3 Ingredient SILVER Cleaner
Intro: 3 Ingredient SILVER Cleaner
I had tried a silver cleaner some moths ago, it used lemon and you had to let it sit for 30 minutes.. well the worst part was that after that long process my silver jewelry ended up almost as stained as the beginning. I was NOT happy. I then tried this process and it was easy and super fast! I had never imagined I could use salt to make my silver earrings look shiny again!
STEP 1: Just 3 Ingredients!
The best part about this cleaner is that you'll use things you already have in your kitchen:
1 teaspoon of salt
1 teaspoon of baking soda
1/3 cup of warm water (not hot)
Additional things:
Alluminum foil
Little bowl
Spoon
Napkin
And of course the silver object you're going to clean.
STEP 2: Cover the Bowl
Cut a square of the aluminum foil to put inside the bowl.
STEP 3: 3 Ingredients
Put the baking soda, salt and water inside the bowl and stir gently with the back of the spoon.
STEP 4: Time to Clean!
Put the object inside and rub it with your fingers against the aluminum foil. If it's a large piece you can use the sides of the aluminum foil to rub all the edges of the object.
STEP 5: Rinse
Rinse it with water (any temperature) and dry it with a napkin.
STEP 6: Before and After
The whole process just took about 7 minutes and you can see the amazing difference! In this instuctable I show you how to make a nice earring organizer from a frame.
Try it with necklaces, rings and even silverware.
Hope you enjoy it as much as I did. Follow me fore more cool DIYs and beauty tips.
