5 Really Helpful Glue Gun Hacks
Intro: 5 Really Helpful Glue Gun Hacks
STEP 1: Fix It Up Match
Add a ring of hot glue around a match stick
Then when you need to fix something you can light your match and the glue will melt allowing you to smother the glue onto something and fix it:)
STEP 2: Slippery Socks and Hangers
Add dots of glue to your fuzzy night socks and make them no slip! To make hangers not drop your clothes make squiggles on the top parts of the hangers
STEP 3: Melted Crayon Drawing
DISCLAIMER I am not responsible for any damage done to your glue gun or any injuries to you
Stick a crayon were you usually put you glue and have a piece of paper ready to draw melted crayon on
STEP 4: Make Up Brush Cleaner
What you need
Piece of plastic that you don't need
Glue gun
Take your glue gun and make a bunch of dots/chevron pattern/ stripes on the plastic
Use by taking your make up brush and the plastic and run the bristles along it while water is running on it
Glue gun
STEP 5: More Glue?!
Take your next glue stick and melt the tip of it with the glue gun. Then attach the melty tip onto the old one and so when you are nearing the end of the other glue stick it won't fall out.
STEP 6: A Little Extra From Sixsmith
Denatured alcohol is great for removing hot glue
A spritz ofCanned "air" held upside down will set hot glue super fast
-Sixsmith
-Sixsmith
6 Comments
GeekCrafterGirlz432 7 years ago
saiber 7 years ago
https://www.instructables.com/id/Jugadu-Repair-Your...
try this another hack for slippery footwear using glue
sixsmith 7 years ago
If I may add two additional tips.
Denatured Alcohol is great at removing hot glue
and a spritz of caned "air" held upside down will set hot glue super fast.
parisusa 7 years ago
