5 Camping Uses for Trash Bags
Intro: 5 Camping Uses for Trash Bags
Here are 5 uses for a garbage bag when camping. These are all easy to do and will only cost you a couple of bucks.
STEP 1: Use It As a Pack Cover
There's no need to buy a $30 pack cover. All you need is to slip a garbage bag over your backpack to keep your stuff dry.
STEP 2: An Emergency Shelter
You can quickly set up this very cheap and easy emergency shelter with only a garbage bag and some rope.
STEP 3: A Ground Cloth
Weather to sit on or to lay down on you can set a garbage bag down on the ground to keep yourself off it. You can even cut the seams/sides of the bag to double the size.
STEP 4: Keep Your Feet Dry
Line your sock with a plastic bag and even if your boots are all soaked through you can still keep dry feet using this simple trick.
STEP 5: A Pack Liner
Just slip a garbage bag in your backpack before putting your gear in so if your backpack gets soaked you can still keep your gear dry.
3 Comments
fredrp53 5 years ago
One use I have read somewhere is to cut a hole in the bottom of the bag large enough to fit your head through and two holes on the sides for your arms and you have a make-shift poncho in a unexpected downpour.
eitaknella18 8 years ago
Those are some great ideas. So in other words, never leave the house without one!
tomatoskins 8 years ago
We're glad you want to share something with the community, and this project looks very interesting. However, in order to be published this project must only contain original images created by you. Please replace any stock or otherwise borrowed images with your own.
Once you do that, leave me a message and we will publish your work!
Thanks,
Your friendly neighborhood instructables staff.
