Introduction: 3 Easy and Elegant Earings
So hi all , welcome back so today I with these new 3 toturials for earing lovers . Today I gonna share some of my elegant and very easy earing ideas with you all , they all aren't very time taking . So let's start .
Have fun !!!!
Have fun !!!!
So I used these materials to make these 3 earings :
1. Jwellery attachments ( earing hooks and jump rings )
2.big beads
3. Small beads ( that much thick that they can easily fit to a copper wire)
4. Jwellery pliers
5. Leaf blades and some jwellery stones( leaf blades are available in every craft shop and jwelley stones make sure there are HOLES in them )
6. Copper wire
7. Chain
2.big beads
4. Jwellery pliers
6. Copper wire
7. Chain
Step 1: 1st Is the Chain One
Things u need
1. Eye pins
2. Earing attachment
3. Pliers
4. Cutters
5. Big beads
That's all
So first cut 4 equal lenth chain depends on u , how much long u want . After cuting take 1 eyepin and through that add a big bead then with rond nose pliers make a loop at both sides to lock it one side is allready there so do it on other side only . Atach your 1 chain at left and other on right with the loops u made on top atche both the chains with a jump ring and add a earing hook.
Do same with other . Alll done !!!!!
1. Eye pins
3. Pliers
4. Cutters
5. Big beads
That's all
Step 2: 2 Nd Is the Stones One:
Supplies are
1. Stones with holes
2. Leaf shaped with holes
3. Some thread or fishing wire
4. Fabric glue
5. Earing attachment
So let's start , on your thread double it little longer add a jump ring and hook . That your stone don't go pass through it . Then from that hole my stone had two holes one at starting onther at bottom so what I did is I took my dobled thread and took it from the first one then I took it from bottom one for locking the stone I took my thread from down side of my stomne then again it got locked repeat this till you want desired lenth I did it with four stones . Then I took my leaf one and took it from that and then made a thick tight knot that it dosent open . Then at last take fabric glue apply it to the other side of the stones and stick. The stones that it looks just the same from both sides. Do the same for for the other earing . It's done!!!!!!!!!
4. Fabric glue
Step 3: 3 Rd One It the Copper Wire One
Materials you need are :
1. Copper wire
2. Beads
3. Earing attachment
Let's start , make two hoopes with your copper wire , same size then make small hoopes than the big one . So in total you have 4 hoopes . Add 20 beads to bigg one both add 15 beads to small one . Make looped at the end of both the hoopes the earing attachment pass through them make a tight hoopes with small one . Make a loop and join them both with hooks and jump rings.done
1. Copper wire
2. Beads
