Introduction: Easy Remedies for 6 of Your Day to Day Problems!
Hi friends!
Having a good day ruined by some sickness is very annoying.
As we all suffer from common medical problems Like headache,motion sickness,cold,pains etc.Here in this instructable I am going to tell you some most effective home remedies.For some common causes.
We can find many solutions around us and sometimes these home remedies work much better than our expectation.
A home remedy is a treatment to cure a disease or ailment that employs certain spices, vegetables, or other common items. Home remedies may or may not have medicinal properties that treat or cure the disease or ailment in question, as they are typically passed along by laypersons (which has been facilitated in recent years by the Internet). Many are merely used as a result of tradition or habit or because they are effective in inducing the placebo effect.
I am participating in the home remedies contest.Please vote if you like the instructable. Thanks...
Step 1: Acne - Any Teenagers Nightmare
Tip 1:
Fresh lime juice may be dabbed on pimples and black heads.
Tip 2:
Mix 1 tsp fresh coriander powder with a pinch of turmeric powder. Apply on pimples and black heads. Keep overnight and wash off gently the next morning.
Tip 3:
Make a paste of fresh, young curry leaves apply and keep on overnight wash with warm water in the morning. Helps wrinkles to fade away gradually.
Tip 4:
Make a paste of nutmeg (Jaiphal) with raw milk. Apply on pimples and black heads leave on for 20 minutes or overnight. Continue for 10-12 days, till face is clear.
Tip 5:
For dry skin rub a piece of sandalwood on a smooth stone with a few drops of raw milk. Apply the paste procured on affected areas. Keep on for 1 hour. Gently wash.
Tip 6:
For oily skin make a paste of sandalwood and rosewater apply on affected areas, keep for 1 hour and wash off gently.
Tip 7:
Fresh fenugreek leaves made into a paste and applied overnight clears pimples.
Step 2: Cough - Cough........Cough
Tip 1:
Take 3 peppercorns with a pinch of black cumin seeds (shah jeera) and a pinch of salt.
Tip 2:
3-5 drops of clove oil mixed with a clove of crushed garlic and ½ tsp honey helps soothe the throat.
Tip 3:
In a cup of boiling water add 1 tsp turmeric powder and 1 tsp carom seeds (ajwain). Boil till half. Add 1 tsp of honey and have 2 times a day.
Tip 4:
50 gm of sugar candy (mishri) with 50 gm pepper powder. Mix with pure ghee to make small pellets. Take 3-4 times a day.
Step 3: Burn - Ouch!!!
Tip 1:
The first and most important thing to do on getting burnt is keeping the injury under running water for at least 15 – 20 minutes. It keeps the pain at bay for a while.
Tip 2:
Apply a layer of egg whites to the burn and let it dry, it is said to give some relief.
Tip 3:
Soak some tea bags in cold water and place them on the burn, tannic acid found in black tea helps draw heat from a burn. Repeat till the pain stops.
Tip 4:
Apply a thick coating of toothpaste – not the gel or liquid – use only the white one.
Tip 5:
Cold, whole milk is soothing on a burn. Dip some handkerchiefs or scarves in a bowl of milk and place on the burn. Alternate as the cloth becomes warm and dry – every 15 minutes or so. Gauze bandage can also be used.
Tip 6:
Puree some raw onion and apply the paste thickly, many people have found relief doing this.
Tip 7:
Yellow mustard – may sound strange – but is found to be very effective. It not only brings down pain but also prevents scarring.
Tip 8:
Another popular cure is using honey – smother the burn site with honey, it will definitely relieve pain and prevent blisters. To avoid drips, honey can be mixed with flour to make a paste - this will work in the same way and can be kept covered with a gauze bandage.
Tip 9:
Diluted vinegar relieves pain and relaxes skin tissue. Dip clean pieces of cloth or gauze and keep replacing with freshly soaked ones every 15 minutes.
Step 4: Stomach Illness - All Kinds of Pain
Acidity
Tip 1:
After all three meals, take a small piece of jaggery and keep it in your mouth and suck. Voilá no more acidity.
Tip 2:
Boil one cup of water. To this add 1 tsp of Aniseed (Saunf). Cover and leave overnight. Strain the water in the morning, add 1 tsp of honey. When this is taken 3 times a day it prevents acidity.
Tip 3:
To 1 ½ liters of water add 1 tsp Caraway seeds (shah jeera). Bring to a boil and simmer for 15 minutes. Sip while warm. Have the concoction 2-3 times a day for 5-6 days.
Tip 4:
Powder one clove and one cardamom; use the powder as a mouth freshener after every meal. No more acidity and no more bad breath.
Gas Trouble
Tip 1:
Mix 1/2 tsp dry ginger powder with a pinch of asafoetida and a pinch of rock salt, in 1 cup of warm water. Drink.
Tip 2:
Mix 2 tsp of brandy with a cup of warm water and drink before going to bed.
Tip 3:
Chew on some fresh ginger slices that are soaked in lime juice after meals.
Tip 4:
A drop of dill oil in a tsp of honey taken immediately after a meal will help.
Tip 5:
Powder 1 tsp of pepper, 1 tsp of dry ginger and 1 tsp of green cardamom seeds. Mix 1/2 tsp of this mixture with water and drink an hour after a meal.
Tip 6:
Boil water with cumin and garlic, when you feel sick.
Step 5: Headaches - a Real Headache
Tip 1:
Roast some caraway seeds dry. Tie in a soft handkerchief or muslin cloth and sniff to get a relief from headaches.
Tip 2:
Apply the paste of 3-4 cloves on the fore head.
Tip 3:
A peeled and chopped apple, with a sprinkle of salt eaten first thing in the morning, for at least a week will cure chronic headaches.
Tip 4:
Make a herbal tea with 10-15 holy basil leaves (tulsi), 5-6 peppercorns and 1/2" ginger piece, powder. Keep in an air tight bottle. Take 2 pinches with warm water when a headache starts.
Tip 5:
Massage head with rosemary oil.
Tip 6:
Add water to 1 tbsp ginger powder. Heat gently in a pan. Apply the warm poultice on forehead. Keep for 15 minutes.
Step 6: Teeth Colouring - Smile Please..........
Tip 1:
When one brushes teeth regularly, in the morning and evening, the discoloring effect of certain dietary components are taken care of. Toothpastes use chemicals and mild abrasives to remove surface stains and whiten teeth. One should brush teeth soon after consuming food which potentially stains. Floss teeth, at least once, daily.
Tip 2:
An enzyme, malic acid, present in strawberries is known as a natural whitener. Strawberry pulp or halved strawberries can be rubbed onto teeth and left for a minute before washing. This helps teeth to whiten. The natural fiber of strawberries promotes the whitening process, by removing bacterial growth within the gums of teeth.
Tip 3:
Brushing teeth with a small amount of baking soda helps whiten teeth. Baking soda counters the acidity in teeth and buildup of enamel. It is recommended that teeth be brushed with baking soda at least twice a month, similar to the cleaning performed by the dentist. Toothpaste has baking soda as a component. However, baking soda is unable to whiten artificial teeth.
Tip 4:
These natural foods generate a lot of saliva which neutralizes the acidity within teeth, and retards the discoloration process. Apples, carrots, and celery are rich in vitamin C, and prevent gingivitis and gum disease.
Tip 5:
Brushing your teeth with mango leaves,they make your teeth marble white.
Tip 6:
Chewing sugarless gum generates a lot of saliva, which acts as a natural cleanser for teeth.
Tip 7:
Yogurt and cheese are useful products in maintaining the color and health of teeth. Hard cheese (eg, cheddar) is useful in removing other food particles lodged in the gums. Milk products have lactic acid bacteria, which prevent gum disease and maintain teeth. The vitamin D and calcium in milk products enhances jawbone development and fortifies teeth.
Tip 8:
Oranges, lemons, and pineapples are another source of teeth whiteners. Rubbing lemon juice on teeth helps in teeth whitening. Drinking a mix of equal proportions of lemon juice and water, once or twice a week only, helps in maintaining white teeth. The regimen should not be increased for fear of increasing the acidity within teeth. Oranges and pineapples increase saliva production, which helps in naturally cleaning out the teeth and gums.Use along with salt for best result.
Home Remedies Contest
4 Comments
8 years ago on Introduction
Rather than a bunch of Googled images, why not use your own photos of the remedies you have mixed yourself?
Thank you for the information.But i dont have a proper camera.
I will do my best next time
This also my first instructable.
Sorry for the immaturity of the work
+1
