16-key Keypad Decoding With an AVR MCU
Intro: 16-key Keypad Decoding With an AVR MCU
This instructable will show you how to interface a 16-key keypad to your AVR microcontroller and read the key when a key is pressed. I'll introduce the keypad first, then the 74HC922 16-key decoder IC as a pin-saving mechanism, then finally how to take the data and massage it so that you get the correct number for the keypress.
A 16-key keypad can be a useful addition to any embedded project, possibly acting as a code input device for opening a door or as a general input to any project requiring the input of multiple values, like alarm circuits, games, puzzles, DTMF generators.
STEP 1: Equipment List
This instructable doesn't have (m)any expensive components if you already have an AVR setup. You can buy everything online, although I've found if you check your local electronic warehouse/shop (if you have one) you will be able to pick up everything considerably cheaper, though.
You'll need the following:
- AVR microcontroller and a programmer. Arduino, Bare Bones Kit, Freeduino, Boarduino, and all the other clones work just fine. Of course, your custom own ghetto setup will suffice too. Just for the record, the firmware was written for an ATmega328p, so it should run well on that class of AVR's and probably many others with little to no modification.
- Something to compile your code.
- A 16-key keypad. The leading outlets carry them but they can tend to be spendy, so maybe try Jameco.com or do a search for "16-key keypad" on google. It shouldn't run you more than $6-7
- Solderless breadboard
- hookupwire, soldering iron, wire cutters, etc
- 4 10k resistors
- 74C922 IC. This is a 16-key encoder. You can pick them up from mouser.com or digikey.com for around $5. I got a handful at my local electronics shop for $0.95 each.
- 2 x 0.1 uF tantalum capacitors. You can probably get away with ceramic if you have them already.
- DLO7135 Dot matrix LED. This is one SWEEET component. They sell for over $10-15 each online, but, again, I picked up 10 of these at my local electronics shop for $1.50 each.
- 8 pin right-angle header and matching female header for the keypad
STEP 2: Wire Up Your Keypad
Take your keypad an examine the bottom aspect for soldering pads. My keypad came in a package with hardly any information. Definitely no insert, just some markings on the cardboard outer part that described how the pins matched to columns. Well, that's really all we need, isn't it?
I first started by breaking an 8-piece section from a long male right angle breakaway header that I always like to keep lying around. This is totally optional. You can solder your wires directly to the pads if that suits you. The pictures below show the header soldered on.
If you soldered your wires directly to the board then you don't have to worry about making a cable for it. If you did attach a header, then mate it with the female 8-pin header (again, I just snipped off the right section from a long piece I had around). Solder your wires to it, maybe throw on some shrink tubing and call that part a day. Because I am a bone head and constantly worried that I'll hook up the wrong wires, i chose hookup wire of different colors and used the mnemonic for the visible spectrum ROYGBIV to choose my wire color from pin 1 to pin 8. I need help.
Got your keypad setup? Good, we'll connect it to our microcontroller and start reading keypresses.
STEP 3: Reading Keypresses on AVR
Ok, first thing you'll notice is that we're going to be sucking up 8 I/O ports for this bloody keypad. That's a lot of I/O. In the next steps I'll show you how you can reduce that to around four, maybe a couple more depending on how much control you want. But for now, we're going to hook this sucker right into eight free I/O ports of our AVR.
I chose PD[2..7] and PB[0..1] for my connections. Shy away from PD[0..1] if you want to use serial communication on your arduino or other clone. I also had problems with my pins floating, so i used four 10k resistors to pull down the column pins to ground. Your AVR probably has internal pull-ups, but the logic I had already come up with in my head didn't work well with that. You'll note that there's no pin or hookup for power to the keypad, unlike the binary thumbwheel switch I talked about in a previous instructable.
Here's the basic idea. Pull the four column pins down to 0V. Set those pins as input. Set your row pins as output with initial logic 0 values. Loop through each row, sending a logic 1 to the row and read the column pins. If there is a one in there, then you have a keypress. Also of note is the issue of key debounce. Through experimentation I found a workable delay rate, otherwise you'll get many many keypress notifications for each single keypress. Depending on the speed of your MCU, you may have to tweek it a little, too.
I've attached a file at the bottom that I wrote for this section to demonstrate direct connection and reading of the keypad. If you choose to use it you will have to modify it as I reference libraries that I wrote for serial communication. Other than that, I think it should be generally fine. Here's pseudo code to show the flow:
N.B. The numbers are their logical numbers from 0 to 15, not the actual number on the key that was pressed. To do this, you need to either add more logic in your "number pressed is ..." section, or map it to an array, which is just a couple of steps away. First, let's see how to reduce the number of I/O pins this keypad is taking on our microcontroller.
ROWS set INPUT COLS set OUTPUT for (ever) { for each ROW from 0 to 3 { Set ROW HIGH if COL1 HIGH number pressed is ( 4 * ROW) else if COL2 HIGH number pressed is ( (4 * ROW) + 1) if COL3 HIGH number pressed is ( 4 * ROW) + 3) if COL4 HIGH number pressed is ( (4 * ROW) + 3) delay for debounce Set ROW LOW } }
STEP 4: Using 74C922 to Reduce I/O Requirements
The MM74C922N is a 16-key encoder that includes all the internals to take the output of a 16-key switch that we just saw from the previous step, and encode it onto only four outputs using a truth table. This is a boon, as it gives you more I/O to control or monitor other things without having to go buy a bigger (in the sense of more pinouts for I/O) microcontroller.
The 74C922 16-Key Encoder
From the datasheet, the MM74C922 can use an external clock for synchronous keypad scanning, has internal pull-ups, and has an internal debounce circuit! Both the scan rate and debounce time is configurable via an external clock or capacitor. It also keeps the last key pressed on the outputs even after they key has been depressed, in case your MCU has a moment and needs to retrieve the value again (at least before the next keypress). It also operates from 3V to 15V so it integrates well into TTL and CMOS designs.
The rows of the keypad are connected through its internal pull-up resistors when no key has been pressed. When a key is pressed the chip goes through it's debounce mechanism and when that times out, the encoded data is latched and the DA pin (Data Available) goes high. The DA pin stays high (logical 1) until the key is released, then it drops to a logical 0. There is also an OE pin (Output Enabled) which is the inverse of the DA pin.
The 74C922N pinout is shown in a schematic I've included below that only shows this IC. I've also included an Eagle schematic, although the keypad device's rows and columns made the circuit difficult to interpret, so I also include my hand written schematic that I made when I first started toying with the keypad and the 74C922. Hopefully one of those will clear up any connectivity issues, if you get any.
Build the Circuit
Put in your 74C922 into your breadboard, somewhere close but where you're not too cramped. If you're not familiar with IC's, take a moment to wonder at your new shiny chip and notice that the legs are splayed out when they come out of the factory. It can help getting it into the breadboard if you lay it on its side with its legs flat on the table, and with a gentle rolling motion slightly bend them inward. When placing your IC note that there is a stripe or divot on one side. That indicates where pin one is.
Connect the 0.1uF capacitors to pins 6 and 7 and take them to ground. See below. If you're using tantalum capacitors remember they're polarized so put the positive side (usually the longer leg) closest to the pin and the short leg in the ground terminal.
N.B.
You may have to play around with the capacitors for your setup. I've found 1uF on the oscillator and 10uF to 15uF (I had 3 in parallel) gives me the best responsive scan with the least debounce. Figuring it out for your setup can be fun.
Next connect your power components. At this stage I don't have my board powered. It's just easier to do these now than after you're connected all the inputs and outputs. Connect Vcc (top right pin) to 5V, the bottom left pin to ground, as well as the OE pin to ground. We won't be caring about it this time. See below.
Now connect your data outputs to your AVR. In the picture below I've connected Data Out (DO) A to PD2, DOB to PD3, DOC to PD4 and DOD to PD5. Now would be a good time to connect the Data Available pin (the one right below the OE you ran to ground on the right) to your microcontroller. I chose PD6. Nice contiguous block of I/O. If we could know that the same two numbers weren't entered consecutively we could leave off the Data Available and just poll the data out pins. That would reduce our previously needed eight I/O lines to only four! For completeness, I'm including it because that's the pin I'll service with a pin change interrupt. It's nicer than polling and lets your computer do other stuff instead of wait in loops polling the pin state.
Finally, connect your input wires. The top left four pins go to rows one, two, three, and four. The two pins between the capacitor and ground on the bottom left connect to column four and three. On the other side, reading from the bottom right, the pins connect to column two and one. Mind the order! Connect your keypad if you made a cable for it and fire your microcontroller!
Build the Circuit
N.B.
STEP 5: Write, Upload, and Run Your AVR Code
In order to read your data when a key is pressed, we will create service routine that will handle reading the data inputs when data becomes available. The AVR will automatically tell us when data is available for reading if we ask it to (or command it to..I'm trying to be nice so I'm killed last by our soon-to-be Robot Overlords). This notification is called an interrupt and the AVR has several types. The one I'm going to write is called a "pin change interrupt." It interrupts the flow of your code and executes your handling routine when -- you guessed it -- there is logic level change on a pin you've asked to be watched.
Have you wondered yet how the 74C922 distills 8 bits of data into just four data lines? If you've read my other instructable you'd probably have figured it out. Well, maybe you've already figured it out. Once you've done one truth table you've done them all, right? :) The 8 pins from the keypad is encoded in binary using the four data pins. I've made a truth table for you.
If you're unclear what that means, take a look at my other instructables, or do a search for "truth table" or "binary logic" on your favorite search engine.
Code Logic
I'm not sure getting into the details of my code when it's available for you to download is appropriate, but I'll introduce a few things here, and if you're an old salt at this stuff you can skip past it, otherwise I hope I can teach you something.
Declarations
This section is pretty self-explanatory so I won't go into it any further except to draw attention to the local header files that I've included that you may or may not want to use or delete.
Initialization
There are two subsections to initialize in this program:
1. The USART system
2. The interrupt handling system
It's safe to remove the USART stuff if you remove all references to it and don't want to communicate via the USB cable or an external serial console via a max232 chip. Therefore, I won't include it below since it's out of scope of this guide.
Interrupt Service Handlers
This is the pin change interrupt handler. A few things to note:
1. It's very short
2. No functions are called within it
3. This interrupt will be called at any logic level change, so that means when Data Available goes HIGH (which we want) and when it goes low (which we don't care about).
4. A global flag is set and the interrupt handler returns to allow the main loop to handle the rest.
5. I'm using a general purpose I/O register below 0xFF space. This means access is very fast.
Main
All we have to do here is loop while checking if data is available to process. If it is, do our magic, set our flags and working registers to zero and return.
Code Logic
- Check for a global flag indicating data is ready to process
- When the Data Available pin changes to HIGH
- Read the data pins
- Set bits in a general purpose register below 0xFF
- Set "data available for processing" flag
- Process the data and do whatever we want with it
Declarations
#include "common.h"#include "uart.h"#include <avr/io.h>#include <util/delay.h>#include <avr/interrupt.h>#define DATA1 PIND2#define DATA2 PIND3#define DATA3 PIND4#define DATA4 PIND5#define DATA_AVAIL PIND6void Interrupt_init(void);volatile uint8_t bDataReady = 0;
Initialization
1. The USART system
voidInterrupt_init(void){ BSET(PCICR,PCIE2); // Enable Pin Change Interrupt 2 BSET(PCMSK2,PCINT22); // Enable PCINT22 (that's PD6) BSET(SREG,7); // Set I-bit in Status Register GPIOR0 = 0x00; // Using General Purpose I/O register}
1. It's very short
ISR(PCINT2_vect){ if (BCHK(PIND,DATA_AVAIL) == 0) return; if (BCHK(PIND,DATA1)) BSET(GPIOR0,GPIOR00); if (BCHK(PIND,DATA2)) BSET(GPIOR0,GPIOR01); if (BCHK(PIND,DATA3)) BSET(GPIOR0,GPIOR02); if (BCHK(PIND,DATA4)) BSET(GPIOR0,GPIOR03); bDataReady = 1;}
Main
int main(){ // Initialize serial subsystem USART_init(BAUD_9600); // Initialize PCI2 Interrupt_init(); uint8_t encoded = 0x00; for (;;) { if (bDataReady) { encoded = GPIOR0; USART_tx(encoded); bDataReady = 0; GPIOR0 = 0x00; } }}
STEP 6: Visualizing Output With a Dotmatrix LED
Ok, so I found the coolest flipping LED's I've ever seen. They're single container Dotmatrix LED's, or formally Siemens High Efficiency Red DLO7135 5x7 Dot Matrix Intelligent Display withMemory/Decoder/Driver. Um, wow? They're less than an inch in width and height but pack 5x7 led matrix inside that contains onboard memory, a 96 character ASCII set, built-in character generator, intensity control, and runs off of 5V.
These things are $17 at mouser.com and $14 at digikey.com each. Yeah, EACH! Well, as luck would have it, my local electronic shop had a pull-out bin full of them selling for $1.50 a piece. Needless to say, I came home with a pocketful of LEDs, I'm sure making people wonder if I was happy to see them or if I had a lightbright in my pocket. Anyway, I digress...
So, the idea here would be to further connect our keypad, encoder, MCU up to this dotmatrix LED and have it display the number that is pressed on the keypad. This is pretty straight forward, but as I'd like to keep this instructable fairly short, and since I'd like to entice you to read more of my 'ibles, I'll just leave you with a few pics below and tempt you to read my guide on how to use this LED with a microcontroller in your projects.
STEP 7: Finalizing It All
In this instructable you learned how a keypad is read, directly connected to your microcontroller, and also through a 16-key encoding IC. I showed you how to reduce the I/O burden on your MCU through the use of the chip, and gave several code examples (and the code itself) for you to try out and practice at home (or work, or wherever you're reading this).
I hope you enjoyed it! You are always welcome to email me, or if you find yourself on irc, pop over to irc.freenode.net #instructables.
Keep on instructing!
-gian
-gian
9 Comments
vpontis 9 years ago
Where can I get the Eagle schematic?
nevdull 8 years ago
I didn't realize I only included a PDF of the schematic and not the eagle sch/brd. If you're still wanting them drop me an email and I'll look for them and send them to you.
Cheers!
mbroesby-olsen 12 years ago
The diagram shown above confuses more than it helps, as the IC is setup differently - at least the datasheet tells me this: Column X1 + X2 is NOT on the left side. Or in general: the layout of the IC is not comparable to the layout above.
Just a friendly reminder to others :)
nevdull 8 years ago
Heyas,
I think there is some confusion here. The diagram (technically, the schematic symbol I use for the 74C922 is only that: a schematic diagram. Just as a logic diagram does not map one-to-one with the physical pinout of the IC, many schematic symbols also choose to place the pins where it makes the most semantic difference and not how they are physically setup. This is done to help alleviate the rats nest some schematics become when attaching passives and such. The 555 timer is a great example; the physical pinout and the symbol are totally different and this is to allow engineers the ability to follow a common design pattern on the schematic that would otherwise be ugly and messy (as mine looks above).
Hope I understood your question and this helps to clear things up.
huubje 14 years ago
nevdull 14 years ago
Thanks. I've written it for an ATmega328P. You will need to edit the Makefile and change MCU to atmega88 and F_CPU to whatever speed at which you have your '88 running. You may need to change the AVRDUDE settings in the Makefile to reflect your programmer and port. Further, note which pins I have things on and either match those in your setup or change them in the code to match yours.
Also, if you're going to read the key value, you will need to make some sort of translation table or compare how the values are sent when checking a keycode. That's because the actual value of the key (ie 1 or 3 or B) doesn't get sent, but instead a number (hex) starting from 0 at key 1 and ending at F at key D. Make sense? The keypad values vs the value sent from a keypress is like this:
So you'll need to make sure you're translating/comparing the right maps.
Good luck!
arturmariojr 12 years ago
Could sell some to me?
nevdull 12 years ago
Good luck!
- cool name by the way! :)
I am starting out a project tomorrow, using the 74C922 IC.
Would it be possible to use this IC on a 12 keypad-setup?
And is it difficult to translate your code to arduino-readable code?
I really could like to use this IC, as I need as many I/O ports as possible.
