+ Shelf
Intro: + Shelf
This project is a prototype for a modular shelving system that uses simple boxes and connectors to create infinite sizes and configurations.The primary goal was to design a system that anyone could adapt to suit their own space and stuff. The secondary goal was to test whether minimal 3d-printed joints had the structural integrity to hold the weight of solid plywood.
STEP 1: Design
I had a few critera for the design of the shelves. They couldn't have too many types of parts. They had to be modular. And the pieces all had to be simple shapes that were easy to fabricate. The complexity had to arise from the aggregate of the parts, not the parts themselves.
Most modular shelving units fit into one of two categories: they are either stacks of boxes piled on top of each other, or they are large monoliths that are not really modular at all, like the Ikea Expedit. The plus shelf invests instead in the modularity of the connector: simple, colorful, 3d-printed plusses. Each plus connects two boxes diagonally by snapping into holes pre-drilled into the edges of the boxes.
STEP 2: Materials & Supplies
Materials:
- (1) 4'x8' sheet of 3/4" ApplePly or some other plywood with a nice edge.
- (56) #10 biscuits
- Wood glue
- Scrap wood for tests and jig
- Hot glue
Tools:
- 3D printer that can print Vero
- Table saw
- Biscuit joiner
- Big clamps - lots of them
- Drill with 3/8" Forstner bit
- Orbit sander and sandpaper in rough and fine grits
- Glue gun
Optional (for dyeing 3D prints):
- Jacquard iDye Poly
- Rubber gloves
- Tongs
- Metal boiling pots
STEP 3: Make the +'s
I designed the plusses to fit within a 3/8" hole that would be drilled into the wood. Each leg of the plus has a little extrusion at the tip that's invisible once it's snapped into place, making the whole shelf assembly appear as if it's magically balancing on the plusses.
I printed the plusses on an Objet 3d printer in Vero White, because I knew that it would take dye well. Once printed, I followed this instructable to dye them. The colors turned out really fun and vibrant, but it turns out they eroded the prints a bit and made them more bendy, which ultimately led to some structural problems with the shelf.
STEP 4: Building the Jig
Before I could make the cubbies or print the final plusses, I had to be sure the design would even work. I screwed together a couple pieces of plywood and printed a couple of plusses. Then I drilled a bunch of holes in the wood until I got some that allowed the plus to snap tightly into place. The 3d print had just the right amount of give to fit into the holes without popping back out again.
Once I determined the optimal distance for the drill holes from the edge of the wood I built a little jig that would let me place the holes in the right location every time. The jig consists of a small chunk of mdf with a hole drilled in it, and a couple dowels that are meant to rest against the edge of the cubby.
STEP 5: Building the Cubbies
For the cubbies, I managed to use only 1 sheet of 4'x8' plywood (with enough extra to make a few mistakes!). Once I'd settled on the sizes and layout of all the cubbies in 3d I used a pencil to mark where the table saw cuts would go. Then I set the blade on the table saw to cut at 45 degrees and ran the plywood through until I'd made all the cuts.
Assembling the cubbies was pretty straight forward. The key was to biscuit, clamp and glue all 4 sides simultaneously to ensure that they were all at 90 degree angles. Once they were all built, I did a test of how the whole configuration would stack.
STEP 6: Assemble
The shelves snapped together wonderfully, but unfortunately the new bed in the 3d prints caused them to pop out of place under the weight of the shelves. Some strategically-allocated super glue in the drill holes served to keep the plusses in place.
My next goal for this project is to modify the design to have metal connectors that provide greater structural integrity to the assembly, but I'm pretty happy with how this prototype turned out.
Thanks for reading!
14 Comments
mistergreen 8 years ago
Great idea, and great project. I hope you can work out the integrity issue. I love things which don't make me cringe when i imagine moving them. If they had a slight lip at the back, you could drop another piece of plywood in and use them as moving boxes. The lip may also add some lateral stability. It looks so cool, i hope whatever the solution is doesn't mess with the look.
shurly 8 years ago
Thank you! Can you elaborate more what you mean about the lip? Do you mean every box would have an additional side? The boxes themselves are very sturdy, but I did think about adding another long cubby that sits underneath the whole assembly to stabilize it when I move it. You're right - the idea of moving it does scare me more than a bit right now!
just a thin support inside, so when it's time to move, you slip a piece in, and each box can move stuff. Perhaps the things which were in them already ;-)
shurly 8 years ago
Ohhh, I'm following now. Neat!! And nice rendering! Thanks for the idea!
janberlaconsay0121 11 months ago
joshuav4 8 years ago
Have you thought about starting a Kickstarter campaign or something to start selling these?
shurly 8 years ago
I HAVE :) But I think first I need to come up with a sturdier connector - possibly one that's milled or cast out of metal.
Gnome_Scout 1 year ago
fisho1 8 years ago
nice idea i like mixing wood and printing. just an idea but if you off set the vertical bits see pic the loading would all be in compression and the joins shouldn't pop out. the system would also take more load if you where going to fill the shelves up. it wouldn't quite be plus shelf but close. good job
shurly 8 years ago
Whoa, thanks for the input! This is definitely a more stable system. I think there's got to be a happy medium between the two ideas that is more stable without losing the 'floating' feeling. I'll definitely keep this in mind as I continue to develop it. Thank you!
tbar kozyva 8 years ago
Who....Great Great Idea - what about embedded the connector into the wood surface ? It will need more extra efforts...and maybe CNC...
shurly 8 years ago
That's a great idea! I may do something like that next. Thanks!
Digital Electronics Circuits Lab 8 years ago
nice work
krivas 8 years ago
