2d to 3d Iphone Speakers
Intro: 2d to 3d Iphone Speakers
This project was made for a class in my Product design studies(which i am now finishing). the brief was to make a simple iphone speaker that anyone can make easiely enough.
i chose to use Autocad 123D Make to fabricate the speakers since a) its free b)its easy to use c)its cool
i wanted to try to make something that would seem intersting to make with laser cut wood. the shape was arbitrary, it could go to any direction - i choose to do a pod like\alien kinda shape speakers.
i first used solidworks to model the shape, and then inserted the STL file to the 123D Make software, buy you can use a variaty of free softwares to make the shape instead of solidworks.
for the electronics part i took some cheap old iphone speakers i had and used their electronics.
STEP 1: Materials and Tools
Materials:
Wood(if you laser cut it the laser cutting place will have their own)
iphone speakers to disassemble for the electronics(or build your own circuit? thats beyond my skills)
some spare cables - i had to recable the speakers conncetion one to the other
Tools:
Soldering iron
Solder(dah)
Glue - i used r21, it dries super fast! so be carefull, also with your fingers.
Laser cutter(or cut it yourself? :) )
STEP 2: Get All the Parts Together
Sort them by the numbering system(made automaticly with 123d Make) and figure out the correct way to glue them.
shouldnt be too hard
STEP 3: Start Glueing
glue the parts together, make sure to fit in the electronics.
BEFORE you glue make sure you soldered all the cables and such from the disassembled iphone speakers, you can also check they still work(be carefull plz)
STEP 4: Final Soldering and Checking
when it starts to look nearly done check all the wires are connected and not loose, and glue the final parts
STEP 5: Final Steps
STEP 6: And You Are Done!
brag to your friends and enjoy :)
7 Comments
thatguy900 8 years ago
could i ask what the ihpone speakers were that you disassembled to make this project
Dani78 9 years ago
looks nice,
could you upload the pdf file of the parts for inspiration?
NeIdan 9 years ago
hey man, i have it on dxf. if you have troubles opening it then i'll try converting it to pdf
cheers:)
Dani78 9 years ago
Thanks buddy,
I converted the file to pdf and it is attached .
priitm 9 years ago
Holy Jesus Christ these look SHCWEET... You have some artistic skills. Tho i hate (and always have) laser cut wood....
And please, dont upscale this...you will run into million different things about acoustics...
chefmichel 9 years ago
Congratulations, they look great.
I hope they sound as good as they look !
NeIdan 9 years ago
Thx! i should have used a better quality speakers for that:) but next ones will be better for sure!
