2008 Chrysler Sebring Transmission Fix
Intro: 2008 Chrysler Sebring Transmission Fix
So I’m at work all day and 5pm comes around, I grab my stuff and head out to the car. I get in, start it up and go to shift it out of park, but the shifter won’t move. I check the obvious, break is fully depressed and the brake lights come on, but no shifting. So I pull out the owner’s manual, and try the ‘manual override’ instructions for the transaxle. This consists of removing the rubber insert from the cup holder and reaching through a little hole to push a lever. No joy.
STEP 1: Initial Troubleshooting
I pull the chrome trim piece from around the shift lever and look inside through the gap. I notice that the plastic part that I pushed for the ‘manual override’ is pink. There is another pink plastic piece on the other (left) side of the shifter that moves when I try to shift. I grab a screwdriver and pull this toward the rear while shifting. Whew, got it. That let me drive home, but I don’t want to shift with a screwdriver, so I’ll need to fix this.
STEP 2: Disassembly
After I get home, I pull the center console out to get a better look at the problem. First I need to pull the a/c control bezel out so I can get to the screws behind it. The bottom of the panel pulls out, and then you need to pull the unit down to pull the top side out. Remove the cable connectors. Remove six 10mm screws. Two are behind the a/c bezel, and four are in the center console armrest compartment.
STEP 3: Diagnosis
With the console out of the way, I notice that the plastic part on the left side of the shifter is attached to a cable, which pulls it forward when the key isn’t in the ‘on’ position. It goes slack when the key is ‘on’ but there is no spring to pull the plastic piece back out of the way. I find a place where something has broken off, but I don’t find a spring or the broken piece. This is when I decide to improve their system so this doesn’t happen again.
STEP 4: Repair
I had to get a replacement spring, so I went to the parts store and bought the smallest throttle return spring I could find. It was a bit too long, so I cut it down to one inch total length. Then I drilled a hole in the pink plastic part and hooked the spring between it and the spring hold down hook on the shifter housing. After testing that it worked as needed, I put the console back together. Total repair cost, $3.00 and one hour of work for a solution that is better than new. The price for a replacement shift housing at the dealership, $142.00 plus installation, probably at least $300.00 all together.
STEP 5: Factory Recall Notice...
I received a recall notice for my car from Chrysler today, outlining exactly the issue I created this instructable for. I won't be taking my car in since it's already fixed, but if you have this problem and need to take it in, they'll probably fix it for free. They stay that they'll install a "reinforcement clip" to keep your spring retainer hook from breaking.
Good Luck,
Dan
39 Comments
samantha.g.campbell 9 years ago
THANK YOU THANK YOU THANK YOU! I was able to easily figure this out and get home safely. Along with calling the dealership and having them fix it for free. THANK YOU!!!
dan.hipp 9 years ago
Dan
CliffE2 8 years ago
Thanks for the instructions. I was able to remove the A/C bezel with no problem, as well as the six 10mm screws. However, in no way will that console come off. No matter which way it is pulled, pushed, or twisted, it simply will not clear the parking brake handle. The parking brake is full on, but that handle would probably need to move another 30º towards vertical before the console will clear it. Maybe a hacksaw is needed? Can't find any useful information on this anywhere. HELP!
dan.hipp 8 years ago
Sorry to hear that you're having issues Cliff. It's been awhile, so I can't remember if I had any difficulties getting the console off from around the brake handle. Look around to see if anything is still connected, and try wiggling it. Hopefully it's just caught on something. If all else fails, push the broken pink retainer to the rear (picture 2), and drive it to the dealer. It's a recall issue, so they'll fix it for free.
KentC20 5 years ago
CliffE2 8 years ago
Dan: Thanks so much for your reply! I did finally succeed at the repair. The black plastic brace which attaches the front of the console to the dash with the 2 10mm screws had to also be detached from both sides of the console. A torx screw must be removed at each end, and the brace unclipped from the console sides. Also, one more set of wires must be unplugged. Removal of the brace allows the console sides to be splayed out to the sides of the hump as the front of the console is pushed down. Then Voila! The rear of the console will (barely) clear the parking brake handle. After that the repair was by-the-book, and everything went together fine. Found the old spring too, so my total cost was $0.00. BTW, Chrysler did confirm that the dealer would have taken care of the repair on the house. Would have been easier. THANKS AGAIN!!!
KentC20 5 years ago
Thanks!!!
daddydon 7 years ago
Computer read out said my transmission module was bad changed that and car still want change gears. Car takes off fine but at 40 it drops back down to 20 and want idle any higher. What do I check now
LydiaS1 8 years ago
deborah.matthews.16718 9 years ago
How did you get the center console off. I think i lost a credit card back in there!
The pictures and instructions in step two should guide you toward removing your console. The bolts are under the AC control bezel. Hope you find your card!
dward10 12 years ago
omckinley ramirez 12 years ago
ebony givens 13 years ago
DAV706 13 years ago
russhoss 13 years ago
csilva422 13 years ago
dan.hipp 13 years ago
Thanks for the info. Hopefully anyone who is about to have this problem will take their car in to the shop for the free fix. I posted my recall notice as a late entry to this instructable, it's on page 5.
Cheers.
torres1929 13 years ago
lilmrph 13 years ago
