Introduction: 3 D Paper Snow Decoration
20 matching shapes are cut out and glued together to create a decorative SnowBall.
Step 1: Step 1 Supplies
Supplies:
Template printed on photocopy weight paper. File named spokes-5.png. (Originally in .svg but couldn't get it to upload)
Four sheets of card stock paper (110lb is best)
Scissors
Hole punch
Stapler
Glue stick
Optional:
Cutting knife and cutting mat to protect table.
Or electronic die cutter like the new Cricut Explore that is the grand prize for the paper craft contest.
Step 2: Step 2 Print Out 2 Copies of the Template.
Staple each template onto 2 sheets of card stock.
Do a rough cut and add more staples to keep the layers from shifting while cutting.
Step 3: Step 3 Cut “flake” Ends and Punch Hole at Base of Opening Located at End of Each “spoke”
Then use scissors or craft knife and mat, to cut hole to finished shape.
Step 4: Step 4 Finish Cutting Out the Shapes.
I tend to cut all the detail stuff at the spoke ends before removing the remainder of the paper.
Step 5: Step 5 Discard the Template.
Fold each shape at base of the 3 spokes.
And fold the “fringe" towards center of shape.
Step 6: Step 6 Spread Glue on Spoke (but NOT the Fringe)
Glue 2 pieces together 1 spoke back to back with another.
You will be assembling the first 5 pieces to form a pentagon shaped hole in center.
Step 7: Step 7. Continue Adding the Pieces, Being Careful to Form 5 Sided Holes
Photos are
the first 7 pieces assembled (view from inside/center)
first 10 assembled (view from inside/center)
first 10 outside view
Continue to add pieces being careful to have only pentagon shaped openings!
Attach a hanging cord and display proudly!
Papercraft Contest
6 Comments
9 years ago on Introduction
Thank you so much for sharing with us. Beautiful project which I can make with my kids.
Thank you everyone for your nice comments.
Wow...this is awesome. Thank you so much for sharing.
9 years ago
This is epic! Very good work!
Wow, amazing work!
Beautiful!
