433 MHz Coil Loaded Antenna
Intro: 433 MHz Coil Loaded Antenna
In my 433 MHz projects I have been using a cheap (0.70 cnts) pair of Tx/Rx
modules. I have mostly used the transmitter and that is actually fairly OK with just a simple 1/4 lambda antenna, but is open for improvement
The receiver however is a bit crappy: without antenna the reach is maybe no further than a meter, but even with a 1/4 lambda antenna it is marginally more, even with free Line of Sight.
For any serious project that involved receiving data it seemed I needed the much better (and more expensive) RXB8 receiver. But as said, also the reach of the transmitter could use a bit of improvement.
However, when mining the internet for a coil antenna (trying to improve on the lengthy 17.2 cm stick antenna) I came across a design of Ben Schueler, apparently once published in elektor magazine. A reference to Ben's pdf (back up) would suffice to build it, but so is my picture and I can add my experience with it as well.
It is a so called coil loaded design consisting of 0.6mm wire wrapped around a 2.5mm core.
The picture gives a clear description: a length of 25 cm wire should be enough. At the base it is 17 mm long. Then goes into 16 turns over a 2.5 mm diameter core (Ben advises to use 1.5mm²black installation wire for this. I just used a screwdriver)
The results with this antenna are very good. The distance (with the cheap receiver as well as the transmitter) that can be covered easily goes to 25 m with line of sight, but also in-house the distance will be increased reaching other rooms with concrete walls in between, were earlier 3 meters with line of sight would be pushing the limits already.
I am not the only one with this experience. Many people confirm to me that it dramatically increased the range of the cheap Tx/Rx pair, read the comments!
94 Comments
mp2022 5 months ago
diy_bloke 5 months ago
mjward1 4 years ago
KenC7 4 years ago
mjward1 4 years ago
KenC7 4 years ago
mjward1 4 years ago
KenC7 4 years ago
SaifullahK5 4 years ago
KenC7 4 years ago
portbox 1 year ago
Edit: This was tested while plugged into a breadboard. Once I soldered the straight wire onto the protoboard, performance degraded considerably. Like really bad. Maybe interference with the rest of the Raspberry Pi.
diy_bloke 1 year ago
mjward1 1 year ago
You also need to take into account the type of wire you are using, as the design was for a resin coated wire, not a plastic sleeved wire, which will detune the aerial and make it lose performance.
If it is not working then you can always try stretching the coil and cutting it shorter, or just use the straight wire, in either case, make sure the ground plane is there.
portbox 1 year ago
Regardless, how would you suggest I do this for my project? I am using a Raspberry Pi Zero W with this protoboard on top, and this RF receiver. The parts together look like the attached first image. The entire thing is maybe 2 inches long, not including the antenna, it's a small device. The soldered wires are connecting the chips ground, 5V, and data pin to the Raspberry Pi. If the chip is grounded to the Pi, is the Pi serving as the ground plane or no? Would I need to add another metal layer to this configuration? I appreciate your help.
mjward1 1 year ago
I have seen people use a metal plate, a copper clad board or even a metal box with the aerial going through a hole in the plate/box.
Theoretically if the pi is sat on a board with a ground plane, this may work, but given the fact that RF is not good for interference with data lines, you may want to add a ground plane over the PI anyhow.
I would opt for a piece of metal on spacers, or an alloy box, being the cheapest method, the aerial perpendicular to the ground plane
KenC7 1 year ago
In both cases, the yellow oval is the antenna, and the amber rectangle is the 433mhz module. Notice in both cases, the antenna is perpendicular to the plane of the module's ground plane. Also, in both cases, the antenna ends up pretty much perfectly vertical. Both antennas are made of the same 22ga solid copper hookup wire.
Both of the antennas reliably pick up signals up to 600ft. away. I suspect they'd handle longer distances than that, but don't know. Also, I can't get a signal strength reading out of these - they're very dumb modules. I tried to make the antenna mjward1 suggested, but couldn't get it into my package. And since both of these work fine, I've just stuck with what I have.
I have two types of sensors. I have long range Olymbros sensors that use a professionally made SMA attached vertical-up antenna. For my home-made sensors, I use the straight wire antenna, and the wire is actually straight down. Both get picked up fine by the two receivers.
portbox 1 year ago
KenC7 1 year ago
diy_bloke 4 years ago
0000007 4 years ago
