Making a Vacuum Bag Connector (Vacuum Port) for $10 With Hardware Store Parts
Intro: Making a Vacuum Bag Connector (Vacuum Port) for $10 With Hardware Store Parts
In this instructable I'll show you how to make a vacuum bag stem (also called a vacuum breach valve/unit). These are important in vacuum bagging because taping the hose on the seam of the bag is a recipe for leaks and disaster.
This adds on to the excellent guide on vacuum bagging basics
It also goes well with the bicycle-turned-vacuum pump guide if you want to do some hand powered vacuum bagging, or the great tire-inflator-turned-vacuum-pump guide.
STEP 1: Gather Your Parts
4 3/8" steel washers
2 3/8" ID, 7/8" OD neoprene washers
1 1/8" F nut (dunno what they're called)
1 1/8" M to M threaded tube connector (the shorter the better)
1 1/8" F NPT to hose connector
Vacuum bagging plastic sheet/film
STEP 2: Assemble Everything
Rubber tube connector, M M threaded connector, 3 steel washers, 1 neoprene washer, plastic to be vacuum bagged, 1 neoprene washer, 1 steel washer, nut.
Note: When you put the vacuum bagging material on you will need to punch a hole in the bag to get the tube through. Make sure this hole is smaller than the tube, and stretch it around the tube to help prevent leaks.
STEP 3: Done! Enjoy Your Breach Valve
On a side note: The neoprene washers should be a tight fit around the tube. This is good because if it doesn't happen, you'll have air leaking around the rubber and killing your vacuum.
12 Comments
JaakkoP1 6 years ago
This isn't very good solution. You need to solder the first washer(s) to the brass hose connector, then you are able to block the air leaking when there isnt any route to pass the gasget(s). This way you need only one gasget.
coultervm 8 years ago
I just ordered a valve on amazon with a hand pump. It is usually used to keep whine fresh, but i got 4 "valves" and a small pump for around 10$. They are nearly identical to the ones used by Roarockit.
tim.nagy 9 years ago
solder (or weld) the washers together to make handling it all easier
DB.Cooper 10 years ago
great instructable, purpose driven, simple enough for anyone to do.
If I may ask, would this not be a port instead of a valve? And am I to assume that this is for a short term project use - such as vacuum forming, or impregnating a fluid in a material such as with carbon fiber?
Would it be possible to create a valve by cutting an extra piece of rubber that opens during the draw out, but closes against the other washer to generate a seal; such as one would find in a blacksmith's bellow's?
cpederkoff 10 years ago
You're absolutely right, it is a port instead of a valve. It should be called a vacuum connector or a vacuum port instead.
And you're right! It is for short-term project use like vacuum forming or vacuum bagging carbon fiber or fiberglass.
I haven't given the rubber seal much thought. The trick is that the flap would need to be on the outside, not the inside to let air go the right way.
vincent7520 11 years ago
how air isn't sucked in through the valve ?
Does it has a flap inside or something ?
The hose connector is hollow, no ?…
Don't get the idea at all !…
sorry…
cpederkoff 11 years ago
Thans for posting.
gomibakou 11 years ago
//////////// <---- neoprene washer
----------------- <- plastic
It should help for a better tighting...
Mindmapper1 11 years ago
Though that doesn't fix the problem of air flooding back in when I remove the hose. I just leave the hose on and maintaining the vacuum for as long as I need it and then remove the hose.
