.223 Survival Whistle
Intro: .223 Survival Whistle
Because yelling will make you lose your voice, it’s important to carry a whistle just incase you get in a jam. For example: When I went mountain biking with a group of friends I crashed plenty of times. Luckily, none were serious. However, if I had a bad crash, I would of had to wait until someone pedaled back to me. Unless that is, I could signal them somehow.
To signal for help with a whistle you sound three blasts. Do this in a consistent interval until help comes. The plus side to this whistle is you’ll have a conversation starter when help finally comes.
STEP 1: File Out a Notch
Before you start, clean out the brass with dish soap and cotton swabs. Clean inside and out until the swabs come out completely white.
Grip the shell in a clamp. Make sure to clamp the primer side of the shell or it will collapse. Also if you don’t have a wooded clamp you can improvise to protect from scratching up the brass with something like an old leather belt.
Using a ¼” triangle file, file a notch ¼” down from the taper line on the shell. Make sure to keep the leading edge of the file at 90 degrees. See the pictures. Keep filing until the trail edge of the file is flush with the shell wall.
Remove any burs.
Remove any burs.
STEP 2: Prep the .22 Shell
Use a pair of diagonal cutting pliers to remove the primer side of the .22 shell. Next take a scrap piece of brass from another shell and solder it halfway onto the business side of shell. See the pictures.
Use metal shears to cut off the excess. Smooth out any rough edges with a hobby file.
STEP 3: Place the Prepped .22 Shell
Insert the half covered side of the .22 shell into the opening of the .223 shell. For best results you have to make two things sure.
One: the end of the .22 shell lines up with the notch cut in the shell.
Two: the opening of the .22 shell is parallel to the notch cut out in the .223 shell.
Solder the .22 shell in place. Be careful not to over do the heat or you might melt the solder away from the half cover.
File the blowing end flush with a hobby file. Next use a polishing wheel with polishing compound to buff the whistle to a shine.
STEP 4: Tie It Off
Take a section of nylon cord and melt the ends together side by side. Place the melted end against the shell and secure it with a constrictor knot. Another option is to drill small holes at at the primer end and fit a paper clip to make a keychain. Sort of like I did on my keep sake pendant instructable.
Thanks for reading.
Thanks for reading.
115 Comments
SurenO1 7 years ago
Would a 30-06 Springfield with a 9mm inserted inside the 30-06 work?
NoahPlayz 5 years ago
a 9mm brass would be too large to fir in the neck of a 30-06 casing. maybe a .45 caliber rifle brass and a 45 acp
TECHYman3 7 years ago
I need on of these! We shoot guns, and we always have extra bullet shells. This is a good use for them!
Yonatan24 8 years ago
Nice, They look so easy to make!
GrowleyMonster 8 years ago
Mrballeng 8 years ago
bobbyflay2019 9 years ago
Will this work with a .243 cartrege
soul_eater 12 years ago
bennettcrew 12 years ago
There are some folks, on there, who sell empty brass for people to make craft projects with. I have some various types... but they're all bigger than .223
The good thing is that, on the website, you can get quite a few for just a few US Dollars. Pay through paypal, or other method, and have them shipped right to you.
sockless 12 years ago
SIRJAMES09 12 years ago
In America, if you want to own empty shell casings, it's not illegal...now if you have a few hundred thousand casings, that might cause a bobby to ask Questions, but it's still not illegal.
dc0de 12 years ago
As far as empty v/ loaded brass, I'll leave that for the thieves to guess which ones are loaded...
Just make sure you have some very hungry hogs near by....makes it easier to hide the bodies. j/k
ray.graham.9216 9 years ago
good one dude
southern boy 12 years ago
slamonella 9 years ago
If only that were true. In Massachusetts, you need a permit to own possess any ammunition components. I would not be shocked to hear that other states/cities had similar stupid laws.
really???? Damn thats messed up.
cmanningx 10 years ago
Not so.
In NZ you can buy/own shell casings, projectiles (bullets) and even gunpowder and primers WITHOUT a license. You can even buy/own reloading equipment.
You do however have to have a license to possess whole ammuniton, so it would be illegal to assemble loaded ammunition without a license.
Shell casings, straight up or made into whistles... no problems at all.
Hazara_nz 12 years ago
