30V-4A Low Noise Adjustable Power Supply (CC-CV)
Introduction: 30V-4A Low Noise Adjustable Power Supply (CC-CV)
Power supplies are one of the most popular topics in electronics. There are two major types of regulated power supply: linear and switching. Both power supply types introduce some advantages and disadvantages, however, a linear power supply offers better line and load regulation figures and it handles lower noise at the output, specifically when the power supply is adjustable and the output is under load; although its efficiency is lower than a switching power supply. In this article/video, I introduced an adjustable 30V-4A linear power supply that provides constant voltage and constant current adjustment. The output noise of the power supply is low and has measured using the power analysis feature of the Siglent SDS2102X Plus oscilloscope. All component packages are through-hole, so you don’t need any special tool for soldering. Let’s get started!
Note: This is the first prototype, as I mentioned in the video, in the last revision of the PCB board (which is available for you), the distance between electrolytic capacitors and the power resistors has been increased, however, if you still have concerns about this, you can use 470uF-50V capacitors instead of 1000uf-50V capacitors which are smaller in diameter.
Step 1: A Complementary Video of Test, Operation, and Tips ...
Specifications
  • Input Voltage (max): 35V [30V, max-tested]
  • Output Voltage (min): 1.28V
  • Output Voltage (max-tested): 27.35V [28.9Vin, no load, 25C]
  • Output Current: 1.1mA to 4A(max continous)
  • Output Noise (no load): 6-7mVpp
  • Output Noise (1A load): 6-7mVpp
  • Output Noise (2A load): 8-10mVpp
A: Circuit Analysis
Figure 1 shows the schematic diagram of the device. The design consists of two main parts: the main regulator circuit and the current limiting circuit.
Step 2: Figure 1 Schematic Diagram of the Adjustable Power Supply
P3 is the KF128-4Pin block terminal to connect the input and output wires to the circuit. C4, C5, and C6 are used to reduce input noise. D1 and D2 are protective diodes. Schottky diodes can be used instead of D1 and D2 as well.
IC3 is the LM338 5A positive linear regulator [1]. R3 provides an output feedback path to the regulator and P2 is a 5K multiturn potentiometer that is used to adjust the output voltage. C7 capacitor has been used to reduce noise. C9, C10, and C11 have been used to reduce output noise, however, they are connected to another ground reference that is the Drain pin of Q1.
Q1 is the IRLZ44 N-Channel Mosfet [2] that limits the current with the help of IC1. The theory behind how the combination IC1 and Q1 does the current limiting is a bit complex and it will be explained in a video in the future. IC1 is the LM358 famous operational amplifier [3]. R2 is the load resistor that consists of three 3.3R-10W resistors in parallel, which is equal to a 30W-1.1R resistor.
C3 and R1 build an RC filter that reduces the noises coming from the load resistor. C1 and C2 are also used to reduce noise. IC2 is a 78L09 regulator [4] that is used to provide a stable supply rail for the IC1. C8 has been used to reduce the output noise of the IC2. P1 is a 5K multiturn potentiometer that is used the set the current limit. Finally, R4 is a basic load resistor that draws a few milliamperes of current to stabilize the output of the power supply under no load.
B. PCB Layout
Figure 2 shows the last revision of the PCB layout. It’s a two layers PCB board and all component packages are through-hole. Pretty easy to solder for most users. The thickness of high current carrying tracks is 4.5mm. You should mount three 3.3R-10W resistors on top of each other to build R2, so R2 is a parallel resistor of three 3.3R-10W resistors, that is equal to a 1.1R-30W resistor.
Step 3: Figure 2 PCB Layout of the Adjustable Power Supply Circuit (last Revision)
The component libraries of a few components were not available in my component libraries storage. So as usual, I used the SamacSys component libraries and installed the missing libraries (schematic symbols, PCB footprint, 3D model) for the IC1[5], IC2[6], IC3[7], and Q1[8]. You have two options to install and use the component libraries. You can either visit the componentsearchengine.com, download and import the libraries in your CAD software or you can use the SamacSys CAD plugins (figure 3). Almost all known electronic designing CAD software are supported [9]. I used Altium Designer, so I installed the component libraries using the Altium plugin [10] (figure 4).
Step 4: Figure 3 All Supported Electronic Designing CAD Software by the SamacSys Plugins
Step 5: Figure 4 Selected Component Libraries in the SamacSys Altium Plugin
Figure 5 shows the assembled PCB board. The PCBs have been fabricated by the PCBWay in good quality. I did not have any problem with soldering the components at all. The quality of the PCB copper, silkscreen, and solder mask is very good.
Step 6: Figure 5 Assembled PCB Board of the Power Supply Circuit
C. Test and Measurement
You can find more information about the voltage and current testing in the video, however, I put some test results about the output noise here as well. These tests have been performed using the Siglent SDS2102X Plus oscilloscope [11].
This oscilloscope introduced a handy feature named “power analysis” that allows the user to perform a variety of tests on power supplies. I’ve used the “output ripple” feature of the “power analysis” option.
Figure 6 shows the output noise under no load. Figure 7 shows the output noise under a 1A load and figure 8 shows the output noise under a 2A load. This circuit can deliver up to 4A continuously, however, please use big heatsinks and prepare good ventilation.
Step 7: Figure 6 the Output Noise Figure of the Power Supply Under No Load
Step 8: Figure 7 the Output Noise of the Power Supply Under a 1A Load
Step 9: Figure 8 the Output Noise of the Power Supply Under a 2A Load
D. Bill of Materials
Figure 9 shows the bill of materials. Two 5K multiturn potentiometers must be attached to the board using two 3-Pins XH connectors.
Step 10: Figure 9 Bill of Materials of the Adjustable Power Supply Project
Be the First to Share
    • Origami Speed Challenge
    • Science Fair Challenge
    • Tinkercad to Fusion 360 Challenge
    10 Comments
    mfortea
    mfortea
    1 year ago
    Hello. All mouser links seems to be broken
    sam_moshiri
    sam_moshiri
    Reply 1 year ago
    I should really appreciate you for informing me, I don't know why the editor had changed the links like this. So weird. anyway I fixed them all. Just two of them belong to the mouser which refer to the datasheets.
    throbscottle
    throbscottle
    1 year ago
    It's really nice to see a PSU project that actually has some circuit design and doesn't just follow the format of "buy these modules, connect them like this, make nice case". Very refreshing!
    sam_moshiri
    sam_moshiri
    Reply 1 year ago
    Thank, you can subscribe to my channel, there are other designs which will show up soon
    scirx
    scirx
    1 year ago
    Very impressed by the noise parameters. Very quiet and consistent.
    sam_moshiri
    sam_moshiri
    Reply 1 year ago
    Thanks, go for it and build one
    RomasP
    RomasP
    1 year ago
    I'm just curious how will look like noise in current limiting mode? Please check this. I think it can be terrible due to fact opamp is connected as infinite gain mode amplifier - comparator.
    sam_moshiri
    sam_moshiri
    Reply 1 year ago
    Good question, actually if it shows some noise when it goes to CC, then what's the benefit? so no, there is no problem under CC, and I think it was under CC when I captured the output noise using oscilloscope. No worries.
    JohnC430
    JohnC430
    1 year ago
    The 1.1 Ohm resistor drops 4.4V between the input and out put grounds until Q1 is triggered and then the current flows thru Q1. does this latch the LM358? if not then will it oscillate?
    sam_moshiri
    sam_moshiri
    Reply 1 year ago
    That would be no problem, Yes that power resistor introduce around 4.4 to 4.5V drop (I tested under 2A load), however as you see there is no oscillation.
