Soda to Slushy Conversion
Intro: Soda to Slushy Conversion
In this instructable I will show you how to make an insta-slushy that can go from soda to slushy in under three minutes. This project is easy to make( a five year old could do this easily. That being said, always perform with adult supervision ) and only requires a soda of choice and a working freezer.
STEP 1: Build Pressure
The first step is to shake the soda bottle for around thirty seconds( or until the layer of foam is roughly a centimeter thick) . Put the result in the freezer.
Obviously, it is important to be careful when handling the pressurized bottle. Use a new bottle, and be wary of leaks if you do not want an unexpected visit to a dry cleaner
STEP 2: Making the Slushy
After 3 to 4 hrs in the freezer, the drink should be near 0 degrees celsius, but not actually frozen. Release the pressure and tighten the cap. The soda in the bottle can now easily freeze with a light tap. This frees air bubbles in the drink, which the water molecules form around, making ice. If not all of the drink freezes, turn the bottle upside down to freeze the rest. You now have a nice slushy. Enjoy the slushy and recycle the bottle.
Favorite this instructable and leave comments if you liked it. Also leave suggestions on how to make this more AWESOME.check out my other instructables and enjoy your new-found favorite beverage.
4 Comments
Chris Logan 9 years ago
Was sorely disappointed by the last step.
lazyboy395 9 years ago
suppose you used dry ice instead of a regular freezer, then you could probably get the three minute result
sorry about that. I was referring to the actual forming of the slushy. i corrected the title now.
the ultimate smaug 9 years ago
