3D Printer Filament FAULT Detector - Octoprint
Intro: 3D Printer Filament FAULT Detector - Octoprint
Melvin Cruz, Skip Meetze, and Jon Schull
Rochester e-NABLE Lab October 2017
Tom Sanladerer listed “filament tangled on the spool” as the number one filament problem causing failed prints in 3D printing. We would add “running out of filament” as being right up there for causing failed prints in our lab. Here’s the good news: If you have Octoprint set up, then we have a simple solution for detecting either out of filament or tangled filament conditions. The printer will pause and you can replace or untangle the filament and then resume the print!
A few months ago, Chris Riley posted a way to deal with out of filament using a 3D printed holder for a limit switch and a bit of fiddling with your Octoprint:
https://www.thingiverse.com/thing:2095911
https://www.youtube.com/watch?v=ChjwIGxnivw
With our Octoprint setup and our design for a one switch holder, you can also detect tangled filament problems and save yourself lots of failed prints!
As with missing filament sensors, we have a switch that changes state when the filament goes missing. In addition, we have a hinged lever in the system that is held in place by a rubber band. A Tangled filament jam pulls the lever away from the switch, causing it to change state again.
This sensor will work fine with all filament sizes.
Materials:- 3D Printed Parts YouMagine
- 21mm Lever Arm Micro Switch Black KW12-3 ($10.58 for 20 pcs)
- (4) Zip ties (Medium Lenght)
- (2) Small Rubber Bands
STEP 1: Assembling Parts and Setup
Get all the 3D printed parts together, make sure to sand any residuals or threads on the parts that could be interfere with the mechanism's movements.
Set up cable setup and soldering as shown in Chris Riley's video on YouTube.
Place the switcher in the box; it will only go one way.
Attach the sensor and the box firmly to the bracket using a zip tie.
Use filament to make a pivot for the lever.
Finally, use a rubber band to adjust the sensitivity of the jam sensor, two loops should be good, depending. (on the rubber band.)
STEP 2: Octoprint Setup
If you don´t have an octoprint set up yet, you can follow this previous instructable:
https://www.instructables.com/id/Sistema-Octoprint...
Once you have set up the octoprint system, you'll need to install the plugin called "Filament sensor reloaded". Once it's installed, make sure to restart the system. Once restarted, go back to settings and look under plugins the tab for "Filament Sensor Reloaded" and configure it according the image shown.
STEP 3: Demo and Assembly Timelapse
Visit our blog to follow further developments or iterations on this design!
3 Comments
mryusufcan 3 years ago
DennisF26 6 years ago
I really like this solution and want it to work but I am noticing this solution puts a lot of strain on the extruder motor which could effect quality. The issue I think is how the sensor is mounted just above the spool. The filament feeding into the sensor case is at a weird angle causing the filament to be pulled at a very high force which I think ultimately will destroy the motor. Like I said I really like this solution and just wish there was a way to make it easier to lesson the amount of force the extruder motor is seeing.
DIY Hacks and How Tos 6 years ago
This seems like it would be a good addition to any large printing setup.
