50 Cent Coin Battery
Intro: 50 Cent Coin Battery
In this instructable I will be showing you how to make a battery that can be made with common items found in your house. This is a very useful tool and can be used in everyday life for jobs as simple as lighting LEDs to charging your Ipod( if you "do the math"), and is easy to make and use.
STEP 1: Materials and Tools
this is a list of the materials and tools you will need.
Materials:
Pre- 1982 pennies
zinc(galvanized) washers( the same no. of washers as pennies)
vinegar( the type doesn't matter too much, but will affect the amount of voltage you get out of the battery)
cardboard( any porous material, such as paper, will work)
wires
electrical tape
Tools:
Multimeter(optional)
open container
scissors
spoon or stirring rod
STEP 2: Mixing the Vinegar
Pour a small amount of vinegar into a container. Cut three cardboard pieces, roughly the same shape and size as the pennies you will be using. Soak them in vinegar, remembering to stir the mixture once in a while. after five minutes, remove the cardboard dots.
STEP 3: Making a Cell
layer the following parts as shown: penny on the bottom, wet cardboard in the middle, and zinc washer on the top. repeat this pattern as many times as you like, depending on the voltage you want.
At this point, the battery is finished, but there are a few more steps in order to make sure that it can be used properly.
wrap the entire cell in electrical tape in order to keep it from dying out, but leave part of each end uncovered for wires. You should have a penny at one end and a zinc washer at another end. These two ends are positive and negative, respectively. hold wires to each exposed end, and tape the assembly closed.
STEP 4: Final Tips
You now have a fully functioning coin battery, but before you use it, it helps to measure the voltage of the battery to prevent any future mistakes.
When measured, one coin battery generates just over half of a volt. That means that for every penny used, you can get half a volt of free energy.
These batteries are not made to last, as the vinegar inside will eventually evaporate and leave the cell dead. When that happens, simply replace or re-soak the cardboard, or take back your money.
Please favorite this instructable and leave a comment if you have a way to make this more AWESOME. Check out my other instructables and use that new-found energy in your hand.
5 Comments
variances 9 years ago
lazyboy395 9 years ago
Possibly. However, I am short on change, so I cant confirm this.
f.3 9 years ago
Sorry for the typo, i meant pre 1982 pennies. Typically both work, but pre-1982 pennies have more copper.
supercapacitor 9 years ago
Nice! I really want to try this out.
