12V Battery Charger DIY
Intro: 12V Battery Charger DIY
What is a Battery Charger?
A Battery charger is a simple electronic device that is used to force energy into a secondary cell or battery by pushing an electrical current through it. They are relatively inexpensive & easy to build at home. So, in this article, we are going to go over a step by step instruction on How to Make A 12V Battery Charger. So let’s get into it. They are many variations of battery chargers available in today’s market such as Pulse chargers, Trickle Chargers & fast chargers, etc. But generally, all chargers follow the same schematic scheme. A Step-down transformer along with an X-rated Capacitor connected in series to lower the high input AC to a usable level & a bridge rectifier to convert the AC signal into a rippling DC. You can also use a smoothing capacitor to the output of the rectifier to get rid of any noise.
We extend our heartfelt gratitude towards JLCPCB for sponsoring projects on this website & Youtube Channel. JLCPCB is the Best PCB Prototype Assembly & Manufacturing Company in China. Situated in Hangzhou, JLCPCB caters to all of your PCB design needs, offering the best service you will ever experience in terms of Design Quality, Pre & Post sales support & Fast Delivery time.
We at Circuits-Diy strongly recommend ordering PCBs from AllPCB. Simply, signup for a new account on the AllPCB website, fill in your board’s physical parameters & upload the Gerber File. It’s as simple as that!. Get an Instant PCB quote by visiting their website today!.
STEP 1: Hardware Components
STEP 2: Step by Step Tutorial...
1) Make a Bridge rectifier by connecting 4 1N4007 Diodes in the following configuration.
2) Solder the +ve & -ve Terminals of the bridge rectifier to the secondary winding of the Non-C.T Transformer
3) Trim excess leads of the bridge rectifier.
4) Solder one end of the X-rated capacitor to the +ve terminal of the AC supply & other to the primary of the transformer. Solder the -ve terminal of the supply to the primary of the transformer.
5) Solder alligator clips to the terminals of the bridge rectifier.
6) Connect the output terminals of the charger to the terminals of the DC power jack & test the circuit.
To buy Custom PCBs and to get best deals, Go to JLPCB.com.
STEP 3: Output.
Battery Charging (Fuse Engaged)
Battery Not Charging (Fuse Disengaged)
Working Explanation
The working of this circuit is pretty simple. A 220V AC signal acts as the input for the charger circuit. this AC signal goes through a 1uF X-rated capacitor directly connected to the live AC line in order to drop the AC Voltage. The Output signal goes through a non-C.T stepdown transformer.
The output AC signal signal is then fed to a bridge rectifier circuit made by using four 1N4007 diodes. The DC output from the bridge rectifier is then used to charge any 12V lead acid battery using battery clips. Applications It is commonly used to charge 12V Lead Acid Batteries for emergency backup power.
To buy Custom PCBs and exciting deals, Go to JLPCB.com
