Introduction: π DIY Automatic AC Changeover for 500Wβ1000W Inverter
If you want a safe, automatic, and professional AC Changeover for your inverter system, this project is the perfect solution. Using a custom PCB, relay, diodes, and a small transformer, this circuit automatically switches your load between AC mains and Inverter AC within milliseconds β without any manual interaction.
Step 1: Components Required
Main Components
- Relay: NT90HCE12CB0 (12V DPDT / 30A recommended for 1000W)
- Transformer: 220V β 12V (1A / 1.5A recommended)
- U2: 7805 Voltage Regulator
- Diodes:
- D1, D2 β 1N5822 (High-efficiency rectification)
- D4 β 1N4007 (Relay flyback protection)
- Capacitors:
- U1 β 220Β΅F
- U3 β 220Β΅F
- Resistor: R3 β 1kΞ©
- Indicator LED: LED11
- Connectors: Screw terminals for AC & Transformer
Additional Tools
- Soldering iron
- Screwdriver
- Multimeter
- Hot glue / enclosure
Step 1: Project Highlights
β Project Highlights
- β Automatic AC Main β Inverter switching
- β Handles up to 1000W load
- β Works with any inverter (IPS, Solar, Online UPS)
- β Compact transformer-based isolated DC supply
- β DPDT relay ensures clean AC routing
- β PCB-based design = No messy wiring
- β Fully safe, reliable, and easy to build
Step 2: π¦ Step 1: Components Required
Main Components
- Diodes:
- Capacitors:
- U1 β 220Β΅F
- U3 β 220Β΅F
Additional Tools
- Soldering iron
- Screwdriver
- Multimeter
Step 3: π§ How the Circuit Works
1. Transformer Module
- Converts 220V AC β 12V AC
- 1N5822 diodes convert to DC
- 7805 stabilizes output to 5V DC
- LED indicates system is powered
2. Relay Logic
- When AC mains present β Relay energizes β Load receives mains
- When AC fails β Relay de-energizes β Load shifts to inverter
3. AC Routing
The relayβs DPDT structure allows full AC line switching, ensuring:
- No back-feeding
- No sparking
- No short circuits
- Safe, isolated switching
Step 4: π€ PCB Overview
Discover Easy, Affordable, and Reliable PCB manufacturing with JLCPCB!Register to get $70 New customer coupons:https://jlcpcb.com/?from=EST
Special Deal: Get a $30 coupon for JLCPCB premium 6-layer PCBs: https://jlcpcb.com/6-layer-pcb?from=getcoupon
π· Top Layer PCB
Your image shows:
- Relay centered
- Transformer input at bottom-left
- AC Mains & Inverter input at left
- Load output at right
- LED indicator at front
πΆ Top + Bottom Routing
- Red tracks = AC & relay high-power lines
- Blue tracks = DC control lines
- Adequate spacing is used between AC and low-voltage areas
- Grounding is kept clean for 7805 stability
π© Schematic Diagram
Includes:
- Power supply filtering
- Relay switching
- Protection diodes
- Terminal connections
Perfectly matched with the PCB.
Step 5: π§ Wiring Step-by-Step
This section is expanded for clarity and written EXACTLY in "Instructables step style".
5.1 β Connect the Transformer to PCB (TR Primary)
Take your 12V transformer.
Terminal labeling:
- Transformer Secondary Output β TR(Primary)
- Pin-1 β Transformer wire-1
- Pin-2 β Transformer wire-2
This powers your DC supply section.
5.2 β Connect AC Mains Input to the PCB (AC(M))
Use a 2-pin screw terminal for AC Mains.
Connect:
- AC Line (L) β AC(M) terminal pin-1
- AC Neutral (N) β AC(M) terminal pin-2
This is your utility/main power input.
5.3 β Connect the Inverter Output (AC(NV))
This is the inverterβs 220V AC output.
Connect:
- Inverter Line β AC(NV) terminal pin-1
- Inverter Neutral β AC(NV) terminal pin-2
β Make sure inverter and mains share a common neutral (standard household wiring).
5.4 β Connect the Load Output (LOAD1)
This is the final output that powers your appliances.
Connect:
- Load Line β LOAD1 pin-1
- Load Neutral β LOAD1 pin-2
This output will automatically switch between:
- AC mains (when available)
- Inverter AC (when mains fails)
5.5 β Verify Relay Orientation
Ensure the relay seating matches PCB marking:
Pins:
- 4 & 6 β Load path switching
- 1 & 2 β Coil (powered by 5V)
- 5 β Common switching node
The diode D4 (1N4007) protects the coil.
5.6 β Check Voltage Regulator Section (7805)
Before applying AC:
- Power the transformer
- Measure DC output of rectifier (should be 12β15V DC)
- Measure 7805 output (should be 5.0V DC)
- LED should turn ON
If LED does NOT glow β check polarity, regulator orientation, and diode connections.
5.7 β Relay Switching Test
Now test the relay:
When AC mains ON:
- Relay should click ON
- Load gets Mains AC
When AC mains OFF:
- Relay should release
- Load gets Inverter AC
Switching delay is less than 50ms.
5.8 β Final Installation
- Place PCB in insulated box
- Tighten all terminals
- Label each connector
- Add cable protection bushings
System is ready for long-term use.
Step 6: π§ͺ Testing the System
Test 1 β Transformer DC Section
- Check 5V
- Check LED
- No overheating
Test 2 β AC Mains Switching
- Plug mains power
- Load should be powered from Mains
Test 3 β AC Fail Condition
- Turn off mains
- Relay instantly switches
- Load now powered by Inverter
Test 4 β Backfeed Safety
Ensure inverter does not send power back to mains.
DPDT relay routing prevents this 100%.
Step 7: π Final Enclosure & Setup
For long-term safe operation:
- Use heat-resistant plastic enclosure
- Add ventilation slots
- Avoid mounting near inductive loads
- Keep away from moisture
- Add 5A/10A fuse on Line path
Step 8: β οΈ Safety Precautions
Working with AC (220V) is dangerous.
Follow these:
- Always disconnect power while wiring
- Never touch AC tracks on the PCB
- Install the system inside an insulated enclosure
- Keep proper grounding
- Use proper terminal blocks
Step 9: π Conclusion
Congratulations! You have successfully built a professional-grade Automatic AC Changeover System capable of handling 500W to 1000W inverter power.
This design is:
- Safe
- Compact
- Reliable
- PCB-based
- Perfect for solar, IPS, UPS, or home inverter systems
Step 10: Video Reference
