10x5 RGB LED Matrix With Only 5 IO Pins
9,358
55
7
Introduction: 10x5 RGB LED Matrix With Only 5 IO Pins
About: Hello, it's me, Ole! I'm from Germany and my interests are Hardware Hacking, LEDs and many more! I will show you instructions of my projects and of other things, if you like them then just follow me!
If you wanna build a fancy led matrix display with only a few pixels, this is exactly what YOU need!
Step 1: Get All What You Need!
You need:
-An Arduino
-WS2812(B) LED strip
-A piece wood
-7 jumper wires
-7 female pin headers
-some capacitors
-some wires
Step 2: Craft It to One Part
Use your crafting tools to bind the led's onto a base (something like a piece of wood or something else of your favor). Arrange them in a matrix of a size like 5 by 10 Led's.
I added on every second line an capacitor, because the LED's need much power. And I don't put the data out to the data in of an other line, because I wanna drive them parallel on 5 IO pins.
Put the first line's data IN to D10 of the Arduino, put the second to D9, the third to D8, the fourth to D7 and the fifth to D6!
Step 3: Flash the Software to Your Arduino
This is the software which you need:
-Arduino
-Processing
Flash the software to your Arduino and open the processing project with... Processing! Now you should change the line "String portName = "/dev/ttyACM~";" to your Serial port, on WINDOWS "String portName = "COM~";"
Step 4: LOOK to This Stuff
Thank you for reading :)
Be the First to Share
    • Retro Tech Challenge
    • 3D Printed Student Design Challenge
    • Space Contest
      Space Contest
    7 Comments
    PhilipK8
    PhilipK8
    6 years ago on Introduction
    its been some years since i fired up my arduino uno - and this is the project that will get me to do it - i know the inputs are simple for leds -but can you supply a wiring diagram (common cathode/anode, capacitor type and polarity etc)
    NEHAK8
    NEHAK8
    Nice project !!!! (y)
    can you upload more clear picture of how to make the connection?
    its my 1st project... so please can you?
    drj113
    drj113
    Are you able to share a non-rar version of the code?
    Ole_L
    Ole_L
    Reply 6 years ago on Introduction
    What would you have? .zip or .tar.gz?
    starwriter34
    starwriter34
    WS2812's are addressable and this could have been done with one pin running the data for the whole thing. Was there a reason you split it up into 5 data pins?
    elias.alberto
    elias.alberto
    What about latency? Driving 50 leds serially would certainly add some latency, which could be an issue. Would it even be noticeable? I have no idea about the delay of those things
    balrog-k1n
    balrog-k1n
    That's true, it would be noticeable in a Persistence of Vision type project but probably not here. Secondly I believe no one has figured out driving 5 LED strips simultaneously using an Atmega328 yet, but there's a library that can drive 4 of them at https://github.com/balrog-kun/ws2811-multi, which I use for a POV display.
