0 Gauge Plug Earings
Intro: 0 Gauge Plug Earings
This is a instructable to show people how too make plugs very cheeply and in about five minutes.
This can be dangerous too make and too wear please make sure your ears are completely stretched and healed before wearing. I am not responsable for your actions. Proceed with caution!
TOOLS:
razor
pliars
ruler
lighter *
sharpie*
SUPLIES:
pen body with outer diameter of 5/16"
piercing/plumbing O-rings (not sure the size)
any resin/filler*
*optional
TOOLS:
razor
pliars
ruler
lighter *
sharpie*
SUPLIES:
any resin/filler*
*optional
STEP 1: Cut Away!
get your pen body ,
mark about half an inch,
cut off,
do this twice.
you now have two 0 gauge "blanks" as i call them
cut off,
do this twice.
STEP 2: Get Filing.
this part is easy
file the edges...
file the edges...
STEP 3: Seperate Ways..
this is where you can go a couple different ways
if you want no flares on your plugs got to step 6
if you want double flares go to step 5
if you want one flare keep moving along
STEP 4: One Flare
if you want one flared edge take your lighter and heat one edge gripping the blank with your pliars,
after the plastic stars to melt press it firmly against a flat surface,
add O-ring to other side.
STEP 5: Two Flare
if you want botht flared edges take your lighter and heat one edge gripping the blank with your pliars,
repeat to other edge.
STEP 6: No Flare
if you want no flare on either edge just put two O-RIngs on and go to step 7
STEP 7: Customize...
now you have your plugs!
what you can now do is fill the inside with resin to have a solid plug
or just paint, glitter, or leave as is.
i kept mine hollow but im going to make a solid set soon
i also painted the front of one white
before you wear these sterilize them ass much as possible using rubbing alclohol
or you can get an infection
Again this can be dangerous too make and too wear please make sure your ears are completely stretched and healed before wearing. I am not responsable for your actions. Proceed with caution!
show me how yours turned out =]
