3D Printed Gadgets for Woodworking
Intro: 3D Printed Gadgets for Woodworking
This is a collection of simple 3D printed gadgets for my woodworking workshop. All where designed in Autodesk Fusion 360, and I have included the stl files so you can print your own. The designs are pretty simple, so it should not be difficult for you to modify any of the parts.
STEP 1: Clamping Brackets for Mitered Corners
The brackets are used to clamp mitered joints like picture frames and boxes. The miter angle does not need to be 45 degrees. When 3D printing use 50% or more infill for strength. Glue 80 or 100 grit sandpaper to the flat inside surface to prevent the bracket from slipping during use. The pictures show how the clamp brackets are used.
STEP 2: Knobs
Make threaded knobs and handles for fixtures and jigs. The interior threads are 1/4-20 and 5/16-18. Thread in a hex bolt and super-glue in place.
STEP 3: Rounded Corner Layout Templates
These templates allow you to mark rounded corners for 1/2", 3/4", 1", and 1.5" corner radii. Hook the template over the corner and mark with a sharp pencil. Then saw and sand to the line.
STEP 4: Mortise Layout Templates
These templates are useful for laying out mortises on your stock for routing, chiseling, or a mortising machine. Draw the centerline of the mortise across the stock, line up the template, and mark it with pencil or marking knife. Templates are included for 1/4", 3/8", and 1/2" mortises for 3/4" stock.
STEP 5: Temporary Corner Brackets
They provide extra 'hands' during the assembly of your workpieces. Useful for alignment during glueing, clamping, assembly with screws, etc. Use on corners or for T-joints. Sized for 3/4" stock.
STEP 6: Angle Gauge
Set your saw blade to exact tilt or miter angles. 30, 60, 90 degrees. Design your own for other angles.
STEP 7: Height or Cutting Depth Gauge
Easily set the height (cutting depth) of your table saw blade or dado blade for creating grooves, rabbets, or dados. The gauge includes 1/16", 1/8", 3/16", and 1/4" settings. 3D print standing on edge - no supports needed.
STEP 8: Miter Slot Bars
These fit into miter slots on you table saw, band saw, router table, or sander. Use as stop, or attach to jig/fence/sled. Modify to fit your saw/sander/router table.
STEP 9: Band Saw Insert
Replace a worn band saw insert. The file is for my Grizzly G0555 bandsaw. You may have to tweak the dimension to fit your bandsaw. Omit the center slot to make it a zero-clearance insert.
STEP 10: Magswitch Jigs
Make your own Magswitch jigs. Shown is a featherboard using the commercially available Magswitch magnets (MAGJIG 95). You can design other jigs and reuse the same Magswitch magnets as needed.
STEP 11: Dust Collector Adaptors
Make your own adaptors and fittings for dust collection systems and shop vacuums. The second picture shows a belt sander to shop vac adaptor. Use blue painters tape when you don't get the fit quite right! The dimensions are very specific to your machinery, so you'll have to design your own. I use a 2.4 mm wall thickness, 0.2mm layer height, 3 top/bottom layers, 3 outside/perimeter shells, and 35% infill where needed.
STEP 12: Center Marker
Use this simple gadget with 8d nails to mark the centerline of a board.
STEP 13: More ...
More gadgets to come. Feel free to improve the designs or add your own ideas. Share what you create!
48 Comments
HughC13 4 months ago
rschoenm 4 months ago
topwoodworkingtips 3 years ago
rschoenm 3 years ago
JefferyB16 4 years ago
rschoenm 4 years ago
steegs8319 5 years ago
Some suggestions for the next post- a Dowelling joint jig, & a pocket hole jig?
rschoenm 5 years ago
Any further suggestions are welcome.
youngrh 5 years ago
After importing a mesh (stl file) into Fusion 360 (“Insert > Insert Mesh”), use the “Inspect > Measure” menu item and click on different nodes of the mesh to get distances and angles.
If you just want to 3d-print the stl file use the free Autodesk Print Studio program to process the file for your specific 3d printer. Again, import stl files with mm units.
To modify any files you would need the original Fusion 360 files. If you have a specific gadget in mind I could send you the file. Many of the designs are simple enough for you to recreate quickly and learn Fusion 360 in the process.
Regarding recommendations for specific 3d printers, I don’t have experience with many available systems. I am using an older Dremel 3d20 Idea Builder. It has worked well and reliably for me. Search the internet for current recommendations.
youngrh 5 years ago
vistamachine 5 years ago
youngrh 5 years ago
Philbert D 5 years ago
BonJiba 5 years ago
BonJiba 5 years ago
TheMainMan 5 years ago
What is the notch for in the rounded corner templates?
