5 Easy Steps to Making a Living Succulent Wreath
3,279
85
8
Introduction: 5 Easy Steps to Making a Living Succulent Wreath
About: gardening, gardens, crafting & creating. let's make the world a more beautiful place. eco-centric company inspired by nature & lovin' the great outdoors.
You can make this gorgeous wreath in 5 easy steps and under one hour!
Step 1:
As you know, I’m a succulent maniac. I have a lot of them planted in my garden and in pots. I jump at the opportunity to make anything using these interesting, durable and visually diverse plants. I thought: alright already, it’s about time I make 1 of these wreaths! Succulents are fun to look at and easy to maintain which makes them so fitting for this project. So drumroll please, today I want to show you how I make a living succulent wreath, using plants, in 5 easy steps.
Here are the main ingredients I used to make my living masterpiece.
You’ll need:
–> A living wreath wire form (I used a 12″). Make sure you get 1 you can plant in, not a flat form. I needed to attach a hanger but some already come with 1.
–> Preserved sheet moss.
–> A variety of succulents. I used 16 of the 2″ pot size.
–> Greening pins. These are what holds the moss in place – you’ll see me using them in the video.
Step 2: Here I Am at My Work Table in the Garage Guiding You Through This Living Succulent Wreath Project
I made a festive grapevine wreath with succulent cuttings which I posted back in December. I’ve also made 1 using a sphagnum moss wreath form which I don’t like as much as these wire wreath forms. These wire forms come in a variety of sizes, shapes, including square and heart, as well as a variety of planting depths and widths. The 1 I used was a bit on the tight side so I used 2″ succulents. The 1″ size would have been fine too.
Step 3: HERE ARE THE STEPS
1- Line the wire wreath form with the moss. Tip: wet the moss to make it more pliable. Don’t worry if the moss doesn’t look neat & even because it doesn’t grow in nature that way. Just make sure the bottom & sides of the form are lined & that you have enough moss to fold over & cover the root balls of the plants.
Step 4:
2 – Lay the plants out around the wreath form to determine what pattern is pleasing to you. Tip: use succulents which all stay rather low & tight (more in a rosette) rather than ones that grow taller with a stem. That way your wreath will keep a much better form over time.
Step 5:
3- Compact the root ball of the plants by lightly pressing them in your hands to get them in the form. Tip: if you water your succulents before doing this it’s much easier. I had to do this because the planting well of the form I used was relatively small. Don’t worry because succulents are tough & can handle a gentle massage! Your may not need to do this if your form has a larger planting space. Either way, you’re bound to make a big mess like I did.
Step 6:
4- After all your succulents are in (I needed to add 1 more at the end – you see it in the video) then fold the moss that’s hanging over the edges back over the soil of the root balls. Tip: greening pins make it very easy, just fold & pin, to secure the moss. Make sure you push the pins all the way down into the soil so the moss holds tightly in place. You may need to go back over & patch some pieces of moss over any exposed areas of soil as you want it completely covered with moss.
Step 7:
5- Although I have the wreath hanging in this pic, I immediately laid it down my back patio. This Is The Biggest Tip: make sure your wreath lays flat for at least 1 month, preferably 2, as the roots settle in. You don’t want to hang it on your door or wall & have it completely fall apart. Also, keep it out of any direct hot sun.
I adjusted the succulents a bit to angle them the way I wanted them to grow. This also makes for a bit more interest rather them having them all lined up and growing in a perfect circle. I don’t water the wreath for about a week (remember, I watered the succulents before planting them in the form) and after that time, give it a good drink. By the way, this living succulent wreath project took me about 45 minutes so it’s a quick one. I do a lot with succulents and am always looking for some creative way to use them. How about you – do you have succulent mania too? If so, we’re definitely not alone on this one!
Happy gardening,
Nell
Joy Us garden
Be the First to Share
    • Make it Glow Contest
    • First Time Author Contest
    • Anything Goes Contest
    8 Discussions
    Kane Measham-Pywell
    Kane Measham-Pywell
    3 years ago
    Great project just wondering do the succulents grow up searching for light or do they generally stay the way you planted them
    JoyUsGarden
    JoyUsGarden
    Reply 3 years ago
    Hi Kane - If given very bright light, they won't search for light. If not, they'll eventually get leggy. Be sure to keep your succulent wreath out of direct, hot sun as it'll burn. Nell
    Meglymoo87
    Meglymoo87
    4 years ago
    Gorgeous!
    JoyUsGarden
    JoyUsGarden
    Reply 4 years ago
    Thank you so much - glad you like it! Nell
    krivas
    krivas
    4 years ago
    This is gorgeous! I really like the variety of plants you used and how their colors complement each other.
    JoyUsGarden
    JoyUsGarden
    Reply 4 years ago
    Thank you so much! Succulents are so interesting - they make it easy to be a plant artist. Nell
    Meglymoo87
    Meglymoo87
    4 years ago
    Beautiful!
    JoyUsGarden
    JoyUsGarden
    Reply 4 years ago
    Thank you so much! Nell
