Introduction: The Easiest Swing to Make Ever!
This swing is the easiest swing to assemble that I have ever used. The only hard part is getting the rope over the tree branch.
Step 1: Supplies.
1. A pogo-stick
2.some rope NOTE: please make sure that the rope is able to support your weight before you enjoy your swing.
3.a large tree you are able to climb NOTE: make sure the branch you will hang your stick on is not dead for it will fall and give you a nasty headache.
Step 2: Hang the Rope
find a sturdy branch and just put the rope over it so the two ends are about even at the bottom and two feet above the ground. If the rope ends are higher than that you will probably want to get a longer rope.
Step 3: Tie the Knots!
this will most probably be the hardest step yet. Just pay attention to the pictures carefully
Step 4: How to Have Fun
This is not exactly something you need to do but just a list of fun things to do wit your pogo-swing.
1.just swing-DUH!
2.stick your arms through the two ropes and you will be able to make awesome poses.
3. roll up th ropes on the handles even higher so it will obviously be higher in the air.
4.spin your pogo swing really tight, get on and try not to fall off.
5.loosen the ropes so the pogo-stick hangs loose but still stands at an angle above the ground. just balance on it.
