Introduction: 3 Beautiful Handmade Beaded and Copper Jwellery
SO , HI ALL HIYA HERE ITS BEEN A LONG TIME I HAVE NOT UPLOADED ANYTHING , SO TODAY I DECIDED TO SHOW OFF MY PASSION THAT IS JWELLERY OR YOU CAN SAY BEADING . I MAKE ALOT OFF JWELS AND SELL THEM . SO TODAY I WILL SHARE MY 3 EASY AND VERY BEAUTIFUL EARINGS DESIGNS WHICH ARE VERY EASY TOO MAKE ALSO .
SUPPLIES
1. CLOURFUL SEED BEADS
2. SEED BEAD NEEDLE
3. NYLON THREAD
4. JUMP RINGS
5. EARING HOOKS
6. COPPER WIRE
NOTHING ELSE !!!
Step 1: NO.1 COPPER COILED EARINGS
SUPPLIES YOU NEED ARE :
1. COPER WIRE
2. EARING ATTACHMENTS
3. ROUND NOSE PLIERS
HOW TO MAKE ?
SO THIS ONE IS VERY VERY EASY TO MAKE , WE JUST HAVE TO TAKE 35 CM OF WIRE AND START COILING IT WHEN ITS ALMOST 17.5 CMS LEFT THEN YOU JUST HAVE TO TAKE THE WIRE AND TAKE IT THROTH THE CENTER OF THE FIRST COIL AND GIVE SOME SPACE AND START COILING AGAIN . THEN AT END WHEN ITS DNE JUST TAKE A HAMMER OR ANYTHING HAVY AND TAP ON IT SEVERAL TIME TILL IT BECOME STRAIT AT LAST ATTACH A JWELLERY ATACHMENTS AND ITS DONE YOU CAN REFFER PICTURE ALSO .
PLEASE TRY
Step 2: NO.2 SEED BEADED BRAIDES
THINGS YOU NEED ARE
1. ANY TWO COLOURS OF SEED BEADS THE QUANTITY SHOULD BE 55 BEADS EACH
2. NAYLON THREAD
3. I USED 11 NO. NEEDLE IT DEPENDS YOU WHATS THE SZE OF YOUR THREAD
4. JWELERY ATACHMENTS
HOW TO MAKE ?
SO ITS ALSO VERY EASY TO BE MADE YOU JUST HAVE TO TAKE YOUR THREAD AND NEEDLE PICKED ,INSIDE THE NEEDLE . AFTER THAT ADD 55 SEED BEADS ,THEN MAKE A LOOP TAKE THE LEFT OVER THREAD THROUGH THE LAST BEAD AND MAKE A KNOW DO NOT CUT THE LEFT OVER THREAD . DO SAME WITH OTHER COLOUR AND DONT CUT BOTH THE NEEDLE AND THREADS . AFTER THAT JUST MAKE THE KNOT OF BOTH LOOPS TOGETHER THAT WHY I SAID TO NOT CT , BECAUSE IT CAN MAKE THE KNOT OF BOTH WHEN ITS DONE JUST TAKE ONE COLOUR FROM THE OTHER LIKE TAKE ONE COLOUR INSIDE FROM OTHER USE ONLY ONE COLOUR THEN AT LAST WHEN ITS TIGHT ENOUGH TAKE SOME MORE THREAD AND NEEDLE AND MAKE SURE TO DOUBLE IT THEN YOU CAMNSEEE IN THE PICTURE I HAVE FIRST TAKE THE 4 TH YELLOW BEAD AND FROM THAT TAKE THE NEEDLE FROM THE DOBLURED THREAD THEN TAKE TO OTHER SIDE 4TH BEAD THEN THE WILLBECOME MORE CLOSER THEY WILL LOOK LIKE A BRAID THENTAKE THE THREAD AND TAKE IT HROUGH THE OTHER COLOURED FOURTH BEAD AND REPEAT TILL THE END WHEN YOU ARE AT LAST LOOP JUST TAKE THROUH ITBAND TAKE OUT THE NEEDLE FROM THREAD TEN THEY WILL BECOME 2 THREADS AND MAKE A KNOT ATLEAST 4 TIMES TO MAKE IT TIGHT AFTER THAT , WITH A FIRE TOURCH OR ANY KIND OF FLAME JUST MELT THE END A LITTLE THAT IT TIGHT AND WITH A PLIER JUST PRESS IT , AND CUT FO THE OTHER .AT LAST JUST AD THE ATACHMENTS . DONEEEE!!
Step 3: NO.3 FLOWERS EARING
THING NEED
1. JWELLERY ATACHMENTS
2. SEED BEADS
3. THEAD AND NEEDLE DOUBLED
HOW TO MAKE ?
TO START OF YOU NEED A LONG THREAD WITH NEEEDLE THATIS DOUBLED , MAKE A HOOP OF 20 SEED BEADS , TO MAKE A HOOP ADD 20 BEADS THEN TAKE IT TO LAST THEE AT LAST THE DOUBLED WIRE BE THERE FROM THAT JUST TAKE IT AND KNOT IT TWICE . AFTER THAT ADD 4 OTHER COLOURED BEADS THEN AD 1 MORE OTHER COLOUR BEAD THEN ADD AGAIN THE SAME 4 COLOURED BEADS AND JUST TAKE IT THROUGH THE SECOND BEAD AS SHOWN IN THE PICTURE REAPET THIS PROCES TILL THE FLOWER IS MADE AFTER THAT WHEN ALL PETALS ARE DONE ADD 20 OTHER BEADS AS SHOWN IN PICTURE . WHEN YOU HAVE ADDED THE BEADS THEN LEAVE THE LAST BEADD AND TAKE THE THREAD FROM THE 19 TH BEAD , THAT IT DOSENT BREAK THAT WHY WE TOOK FROM 19TH BEAD TILL THE 1ST BEAD AFTER THAT TAKE OUT THE NEEDLE AND MAKE NOT 7 TIMES AND JUST MELT THE WIRE WITH A FIRE TORCH OR ANY FLAME . THEN PRESS IT WITH PLIERS AND CUT OFF EXTRA . WHEN ITS DONE FROM THE LAST BEAD ADD JUMP RING AND EAERING HOOK ADD FROM 20TH BEAD . DONE!!
