3D Printed Honeycomb Led Lamp ( Arduino Nano - IR Proximity Sensor- 12v Led Strip )
Intro: 3D Printed Honeycomb Led Lamp ( Arduino Nano - IR Proximity Sensor- 12v Led Strip )
3D printed Honeycomb led lamp Operated by IR proximity sensor with Arduino nano with 12v led
STEP 1: 3D Printed Honeycomb Led Lamp ( Arduino Nano - IR Proximity Sensor- 12v Led Strip )
Using Fusion 360 i had designed and modeling the Honeycomb led lamp, it contain 5 parts each part can print individual
STEP 2: Circuit Chmatic
Component :
- Arduino Nano
- LED Strip 12v
- IR Proximity sensor
- Transistor PNP 2n2222
- 1K Resistor
- Power Source ( 12v )
STEP 3: Connections
- Connect IR Proximity sensor pin ( OUT ) to Arduino Nano pin ( A0 ) & VCC pin to 5v Arduino Nano pin and GND to Arduino Nano GND,
- Connect Transistor Base to 1K Resistor and Other side of resistor to Arduino Nano pin D2 & Transistor Emitter to 12v GND & Transistor Collector to LED Strip ( GND ) .
Connect LED Strip ( VCC ) to 12v ( VCC ) .
STEP 4: Coding
int ir=A0;
int led=2; // Transistor PNP 2n2222
int val=0; int ledon=0; int pushed=0;
void setup() { Serial.begin(9600); pinMode(ir, INPUT_PULLUP); pinMode(led, OUTPUT); }
void loop() { val=digitalRead(ir); if(val==HIGH && ledon==LOW) { pushed=1-pushed; delay(100); }
ledon=val; if(pushed==HIGH) { Serial.println("led on"); digitalWrite(led, LOW); } else { Serial.println("led off"); digitalWrite(led, HIGH); } }
STEP 5: Print All the Parts
All Parts here :
https://cults3d.com/en/3d-model/home/honeycomb-led...
Using Cura i had slice all the parts ,
I hade to use small support for the base model
Layer Height : 0.2 mm
Infill : 10%
Infill Pattern : Gyroid
Support for one model ( Base )
Speed : 50mm/s
