisted wire ends around socket screws, separate caps and shells (socket housing) for repairs, and so much more! I would definitely recommend investing in one of these little puppies.
4.5" Flathead Screwdriver
Phillips Screwdriver
This is another mandatory tool. It's used to tighten the socket screws and to take apart and reconstruct line switches and old fashioned style plugs. Make sure you buy one that fits comfortably in your hand and is easy to maneuver. A 6.5" - 8" one will work, depending on your hand size.
6" Phillips Screwdriver
Needle Nose Pliers
These are super helpful for getting into hard to reach places. Whether you're making lamps from scratch (raw materials) or using found objects, you never know when you're going to need to use these versatile pinchers.
Needle Nose Pliers
Continuity Tester OR Multimeter
It's important to have a way to test whether or not you've wired your lamp correctly BEFORE you plug it in, so you don't risk blowing a fuse or scaring yourself with the spark incorrect wiring can generate when plugged in. Either of these tools will do a great job of helping you discern this.
The continuity tester's only job is to test non-energized circuits, fuses, switches, wiring, etc. It's the simplest and cheapest of the two options and is perfectly adequate for all portable lamp testing.
The Multimeter, also known as a VOM (Volt-Ohm meter or Volt-Ohm-milliammeter ), is an electronic measuring instrument that combines several measurement functions in one unit, like measuring voltage, current, and resistance. It is way more than we need for this class, but if you already have access to one, it will definitely work for our simple testing purpose. Just set its switch to the setting pictured in the bottom right image below.
Continuity Tester
Continuity Tester in Action
Multimeter
Multimeter Set To Continuity Test
Electrical Tape
Electrical tape, also known as insulating tape, is used to insulate electrical wires and other materials that conduct electricity. For our purposes, it's used to secure wire nuts in place.
electrical tape
Ruler & Measuring Tape
Elmer's All Purpose Glue(not pictured)
Cutting Mat (not pictured)
Optional Tools
The following tools are not needed for this class, but are handy to have when making custom lamps:
Hand Drill
I prefer to use a cordless hand drill, but a corded one will also work.
Cordless Hand Drill
Safety Glasses
It's important to keep your eyes safe from any flying bits that may occur during drilling.
Grip Mat, Clamps, & Wood Pieces
These items will help stabilize pieces for drilling. The grip mat is simple drawer liner and any type of clamps will do as long as their deep enough to be able to fit the work table edge and the wood pieces.
Grip Mat
Two Wood Pieces (2x2" or 2x4") and Two Clamps
Center Punch
This, along with the hammer, is used to create a small hole in wood, metal, and some plastics that gives a drill bit a starting point and helps it stay put and not wander as you drill.
Center Punch
Hammer
Used by Thor AND by us to make drilling center punch marks in future shades and lamp bases.
Hammer
25/64 Drill Bit
This drill bit is the size I use to drill holes in lamp bases to accommodate a center threaded rod. I find it's the best hole size for 1/8 IP parts.
25/64 Drill Bit
Circle Compass
For this class, this tool is used to draw circles that help find the center of round bottomed shades.
1 9/16" Multipurpose Hole Saw w/ Pilot Bit
This multipurpose hole saw works well on all kinds of materials. It is the perfect size to accommodate the threads of a phenolic socket. This one has a built-in arbor (= the part that goes into the chuck of the drill). NOTE: Must buy both the hole saw and the pilot bit. Links to both above.
Half Round File
This file smoothes out rough metal edges and removes burrs.
Sandpaper
I'd recommend getting one sheet of 220 grit and 400 grit.
Ball Chain
I use ball chain to help guide lamp cord through tricky interior paths. For instance, if you've drilled a hole in the side of an object and you want the cord to go into that side hole, up through the object and out the top, sometimes it can be impossible to direct the cord or it may get caught on something inside. Instead, I would suggest, securing the end of the cord to the end of the ball chain and feed the ball chain through first, which will allow you to use gravity and tilting to find the path using the chain and then once the chain is out the top, use the chain to pull the cord through. Presto!
3' of ball chain
Self Adhesive Felt
Adding felt to the bottoms of table lamps is the best way to ensure that the lamp doesn't scratch the table.
Sized Circles
8.5" x 11" Sheets
Utility Scissors
These are good to have for cutting out center-finding templates and general making-ness.
Sharp General Purpose Scissors
T - Handle Reamer
This tool isn't mandatory (read: 100% optional), but it can be very useful. I use it to slightly enlarge holes I've drilled in metal, if necessary, to fit the lamp parts or to clean burrs from the inside of lamp rod that might injure me or the cord.
T-handle Reamer
Not pictured here, but super useful to have:
Step Drill Bits
Silicone squeeze tube
5 Minute Epoxy
Tool Shopping List PDF
Here's a handy tool shopping list for you to download and print.
What's Next?
Before you place an order for the tools you need, please read through the next few lessons. Each practice cord set requires specific parts and you'll save time and money if you get them all together!
Once all your tools and parts have arrived, it's time to dig into Lesson 3, where we'll learn and practice proper wiring techniques!
CLASS PROJECT
Share a photo of your finished project with the class!
Nice work! You've completed the class project
