$1 DIY Conductive Ink and Paint From Fire! (non Toxic, Homemade, Cheap)
Intro: $1 DIY Conductive Ink and Paint From Fire! (non Toxic, Homemade, Cheap)
Turn fire into electronic conductive ink, build electronic circuits, create paper musical instruments and inputs for your Arduino board!
UPDATE (08/18/2014)
If you would like to avoid the process of making your own charcoal and blending it into a paint, I bought very inexpensive 'powdered active carbon', 1kg or 2,2 pounds for just $5. It's already in powder form, no need for added black paint, I used this powdered carbon with just a bit of clear glue and some vinegar to mix it (vinegar is more conductive than water) and I got readings of 23 K to 40 K ohms per 1 inch, so it is more conductive and gives better results than the DIY powdered charcoal, similar or even better than graphite and I believe less expensive.
Today you will learn how to make your own conductive ink to draw electronic circuits using the leftovers from your fireplace or BBQ! You can use this ink to draw circuits on paper and cardboard, learn about electronic circuits or play around with arduino boards like the Makey Makey to create paper musical instruments like pianos, digital drumsets, guitars, etc.
Conductive Ink is a great way to learn the basics of electronics. This a recipe that is non-toxic and extremely low cost. Comercial conductive inks cost around $10 to $15 for a small pen that may not last for much, specially if you want to draw large shapes or cover large surface areas.
This paint will just cost you cents to make using charcoil left from your fireplace or BBQ, a bit of black water paint and a bit of Elmer's glue! That's it!!
STEP 1: Step1: Select Conductive Pieces of Charcoal
Using a Digital Multimeter, measure the electrical resistance of charcoal pieces from firewood remains from your fireplace or BBQ. Choose the pieces that have less resistance, the less resistance they have the more conductive your ink and paint will be. Select pieces with less than 100 ohms. Some pieces haven't been burned completely and since wood is a good insulator these pieces of charcoal will not be suitable for this project.
STEP 2: Step 2: Put Charcoal Pieces in a Blender and Mix!
Once you select the most conductive pieces of charcoal, add some water in a bowl with them so that they moisture. Then place them in a juice blender and turn the power on! You will basically make a carbon dust juice :) Blend for like 5-10 minutes on the highest speed. Then just pour the carbon juice into a glass and let it sit for one to two hours. This will make the extra water float on the top as seen with a light from the back. Take out the extra clear water on the top with a spoon or syringe. You want your mix to have the most carbon particles and the less water possible to make it more conductive.
STEP 3: Step 3: Add Black Paint and Elmer's Glue
Once your carbon juice has less of the clear water on top place some water-based black paint (about 1 tea spoon) and some clear Elmer's glue (about 1 tea spoon too) and stir. These two ingredients will give your paint a deeper black color and more consistency. The glue will help all the carbon dust particles stick together and to the paper once you start drawing circuits on paper and it dries.
And that's it!! you are ready to draw basic electronic circuits using LEDs or other electronic components, 6 or 9V batteries or an AC transformer with variable voltages.
Commercially available inks are much more expensive but also they are much more conductive because they include tiny silver particles or industrial purified carbon. However making your own ink will not also teach you about the electric properties of different chemical elements like carbon, but it's also a very inexpensive ink to paint large surface areas if you want to make paper electronic instruments like pianos, guitars or drumsets!
Hope you can try this Instructable and please let us know if you find new ways and materials to make your own ink, visit us at http://www.makerboat.com if you have any suggestions. Let's create a Creative Commons, Open Source Conductive Paint!
84 Comments
njmalhq 5 years ago
What happens when the vinegar dries out? Does the conductivity of the ink go down?
TURBOTECHNOLOGY 6 years ago
Smees69 6 years ago
After making a large quantity, could you paint a room, then prime, and paint over that with regular, indoor paint, creating a Faraday cage? I realize the windows and doors would need the fabric to create curtains out of, but the floor could be painted as well, before the flooring is put in. Does this stuff have the durability and longevity for such a project?
sp63 9 years ago
Did anybody try to make conductive glue without using charcoal or graphite? I am just thinking if I dissolve some table salt (NaCl) or any other salt or electrolyte in Elmers glue (PVA) and then dry it, would this material conduct electricity? In theory, salt should not dry completely at room temperature, so there will be some Na+ and Cl- ions in the dried glue. If someone tried this, I would be curious about the results.
VictorN61 6 years ago
Salt would not work as it requires a liquid medium for the ions to flow. Once the glue dries, the ions would not be able to flow. For example, you have a lump of salt and you use a multimeter to measure it's resistance as infinitely high. Dissolve in water and the resistance is low.
shomas 6 years ago
"Did anybody try to make conductive glue" Sodium silicate is made from dissolving glass or better yet silica gel into a hot an aquas mix of sodium hydroxide and mixing in water to get water glass. Then activate it with carbon dioxide to form an adhesive
Trike Lover 6 years ago
How concentrated would the Sodium Hydroxide have to be to dissolve the glass or silica gel, and how hot? Would it be necessary (or advisable) to do this reaction in a fume hood, or at least somewhere with very good ventilation? Also, would any special protection be needed, over and above saftey glasses and gloves resistant to hot Sodium Hydroxide? To activate the water glass solution, would you bubble gaseous CO2 through the mixture, or could Dry Ice be used in some way? Just curious, since I'm not an expert in chemistry.
shomas 6 years ago
"How concentrated would the Sodium Hydroxide have to be to dissolve the glass or silica gel, and how hot?" Concentration may very. Too low concentrations of sodium hydroxide will will not convert all the silicon dioxide into sodium silicate. Higher concentrations of of sodium silicate will take on more of the properties of sodium hydroxide. The reaction occurs very very slowly at room temperature. It happens much faster on a stove.
"Would it be necessary (or advisable) to do this reaction in a fume hood, or at least somewhere with very good ventilation?" I dont believe anything is gassed off but for other safety reasons I would prefer doing it outside away from things.
"Also, would any special protection be needed, over and above saftey glasses and gloves resistant to hot Sodium Hydroxide? To activate the water glass solution," I will say this DO NOT underestimate the DANGER of molten Sodium hydoxide. ABSOLUTELY do lots of research of safety protocols when dealing with molten sodium hydroxide. https://goo.gl/6xe5Le This was damage done by room temperature sodium hydroxide. Molten would have been much worse.
"would you bubble gaseous CO2 through the mixture, or could Dry Ice be used in some way?" If one were making a mold then maybe, but if one is considering sodium silicate as a binder in a glue in a conductive ink then I suspect atmospheric CO2 is sufficient , but you could breath on it to speed it up.
danzman 8 years ago
There is a conductive polymer that can be used to make inks or paints: http://www.heraeus-clevios.com/en/conductivepolymers/pedot-pss-conductive-polymers.aspx
GabrielG26 8 years ago
Isn't even easier to try it yourself?
The Cartographer 9 years ago
Do you think different types of wood would be different in their electrical conductivity? If so which ones do you think would be the best? Would a combination of different types of wood be better than one single variety? Would paper be better than wood? If so which type of paper?
I feel that you've discovered something truly awesome and once it's figured out it'd be a very green method of wiring sustainable homes for the future. You could coat the exterior of a house with this, plug your solar panels into the ink and power electronics quite easily. You should do more research into this and what types of carbon work best.
makerboat 9 years ago
These are very good points. I envision one day you could use a special ink to print out your own solar panels at home using some kind of ink that creates the necessary layers of materials to convert solar light into electricity for example. I don't think charcoal will do it though :)
For wiring homes this material will not do it because it does not conduct electricity as efficient as metals (copper wires), but for educational purposes it's very good to learn about the conductivity of everyday materials. Regarding different kinds of wood, yes I feel that hardwoods that make a better, slower burning charcoal are better than softwoods, but that's my intuition, it would be awesome if we could have different people measuring different charcoal in different countries as to learn more about this. I try measuring conductivity of paper ashes (I thought it was a good suggestion!) and unfortunately they are not conductive.
astral_mage 8 years ago
mit did that expriment already. they found out that had a problem . the paper self ignited around 400f.
ErnestoS 7 years ago
And getting to 400 F(or 204 °C) is pretty easy with experimental prototype circuits, right?
shomas 6 years ago
Certainly can be very easy. For instance a 1.5V battery with two thick wires and a thin copper wire is all that is needed to ignite paper it. The thick wires conduct current well enough to a thin wire that heats up from a large amount of current flowing though it. Its not a stretch to see 5 or 12 volts applied to two conductive ink terminals with a thin section in between generating heat, and we have not even gotten to the loony toons that would try to put 110v to it to see what happens. Im not saying conductive inks on paper should not be done, just that inconsistent ink conductance or design could lead to a fire.
BryanB158 6 years ago
Those are unecessary safety concerns, in my opinion. You don't need conductive ink or paper to make a housefire using electricity.
But this is an old discussion. We already have conductive ink made for common inkjet printers and even 3D printers that can print circuits using conductive plastic.
shomas 6 years ago
"Those are unecessary safety concerns, in my opinion" When it comes to the potential of starting fires, the current density through a cross section of any conductor is very much a necessary safety concern made all more important by the fact your dealing with paper substrate and thin wires in one and or two dimensions made from inks.
"You don't need conductive ink or paper to make a housefire using electricity." My point was not what is the best way to start a house on fire, but to bring awareness that the potential is real with poor designs, so that one can ensure it does not happen by accident. Simply put some thought into ones design.
macrumpton 6 years ago
do you think it would be possible to use soot from a match or acetylene flame to coat something with a conductive layer?
Trike Lover 9 years ago
A few thoughts. One would be to cut or break your carbonized lumps into an approximately equal size before measuring resistance and selecting. Second would be to use household rubbing alcohol (dilute isopropyl alcohol) rather than water only when blending - a good portion of the alcohol will evaporate after blending if you leave the mixture spread out to dry & exposed to air. Appropriate caution about open flames and proper ventilation would be needed, but rubbing alcohol is quite safe to work with. Third would be to spread the charcoal/water mixture out on top of a cookie sheet after blending, then put it in the oven at low heat for a short time. This will give you even evaporation but more quickly - you would not leave the paste on the cookie sheet in the oven until it's a dry powder.
thanks for the tips on improving the whole procedure! I specially like the use of alcohol as it evaporates faster, will try it out!
