12v Powerbank - USB to 12v
23,630
68
5
Introduction: 12v Powerbank - USB to 12v
You only need 3 simple things
- A boost converter (This is the cheapest with voltmeter, the same i use)
http://www.ebay.com/itm/DC-DC-4-5-32V-to-5V-52V-XL...
- A USB Cable
- And is optional, but a estandar DC power plug is usefull
Then connect, adjust the output voltage to 12v and thats all :)
Step 1: Its Simple But Very Usefull
A lot of things works on 12v, and now you have a battery for all of them.
Look a example of how many things you can use it on the right of this image.
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    • Big and Small Contest
    5 Comments
    MatT104
    MatT104
    Question 5 years ago on Step 1
    Awesome hack indeed! Would that charge a Mavick air using the car charger? (12v i reckon but please double check) please let me know I'm desperately looking for a way to get charge while out in the field
    Cheers!
    jawadsahibzada
    jawadsahibzada
    6 years ago
    usb port provides very low current, 6v battery with much higher capacity is needed for that
    Yonatan24
    Yonatan24
    7 years ago on Introduction
    If the output voltage is always 12V why do you need a volt-meter?
    jawadsahibzada
    jawadsahibzada
    Reply 6 years ago
    because it's adjustable !!! output from 10-30v ....every time you adjust it, you don't have to use multimeter.
    kaddigart
    kaddigart
    The car ceiling fan rules...maybe a little impractical but very cool nonetheless.
