3D Beaded Cube!!
Intro: 3D Beaded Cube!!
This Instructable will show you how to make a 3D beaded cube
STEP 1: Gather Materials
You will need :
1. 108 Beads
- For this Instructable, I'll be using purple beads
- You can use a different color if you would like
2. String/Wire
- For this Instructable I will be using string
- If you would like the project to be very strong and sturdy, it's best that you use wire
3. Scissors
4. Nail Polish/Permanent marker
- If you don't have any nail polish you can use a permanent marker as well
- Red works best, but any color will do
STEP 2: Fold String/Wire in Half
1. Cut a piece of string/wire
2. Fold string/wire in half
- Make sure that both ends are even
3. Paint the left end of the string
- Paint the string/wire using nail polish or a permanent marker
- Let it dry for a minute
STEP 3: Make Circle #1
1. Put 4 beads on the left end (Painted)
2. Pass the right end (Clear) through the last bead in the opposite direction
3. Hold both ends of the string/wire even
4. Pull tightly to the center
STEP 4: Make Circle #2
1. Put 2 beads on the left end (Clear)
2. Put 1 bead on the right end (Painted)
3. Pass the right end (Painted) through the second bead on the left end (Clear) in the opposite direction
STEP 5: Make Circle #3
1. Put 3 beads on the left end (Painted)
3. Pull to the center
- Both ends of the string/wire should now be on the same side
4. Turn the beads to the right so that both ends of the string are on the top
STEP 6: Make Circle #4
1. Put 3 beads on the left end (Clear)
2. Pass the right end (Painted) through the last bead in the opposite direction
4. Pass the right end (Clear) into the next bead
STEP 7: Make Circle #5
1. Put 2 beads on the left end (Painted)
4. Pass the right end (Painted) into the next bead
STEP 8: Make Circle #6
1. Put 1 beads on the left end (Clear)
3. Pass the right end (Painted) through the bead on the left end (Clear) in the opposite direction
4. Pull to the center
5. Flip the beads over
STEP 9: Make Circle #7
STEP 10: Make Circle #8
STEP 11: Make Circle #9
STEP 12: Make Circle #10
STEP 13: Make Circle #11
STEP 14: Make Circle #12
5. Turn the beads to the right once
STEP 15: Make Circle #13
STEP 16: Make Circle #14
STEP 17: Make Circle #15
STEP 18: Make Circle #16
STEP 19: Make Circle #17
STEP 20: Make Circle #18
STEP 21: Make Circle #19
STEP 22: Make Circle #20
4. Pass the right end (Painted) into the next 2 beads
STEP 23: Make Circle #21
1. Put 1 bead on the left end (Clear)
2. Pass the right end (Painted) through the bead in the opposite direction
STEP 24: Make Circle #22
STEP 25: Make Circle #23
STEP 26: Make Circle #24
STEP 27: Make Circle #25
STEP 28: Make Circle #26
STEP 29: Make Circle #27
STEP 30: Make Circle #28
STEP 31: Make Circle #29
STEP 32: Make Circle #30
STEP 33: Make Circle #31
STEP 34: Make Circle #32
STEP 35: Make Circle #33
STEP 36: Make Circle #34
STEP 37: Make Circle #35
STEP 38: Make Circle #36
STEP 39: Make Circle #37
STEP 40: Make Circle #38
STEP 41: Make Circle #39
STEP 42: Make Circle #40
STEP 43: Make Circle #41
STEP 44: Make Circle #42
STEP 45: Make Circle #43
STEP 46: Make Circle #44
STEP 47: Make Circle #45
4. Pass the left end (Painted) into the next bead
STEP 48: Make Circle #46
STEP 49: Make Circle #47
4. Pass the right end (Clear) into the next 2 beads
STEP 50: Make Circle #48
1. Put 1 bead on the left end (Painted)
2. Pass the right end (Clear) through the bead in the opposite direction
5. Turn the cube to the right once
STEP 51: Make Circle #49
STEP 52: Make Circle #50
STEP 53: Make Circle #51
STEP 54: Make Circle #52
1. Put 1 beads on the left end (Painted)
STEP 55: Make Circle #53
4. Pass the right end (Clear) into the next 3 beads
STEP 56: Tie a Knot
1. Hold one end of the string/wire in each hand
2. Tie a knot
- Make sure to pull the string/wire as hard as you can without breaking it
3. Tie one more knot to make sure that it is secure
4. Pass one end of the string/wire into a couple of beads
5. Cut the string/wire
6. Pass the other end of the string/wire into a couple of beads
7. Cut the string/wire
