Introduction: The Party Starter
I have a glitch in the code, so it stutters every once in a while. No biggy for me, I'll fix it later. I also would have showed myself dancing and partying in the video, but my clothes are matte and boring.
Step 1: Parts & Tools
Velco Pads
Solder Iron
Dremel
Glue Gun
Gloves/Face Mask/Eye Protection
Step 2: Underpainting the Ball
I wanted a base coat of reflective, shiny material so that anyplace where mirrors aren't has some reflective quality. This ball used almost this entire mini can of spray paint. The holder for the ball was quickly made by twisting some coat hanger wire into a shape that'd hold the ball off the ground.
Step 3: Add the Mirrors
Start with the center line and work your way out. Dab a bit of glue and place the tiles. Don't worry too much about gaps, we are attaching square tiles to a circle after all. That's why we painted it with sparkle paint.
I had to take a break for the night after the top section was completed. The glue I was using took FOREVER to dry. The next day I switch to the ol' hot glue gun.
Step 4: Finish the Ball
Now that the mirrors are all set, We've got to use a clever way to attach it to the servo. Velcro will be our mating material. I don't want to ruin a servo and it'll be handy for transportation to be able to remove the ball.
Step 5: Make the Base
Start by marking off where you want the components to go on the foam block
Like all cutting, measure twice and cut once.
I used a Dremel to remove unwanted foam. There are foamcutters, you could use a lighter, smash and tear at it. Whatever your method, know that the servo must be tight so that all the torque and power is transferred to the party ball. Also dremeling this foam turned it into a fake snow like substance, Lots of Fun, bad for the lungs-WEAR PROTECTION.
Go around, add a ton mirrors. Try not to burn yourself on the glue or cut yourself on the glass.
Step 6: Wiring
The servo is the only thing to wire up here. 5Volt, Ground and the signal wire(white) to pin9. I've left room for LED's, Lasers, Buttons, etc. Add what ever you want. Throw another servo on there and make a laser turret. This is how I wanted mine, make your how you want it.
We are not using the servo library in the Arduino code because it was being fussy with the other libraries. I don't know why, but I just worked around it. We are using a servo and not a different motor because of the ease that a servo will mount and attach.
Step 7: Upload the Code
#include <AF_Wave.h>
#include <avr/pgmspace.h>
#include "util.h"
#include "wave.h"
AF_Wave card;
File f;
Wavefile wave; // only one!
uint16_t samplerate;
void setup() {
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Wave test!");
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(9, OUTPUT);
if (!card.init_card()) {
putstring_nl("Card init. failed!"); return;
if (!card.open_partition()) {
putstring_nl("No partition!"); return;
if (!card.open_filesys()) {
putstring_nl("Couldn't open filesys"); return;
if (!card.open_rootdir()) {
putstring_nl("Couldn't open dir"); return;
putstring_nl("Files found:");
ls();
void ls() {
char name[13];
int ret;
card.reset_dir();
while (1) {
ret = card.get_next_name_in_dir(name);
if (!ret) {
card.reset_dir();
return;
Serial.println(name);
uint8_t tracknum = 0;
void loop() {
uint8_t i, r;
char c, name[15];
card.reset_dir();
// scroll through the files in the directory
for (i=0; i<tracknum+1; i++) {
r = card.get_next_name_in_dir(name);
if (!r) {
// ran out of tracks! start over
tracknum = 0;
return;
putstring("\n\rPlaying "); Serial.print(name);
// reset the directory so we can find the file
card.reset_dir();
playcomplete(name);
tracknum++;
void playcomplete(char *name) {
uint16_t potval;
uint32_t newsamplerate;
playfile(name);
samplerate = wave.dwSamplesPerSec;
while (wave.isplaying) {
digitalWrite(9, HIGH);
delay(1);
digitalWrite(9, LOW);
delay(1);
// you can do stuff here!
delay(50);
card.close_file(f);
void playfile(char *name) {
f = card.open_file(name);
if (!f) {
putstring_nl(" Couldn't open file"); return;
if (!wave.create(f)) {
putstring_nl(" Not a valid WAV"); return;
// ok time to play!
wave.play();
Step 8: All Done!
In your workshop
Arduino Challenge
ShopBot Challenge
Holiday Gifts Challenge
