[Collegiate Meals] I Love You (Virus) Burgers
Intro: [Collegiate Meals] I Love You (Virus) Burgers
If stereotypes serve right (ha!), "I love you" is the hardest thing to say (or most dangerous). Unless of course its a contagious message in your mailbox awaiting outlook to execute and infect.... And these burgers are contagious!
I personally like my burgers thin, flavorful and I like to eat a lot of them. I really don't like burgers that are so thick that they take so long to cook that they crumble and leave you with a mouthful of meat (of any kind) and nothing else. Not to mention - no more circle burgers with square buns! I learned my lesson when I was little -- the cube won't fit into the circular hole :P
Here's how I make my burgers. If you like Parmesan cheese, you probably like Parmesano Reggiano which gives these burgers a unique aromatic flavor. Nothing says I love you more than a steaming heart made from ground meat :)
STEP 1: Ingredients
Lean Ground Meat (Red, White, Other White or just other)
Parmigiano Reggiano
Salt
Buns!
You'll also need a cheese grater for the Parmigiano, some sort of rolling pin (I used a beer bottle) and some freezer paper.
Parmigiano Reggiano
Salt
Buns!
STEP 2: Prep
Place your ground meat into a small bowl and add about a quarter cup of finely grated cheese per pound of meat along with two pinches (use your own judgment) of salt per pound.
Mix well -- don't be afraid to mash it up. Make a ball.
Place foil on a baking sheet and place the meat ball on top.Place a sheet of freezer paper on top of this and roll the meat out to a quarter inch thickness. Discard freezer paper.
Select your cutting utensil(s). I am using a heart shape. If you want squares, a pizza cutter works wonders (if you have one) - if not, use the dull side of a knife or a spatula to make squares slightly larger than your buns.
Buns
Before you go cutting away at your meat, take a look at your buns. Are they circular? Or square? If you got a mass produced pre-packed sack of buns (the kind that are typically 2 stacks of 4 connected buns), they are likely square ;) So make your meat square.
To fit our special shapes, first cut your buns using the same cutting tool that you will use on your meat - do this first.
Next, use your cutting tool to cut your meat.
Buns
STEP 3: Cook and Build and Serve
Look at my griddle/waffle maker.... Would you guess that it's 40 years old? Well, it's not -- but my parents have one that is -- and it doesn't look a day over 15 :P My grandmother and grandfather used it, my mother and father use it, I used it and when I went to college, I had to have one myself because my parents wouldn't give theirs up (and I can't blame them for that). Well, years and years later - It's still made! Same exact model.
I highly recommend it too - I believe I paid $40 and it's a waffle iron (flip the irons), griddle, grille and panini machine (makes great pressed Cuban bread/sandwiches).
Anyway - cooking. I set my griddle to a medium heat... So if you're doing the same in a pan, do the same ;) I allowed a few minutes of preheat and gave a very light spray of cooking oil (lean meat == less lubricating oils)
3 minutes used as a panini machine - no flipping. If you're using a pan, 3 minutes on the first side, 2 on the second - flip once. You probably can cook for even less time.
Don't forget to make sure your buns are well toasted -- if you're into that sort of thing ;)
Building
I like a little crunch and a little acid with my burger.... So some heat shaped slices of lettuce and some tomato. To add a bit more aromatic flavor, some grated cheese on top for garnish and flavor.
Served with an Ice cold beer... And I'll be the first here to say - Orange Blossom Pilsner is not good at all - not as bad as a skunky beer. Just cheap tasting.
Building
9 Comments
CapnChkn 16 years ago
CrawfishYAY 13 years ago
I Am An Evil Taco 16 years ago
david2222121 16 years ago
Treepwood 16 years ago
incorrigible packrat 16 years ago
John Smith 16 years ago
jongscx 16 years ago
Fenwick 17 years ago
