4 Ways to Lace Shoes
Intro: 4 Ways to Lace Shoes
Here are four different ways to lace your shoes!
STEP 1: First
First, I'll explain how to do this one.
STEP 2: #1
Put the laces through the bottom like this, evenly.
STEP 3: #2
Tuck the middle behind the tongue.
STEP 4: #3
Skip one of the holes, and pull the left lace through, as shown.
STEP 5: #4
Pull it through, then under into the empty hole under it.
STEP 6: #5
Do the same with the right side.
STEP 7: #6
The repeat that same process above it.
STEP 8: #7
Then pull the laces through the top, and tie them under the tongue. Or tie them as you normally would.
STEP 9: Finished!
Thats it for this one. :)
STEP 10: Second One
I think this one looks the coolest.
STEP 11: #1
Pull both laces through the left side, evenly.
STEP 12: #2
then pull them over the top, and go through the right side, as shown.
STEP 13: #3
Skipping a hole, pull one of the right strings through.
STEP 14: #4
Do them both.
STEP 15: #5
Then pull both strings through the empty holes.
STEP 16: #6
And weave them one on top of the other like this. Its quite simple. Then shove the laces under the tongue, or tie them as you normally would.
STEP 17: Third One
This one was kinda hard for some reason, but hopefully I can explain it well enough!
STEP 18: #1
Pull both laces through one side like this.
STEP 19: #2
Take the bottom lace, and pull it through the top one on the opposite side.
STEP 20: #3
Then take the other lace and go through the other side directly across .
STEP 21: #4
Then go through the other side and come back.
STEP 22: #5
Continue going up, as shown. then tie them off. Thats it!
STEP 23: Fourth One
This is actually the easiest one.
STEP 24: #1
Pull the laces through evenly like this.
STEP 25: #2
Then cross them, skip a hole, and go through. (just lookit the pictures.)
STEP 26: #3
then go back through the oposite hole so that the laces overlap each other.
STEP 27: #3 Continued
Like this.
STEP 28: #4
Then just repeat the same thing over and over. Its very simple. I'm sure you'll figure it out really quickly.
STEP 29: Thats All!
Thats all of them, I hope you can figure them out!! :)
