Introduction: $168 Building Fan Heater PC
A Building Heater Fan Case turned out to be a decent 9.5 liter layout PC, using 10 year old gaming parts. Here is how you can build one for $168. Its quiet and cool. Maybe because it was built for airflow from the start.
Philips screwdriver, grinder, metal shears.
Step 1:
Since I recently became a dad for the second time, I have been playing around sometimes with old PC parts in the office room while the rest of my family is sleeping. Next to the pc case I was busy with was a building fan heater.
Step 2:
I started looking at the PC case, and then at the heater. The pc case was for larger ATX motherboards, while the heater looked like it could just about fit a smaller ITX motherboard, that measures 170 x 170 mm. I took out the fan inside only using a philips screwdriver, and found a second hand motherboard (MOBO), a processor (CPU), a CPU fan and RAM memory for $80 at an auction site, and a power unit (PSU) for $14. I made 4 holes in the side of the case and tried fitting the MOBO. The PSU I fitted in one of the old holes on the other side, just to see how everything fitted.
Step 3:
I used two nuts for each bolt to create a distance between the board and the side of the heater. This was because the board has a slot for an M2 hard drive on the back. I bought a used 512 GB M2 card for $30.
Step 4:
I started checking pc forums and read discussions about air flow. I thought, a fan heater is built to move air, so maybe it is not so bad? I took a piece of thin sheet metal that was left over from some car fixing, and cut a round 140 mm hole, to make an air intake for the front of the case.
Step 5:
I kept the grid from the fan heater, and bought a new 140 mm mesh filter for $4. I also found a second hand start button at an auction for $3. I made a hole and fit it and glued it tight with 2 component glue. I added the mesh filter with screws, and spray painted everything black to fit the original fan colours.
Step 6:
For the back plate I put white paper over the back of the case and shadowed softly with a pencil, to get the shapes that I had to cut out. I took the same thin garage sheet metal I used in the front.
Step 7:
I found a cheap 4 GB graphic card (GPU), that was missing the metal plate that holds it in place. I took another plate from a network adapter I had lying around and cut a bit with a metal shears and drilled holes to fit it. It didnt look so nice but it worked. The motherboard is also missing the I O plate or backplate. It would have looked better with one, but it being missing I think it was one of the reasons I got it so cheap.
Step 8:
The only thing I bought new for this project apart from the mesh filter for the front is the $20 Noctua 60mm fan I put in the back. Can you see how tight it is between the PSU and the MOBO? I started understanding how people building small computers feel.
Step 9:
I added a manual barbecue thermometer from the kitchen, by drilling a hole in the front. After using 3 different dimension drills It fit so well, that I didn´t even have to glue it.
Step 10:
Look how small it looks next to the other PC:s. The one to the left is 15 liter, the one in the middle is 26 liter and the Building Fan Heater only 9.5 Liter, with its handy cubic shape and a handle on top. I hope you get inspired and can find a Fan Heater close to you.
Specs:
MOBO: MSI H 270I Gaming PRO AC
CPU: Intel Core i3 6100
GPU: Nvidia GTX 745 4 GB OEM
RAM: DDR4 16 GB 2400 MHz
PSU: Corsair CX 430
Prices of components:
Motherboard, RAM, CPU, CPU cooler: $ 80
PSU: $ 14
M.2 512 GB Disk: $ 30
Mesh filter 140 mm: $ 4
Start button: $ 3
Exhaust fan: $ 20
4 GB Graphic card: 17
Total: $ 168
