Introduction: 20ft Wooden Binder Clip Bow
Step 1: Gather Materials
a piece of flexible softwood about 13in. long (small shrub limbs work great)
a sharp knife that u can use to debark the wood
a rubber band about quarter the length as ur wood (you will cut band in half)
around 16 small binder clips (i used 16 for a 12in. bow)
BBQ skewers (opt. you can shoot pencils or something else but skewers work best for arrows)
duct tape
ruler at least 12 in.
Step 2: Starting With the Wood
use your knife to remove all of the bark from the wood
IMPORTANT clip a binder clip around your wood, if it fits firmly take it off, if the wood is too big to clip it on or to small for the clip too hold you need to get another piece of wood
now skin all of the bark off of the wood
smooth out any serious knots so the wood is relatively smooth
put down ur knife and go to the next step
Step 3: Soaking the Wood
find a rock or something that doesn't float that is relatively big
put ur wood in the sink and it will magically float!!!!!!!!!!!!!!!!!!!!!!!!!
this is when u put the rock on it to hold it under water
(if ur sink isnt big enough u can use a bathtub)
leave it there fur about 30 min. tick tock tick tock.............................
Step 4: Bending the Wood
this looks hard but its pretty easy
take the ruler and the duct tape and make a contraption like the one below
look at the picture carefully i have confidence in you
if this is too hard fur u to make u can make ur own contraption to bend the wood
leave it like so for AT LEAST 12 HOURS
do this before you go to sleep so u aren't anxiously waiting all day!
Step 5: Installing the Band
i know its hard to get all the tape off but youll find a way
now cut slits about a millimeter deep in each end of thebow lengthwise (as if trying to split wood in half)
insert the band in between the slits and tape each end there
Step 6: The Arrow Rest
remove the handle on the clip that is facing AWAY from you
later u will slide an arrow thru here
Step 7: The Clip Shell
hold the bow in the proper position,
attach the clips facing toward you NOT AWAY FROM YOU
remove all of the handles on these binder clips
Step 8: Ur Done!
happy hunting
WARNING: if u are using BBQ skewers as arrows DO NOT SHOOT AT OTHER PEOPLE
those things are sharp and if you are truly robin hood they will probably pierce open skin
another helpful hint
if projectiles do not fly straight, wrap a bit of duct tape around the end of the arrows
this will provide a more stable flight
-a message from
owner and operator of V-Works ltd.
-Sean
