4-leaf Clovers: a Finder's Guide
340,529
185
384
Introduction: 4-leaf Clovers: a Finder's Guide
I find four-leaf clovers frequently, even when not explicitly looking. Many find this "gift" extraordinary, and even though this mutation is reported to only occur once in about 10,000 clovers, getting lucky isn't as hard as one would think.
Step 1: Background: the Clover
4-leaf clovers are a mutation of the usually 3-leafed White Clover plant, Trifolium repens. One clover is actually one leaf of a larger plant, with 3 leaflets. Mutations can occur due to a low frequency recessive gene or environmental causes. Often the reason for mutation is differentiable from one clover to another. The mutation does not stop at the 4-leafed variety: 5-leafed clovers are not uncommon. However, the more leaflets, the harder they are to find (and the luckier they are): the record is an 18-leaf clover, and the highest I've ever seen is 10-leafed.
Step 2: Patterns, Patterns, Patterns
First, find a large patch of Clover, which isn't hard to do if you have a lawn or live near a park.
Do not get on your hands and knees with magnifying glass in hand, individually examining each clover. From standing height, look over the entire patch, brushing the clover with your foot to ensure none remain unexposed. If you enjoy math problems, eye-spys, the game "SET", or any pattern game in general, you'll be in your element. Amongst all the sets of 3 leaflets, any mutation will stick out like a sore thumb.
Step 3: Statistically Speaking...
Remember, 78% of all statistics are made up. So even though they say there is only one 4-leafer in 10,000 clovers, thats not entirely the whole story. One clover is just a member of one White Clover plant, which can cover from a few square inches to a few square feet. And some plants are more susceptible to mutation than others, so if you find one, look hard in the near vicinity. Several of the mutants pictured in the following steps were all found within a few square inches.
Mutant clovers are also more prevalent later in summer than they are in spring, and some places just seem more environmentally favorable to produce mutants.
Step 4: The Shamrock
The following steps show a few typical mutants so you know what you are looking for.
The Classic 4-leaf clover has, well, 4 leaflets. Most mutants have three leaf stems in which one has split into two leaves, one usally smaller than the other. These types are probably produced by evironmental factors more than genetic factors (not that genes don't play a part). Clovers with 4 leaflets, evenly shaped, and 4 seperate leaflet stems are, from my experience, rarer, and probably strongly genetically influenced.
Note: There are a few companies that have tried to breed 4-leaf clovers to sell for their alleged lucky properties. Due to the complications between environmental and genetic influence, these breeds are tough to produce, and only marginally effective, or so i've read. heres one of these companies.
Step 5: 4 + N Clover
5, 6, 7, and so on -leaf clovers are rarer the more leaflets they have, but really stick out. Some have the attributes of several different kinds of mutants and can be really interesting.
Step 6: 3.5 Leaf Clovers, Color Variants, and "spades"
Some clovers (not very exciting, but pretty rare) have a mitten shaped leaflet due to conjoined leaves. You can tell they are conjoined by looking under the leaflet and noticing that it contains two stems (see below). Even rarer: sometimes part of conjoined leaf breaks off, with a little leaf sticking like a "thumb" off the mitten (sorry, no pic)
Some clovers will also have a "rust color". This is probably due to an inability of this clover to produce green chlorophyll in the leaflets, showing the less dominant red, yellow, or brown hues, much like how leaves turn colors in fall. Unlike deciduous plants, however, I've noticed this discoloration through out the year.
"Spade Leafed" clovers are a mystery to me. These clovers exhibit a strage shape of each leaf which reminds me of the shape of a spade. At first i thought it was due to insects, but the pattern is too perfect and insects too hungry to always produce this shape. Must be a mutant!(?) Weird...
Step 7: The Elusive 2-leaf Clover
O MY GOSH!! Just kidding, someones just messing with you. Though technically, its possible. Though tough to prove...
Step 8: Collecting and Displaying
I made a simple press to collect my clovers using two pieces of scrap wood and 4 machine screws with wing nuts at each corner. I placed duct tape on the inside of the press to make it easier to slide the note cards i used to seperate and label the clovers in and out. Sticking them in between two cards in your wallet works as well, but be prepared to have your credit card number etched into a leaf.
For mounting, I used a poster-sized picture frame (~$10) and the back of the promotional poster that came in it. I glued my dried, pressed clovers using a dab of elmers glue. Try to keep the mount as air tight as possible, as the clover's will loose their color over time.
Last summer i put this skill to the test: i found 166 4-leaf clovers, 11 5-leaf, and 2 3.5 leafs. After mounting these, i found one patch while mowing the lawn containing multiple 7 and 8 leaf clovers, as well as a 10 leaf.
All of the clovers pictured in this instructable were found in about 20 minutes of searching. They're out there, in many mutant combinations, so get looking and get lucky!
The Instructables Book Contest
1 Person Made This Project!
  • Photography Challenge
  • Anything Goes Contest 2021
  • One Board Contest
    One Board Contest
384 Comments
dmsmith8353
dmsmith8353
Reply 3 months ago
That happens sometimes.
57cadillac
57cadillac
12 years ago on Step 7
I have found a REAL one leaf clover. there were no other leaves that grew out, just that one leaf.
dmsmith8353
dmsmith8353
Reply 3 months ago
Yes, ive found several 1 leaf clovers.
laurfrances
laurfrances
9 years ago on Introduction
Is a 4 leaf clover the same as a 4 leaf shamrock (oxalis?) Is this also lucky?
dmsmith8353
dmsmith8353
Reply 3 months ago
No,, they are not the same. Shamrocks dont count as clovers.
dmsmith8353
dmsmith8353
3 months ago
In this 2021 season which started in march & self ended in may, I have found 700 - 4 leaf clovers, 45-5 leafs & 1-each of 6 & 7 leafs. All of them found strictly by me, looking between 30-45 min a day in that 2 month time span, and only in my own yard.
Teniakatz
Teniakatz
1 year ago on Step 8
Thanks! We found over 200 four-leaf clovers (stopped counting a few months ago), over 20 five-leaf, 3 six-leaf, and a few 3 1/2 leaf clovers in our front yard this summer in different patches. Strangest one was the four-leaf with separated leaves shown below. We have a “lucky number” kind of address and I wonder if these were plants bred for it - also we’re one of the only houses on the street that doesn’t use herbicide on the lawn, and are in a marginally higher-radon area of the Midwest. Your tips were spot on and we’d just stumble on them, not really looking for them. Fun summer diversion : ) now what to do with them all - so far we’re laminating kids’ names out of 4-leaf clovers for them to remember the summer by
ineedhelp136
ineedhelp136
8 years ago on Introduction
i am 10 and i think i found a four leafed clover but im not sure i think its a weed but idk
26zachariasm
26zachariasm
Reply 1 year ago
Dude when I read this I nearly fell over and died
I found my first four leaf clovers today. I found 4 of them. I want to keep them and laminate them but don't want them to get ruined. Does anyone know the best way to laminate it without it being ruined?
26zachariasm
26zachariasm
Reply 1 year ago
Actually the best and cheapest way is to put them in a heavy book and leave them until they are dry then put lead gorrila tape on each side and cut of the excess tape
lllostlori64783
lllostlori64783
Reply 6 years ago on Introduction
i bought a laminating machine from walmart about 30.00 put them in book or between paper towels for just a day make sure they are flat them laminate them ive got some back from 1997 that still look great
ineedhelp136
ineedhelp136
idk but i guess just get like you know um the plastic baggies and put it in there
Lynelle1
Lynelle1
I have an area in my backyard that’s full of four leaf clover’s in nothing but four leaf clover’s…
LightningRocketSoul
LightningRocketSoul
4 years ago
I have not found a 4 leaf clover or above after looking for 30 minutes in my school field, anymore ways to find?
2006086
2006086
Reply 2 years ago
Try a different spot! I can easily find clovers in most places, but I've never found any in my grandparent's back yard.
2006086
2006086
2 years ago on Step 6
I can solve the spade leaf problem!!! When the clovers come up they're still folded and insects eat a chomp out of them since they're so tender and then they open after- like a paper snowflake!
AmandaL4279
AmandaL4279
2 years ago
Wow! I am thrilled to see such intrest in 4 leaf clovers! I thought it was only me. I am, like others here, blessed with the ability of what I have been labeled with, "mouse-vision", and am able to easily spot a 4 leaf clover among 3 leaf clovers and find them quite easily. My personal record is 227 in 3 hours. I have also found multiple 5, 6, 7 and 8 leaf clovers. Apparently somehow that 4th leaf stands out to some people and we are able to see it more easily. Also how many people really get down and look for them? Everyone always feels as though they spend sufficient time & should be rewarded. But without the time & a predisposed "skill" (eyes w/attention to detail) how can you expect to find any if you don't put in the time to look. I'm not saying you need skill to find em but for those that don't find them as easily, you have to work a little harder at it than others. You'll get it too. There isn't a secret to it. I almost wish there was then I would actually be part of something, lol.
jiachengyang
jiachengyang
2 years ago on Step 5
where can l see a lot of clover in london,l am a student,and l have a project work ,bec l need to shoot a vedio about clover!so l want to know what’s the place l can find it!thank you so much!!^-^
