Introduction: 3W LED Hat Lamp - 300 Lumens
- Hands-free
- Dimmable with three settings
- Run times: 2-3 hours (high), 4-6 hours (medium), 20-30 hours (low)
- Uses 3 AA batteries
- Options for other LED colours
This hat lamp was inspired by ProdMod, who designed a 3W LED video camera light.
Step 1: Materials
3W Hat Lamp
- 3W White LED
- 10 or 30 degree LED lens with holder
- Heatsink (2cm x 2cm)
- 2 pin connectors
- Heat shrink tubing
- Clear Epoxy
Battery Holder with Brightness Control
- 1 ohm 1/2 watt resistor
- 10 ohm 1/4 watt resistor
- 3 AA rechargeable batteries
- On-off-on switch
- 4 AA battery holder (with cover and on-off switch)
Hat Lamp Holder
- Hat
- Velcro straps
Tools
- Drill
- Scissors
- Dremel with grinding disc
- Soldering iron
- Hot melt glue gun
- Alligator clips (to hold parts when setting the epoxy)
Step 2: Remove Extra Battery Contacts
Remove the contacts so that there is more space for the components. Use the last contact already soldered to a red wire to make this a three cell holder. The remaining slot is for the brightness control switch.
Step 3: Grind Battery Contact Holder
Step 4: Drill a Hole for the Switch and Wiring
Drill a hole for the brightness control switch. A hot soldering iron may be used to enlarge the hole. Warning: When heating the plastic, do this in a ventilated area.
Step 5: Convert 4 AA Holder to 3 AA Holder
Wire the holder as shown.
Step 6: Brightness Control Switch
This hat lamp uses two switches. The switch included with the battery holder is the power switch. The on-off-on switch combined with the built-in switch allows three different brightness settings.
If using red/yellow/IR LEDs, a 2-ohm resistor is required. It can be soldered to the LED externally if you plan on using different colours.
Brightness settings (for 3.8V 3W LEDs)
Direct drive - 1000mA
1 ohm - 500mA
10 ohm - 100mA
Note: The recommended forward current for 3W LEDs is 700 mA, but you can drive them a little higher. These LEDs usually have enough internal resistance for 3 AA batteries if you drive them directly. If using Luxeon Rebel and certain Cree emitters, you may need a minimum resistor value of 0.5 ohms for the high setting to limit the current to 1000 mA.
Step 7: Mount LED to Heatsink
Mount the LED to the heatsink. I used JB weld and clamped it with crocodile clips overnight, minimizing the space between the base plate and the heatsink. To provide strain relief for the wires, glue the wire to the heat sink
Step 8: Solder 2-Pin Connector to LED
2-pin connectors allow your lamp to be detachable, giving you the option to use other colours such as red for dark adaptation. You can also use it to select beam sizes.
Step 9: Test the Hat Lamp
Step 10: Attach Lens and Holder to LED
Grind the bottom of the lens holder to make room for the wires and solder joints. Attach the lens to holder and holder to LED using clear epoxy. Use epoxy sparingly along the rim of the lens and lens holder. Quick setting epoxy is preferred. Wipe off any excess epoxy with rubbing alcohol.
Step 11: Attach Light to Hat Using Velcro
Cut narrow openings for the velcro straps to go through. They will be used to hold the heatsink and battery holder. A small grinding disc may be used to cut the fabric. Make sure it is a hat you don't mind ruining. Hot melt glue may be used to keep the velcro from peeling.
If you prefer keeping the battery holder in your pocket, use longer wires.
Step 12: Super Bright Hat Lamp
Now you have a 3W hat lamp. To adjust the beam angle, simply bend the rim of your hat.
Fix & Improve It Contest
LED Contest with Elemental LED
Bicycle Contest
5 Comments
8 years ago
I'm preparing 5w led, how to connect it to ac please send me the circuit
11 years ago on Introduction
Cool instructable.
Where do you buy the 2-pin connectors? been looking for these guys for some of my own little projects. Did you get them at Digikey?
thanks!
Reply 11 years ago on Introduction
Thanks! I got them at Lee's Electronics. I think this is the one.
http://www.ebay.com/itm/JST-2-Pin-Connector-Plug-w-Wire-Male-Female-x-10-Pairs-/110930746245?pt=Radio_Control_Parts_Accessories&hash=item19d3fcdb85
cool.
Thanks!
