$30 High-Speed PCB Drill Press
Intro: $30 High-Speed PCB Drill Press
Want super clean holes in your latest PCB? Want your PCB drill-bit's to last much longer? Tired of using your dremel as the drill press it clearly isn't? For around $30, you can build this simple PCB drill-press.
STEP 1: Planning / Materials
This started when we (me and some fellow modders / hackers) realized we wanted a simple high-quality PCB drill dress, but didn't want to pay $400+ for something that would only run at around 20,000 rpm. We also did not want to use the standard dremel drill-press for drilling PCB's as they tend to break bits fairly fast, and PCB drill bits can be expensive.
The solution that we arrived at was to use a Harbor-Freight Pneumatic 1/8" Micro Die Grinder, and attach it in-plane with a precision linear slide rail. The Micro Die Grinder runs at 56,000 RPM and has the 1/8" collet that I needed for the PCB drill-bits.
The keep the die-grinder in-plane with the rail, we decided to mount the linear rail to a self-centering drill-press jig.
The parts list:
1.5" Square Steel Tubing - Scrap from Around the Shop
56K RPM Micro Die-Grinder Drill - Harbor Freight - $10.00
- http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47869
Self Centering Drill Press Jig - Harbor Freight - $6.00
- http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92046
THK Linear Slide Rail - $10.00
- Ebay, Search for "THK Slide" or "Linear Slide"
MDF for deck - Scrap from Around the Shop
MISC. Screws - Scrap from Around the Shop
Springs - Home Depot / Lowes - $5.00
The parts list:
STEP 2: Build the Drill Mount and Attach It to the Slide
Start by cutting down the Auto-Centering Drill Press Jig. We cut it down to a couple of inches high. This allowed it to provide a good amount of support for the drill, but still be short enough to clear the twist-on/off valve on the drill.
We removed the excess sides of the self-centering drill press jig, and sanded all the rough edges smooth. The THK rail mounts vertically along the center. We used the measurement between the holes to drill through the drill mount.
The holes are easily centered along the mount by drilling in the V in the center of the mount with a small bit, followed by a larger bit and finally using a tap and die set to tap out the threads from the back of the mount.
This is the most critical step of the process, the Drill-Mount MUST be in-plane and square with the Linear Slide.
We then attached the other side of the rail to a small section of angle-iron. We did this by drilling out four holes that I had previously marked. Get these as close as you can to square with the Linear Rail.
If your angle iron isn't square (ours wasn't), then use a square and a sander to square it up.
This piece of angle-iron will be used to mount our Linear Rail / Drill Mount to the Frame.
STEP 3: Build the Frame
At this step of the process we are going to build the frame.
I won't go into exact dimensions, however you do want the drill to be forward enough from the back plate to allow for whatever size boards you would like to drill. It will also need to be high enough to accommodate the drill and have enough room to move at least 1/2" above the board to just below the boards surface.
We will also be attaching 3/4" MDF for the deck, so don't forget to allow for that in your vertical measurements.
After you cut the pieces you need (you can see how we did it below), you will need to weld them together. If you don't know how to weld see if you can get a friend to weld it for you. Failing that you can take it to a metal-shop and they should be able to do it for fairly cheap.
STEP 4: Mount the Deck, Slide, and Drill
Almost done, now we just need to mount the deck, slide, drill, and return springs to the frame.
We started by cutting the Deck out of some MDF we had around the shop. We cut a notch out of it to fit around the back of the frame. We mounted the drill to the drill-mount/slide with some zip-ties that we had around the shop, and then attached the slide to the small piece of angle-iron that was welded to the frame.
We drilled and tapped a couple of holes near the middle of the upper arm and also in the drill mount and ran the springs between them. This provided the auto-return for the drill.
We also tapped and drilled to holes into the base of the frame to attach the deck to. The screws in the deck are counter-sunk (see finished pictures on next step) so that the PCB's can slide around the top of the deck easily.
End-caps were installed to keep everything looking neat.
STEP 5: Finishing Thoughts
We ended up attaching a spring to the slide and the back of the upper arm. We did this to remove any excess slack in the linear rail that might appear over time.
The only changes we may make is to add a handle to lower the drill. Currently you simply press down on the top of the drill which works great for now.
Our holes came out perfect, and there was absolutely NO noticeable wobble or tilt in the drill. Just straight, clean holes every time.
75 Comments
MatanSilver 13 years ago
JohnathanW15 6 years ago
ever heard of rental? I can get an air compressor for 4 hrs for 15 bucks at mennards. if you are doing so many you need it for more than 4hrs, you should probably be sending out to have your boards made. also, If you dropped the attitude you have you might manage to make friends with someone who owns a welder. in my experience most people that own them are happy to do a project as small as that for you/with you for a 6er of beer you will probably consume with them...or just conversation
vharihar 8 years ago
Can someone explain to my *what/why* exactly is the problem in using the Dremel workstation as a drill press jig? Why do the drill bits keep breaking off?
I was considering buying the Dremel workstation for making PCB holes, and wanted to know its drawbacks in this regards, before buying it.
sanoberr 8 years ago
I want to buy $30 High-Speed PCB Drill Press.
hyratel 10 years ago
part numbers on HF's website have changed. drill press jig is now at
http://www.harborfreight.com/self-centering-drill-press-jig-92046.html
armorer243 10 years ago
Z.K. 11 years ago
pfred2 12 years ago
electronicdude 14 years ago
bombmaker2 13 years ago
bobbyrae 14 years ago
Davad 14 years ago
However, I agree with your findings of the prices. This instructables must have been written 20 years ago when thing where cheaper.
lancandy 14 years ago
wildo 14 years ago
technopenguin 16 years ago
adnimo 14 years ago
lancandy 16 years ago
