7 Segment Clock With Temperature Display [ds18b20 and 5 Digit Display]
Intro: 7 Segment Clock With Temperature Display [ds18b20 and 5 Digit Display]
5 digit seven segment clock with temperature display.
PIC16F877A based clock
1, High-precision temperature sensor ds18b20
2, ds1307 RTC
3, 4 switches, easy time adjust option
4, alternating temperature and time display method
5, pic16f877a micro-controller
6, half hour notification - single beep
7, hour notification - double beep
8, buzzer notification for key press
2, ds1307 RTC
STEP 1: Display Panel
STEP 2: Display Panel Circuit Diagram
components
1, BC 558 -5
2, resistors 330 Ohm - 10
3, common anode seven segment LED display - 5
4, acrylic sheet
1, BC 558 -5
4, acrylic sheet
STEP 3: Assembling Steps - Display Unit
STEP 4: Assembling Steps - Main Board
STEP 5: Sensor ,keyboard and RTC Chip
ds18b20 sensor
http://datasheets.maximintegrated.com/en/ds/DS18B20.pdf
ds1307 RTC
http://datasheets.maximintegrated.com/en/ds/DS1307.pdf
Overview of 1-Wire Technology and Its Use
By: Bernhard Linke, Principal Member Technical Staff
Jun 19, 2008
Abstract: This article provides a general overview of the 1-Wire® technology, its communication concept and, as a benefit of the low pin count, unusual package options. The main section discusses 1-Wire devices by their feature set and explains the typical applications. The article ends with practical information on how to evaluate 1-Wire devices, explains device customization options, and references resources that assist customers in integrating 1-Wire technology in their systems.
What Is 1-Wire Technology?
The basis of 1-Wire® technology is a serial protocol using a single data line plus ground reference for communication. A 1-Wire master initiates and controls the communication with one or more 1-Wire slave devices on the 1-Wire bus (Figure 1). Each 1-Wire slave device has a unique, unalterable, factory-programmed, 64-bit ID (identification number), which serves as device address on the 1-Wire bus. The 8-bit family code, a subset of the 64-bit ID, identifies the device type and functionality. Typically, 1-Wire slave devices operate over the voltage range of 2.8V (min) to 5.25V (max). Most 1-Wire devices have no pin for power supply; they take their energy from the 1-Wire bus (parasitic supply).
What Is Special About 1-Wire?
1-Wire is the only voltage-based digital system that works with two contacts, data and ground, for half-duplex bidirectional communication. In contrast to other serial communication systems such as I²C or SPI, 1-Wire devices are designed for use in a contact environment. Either disconnecting from the 1-Wire bus or a loss of contact puts the 1-Wire slaves into a defined reset state. When the voltage returns, the slaves wake up and signal their presence. With only one contact to protect, the built-in ESD protection of 1-Wire devices is extremely high. With two contacts, 1-Wire devices are the most economical way to add electronic functionality to nonelectronic objects for identification, authentication, and delivery of calibration data or manufacturing information.
for more details:
ds1307 Key Features
Real-Time Clock (RTC) Counts Seconds, Minutes, Hours, Date of the Month, Month, Day of the week, and Year with Leap-Year Compensation Valid Up to 2100
56-Byte, Battery-Backed, General-Purpose RAM with Unlimited Writes
I²C Serial Interface
Programmable Square-Wave Output Signal
Automatic Power-Fail Detect and Switch Circuitry
Consumes Less than 500nA in Battery-Backup Mode with Oscillator Running
Optional Industrial Temperature Range: -40°C to +85°C
Available in 8-Pin Plastic DIP or SO
Underwriters Laboratories (UL) Recognized
STEP 6: Circuit Diagram
STEP 7: How to Adjust Time
there are 4 micro switch
SEL/EXIT [selection or Exit ]
Up [increment ]
Down [Decrement]
Set [Update the last change]
step 1: wait for the time display [ switches function disabled at time display mode ]
step 2:
step 2.a
Press the SEL/EXIT switch
hour option selected [Up and Down button for hour ]
step 2.b
Press again the SEL/EXIT switch
minute option selected [Up and Down button for minute ]
step 2.c
AM/PM option selected [Up and Down button for AM/PM selection ]
step 2.d
it cancel the change and exit from updating mode
if you want to save the change don't press the SEL/EXIT button
step 3: SET Button
update the last change
Up [increment ]
Down [Decrement]
step 2:
step 2.a
step 2.b
step 2.c
step 2.d
step 3: SET Button
STEP 8: Working Video
STEP 9: Hex File Download
hex file rtc_temp_clock.hex
crystal 20 MHz | watch dog timer off | code protection off
13 Comments
fareswaled900 5 weeks ago
Thank you for your efforts to present this project
My dear friend, please send me the source code(.c file) with codvision avr.
It is very urgent and necessary.
I will be very thankful
Email: fareswaled900@gmail.com
vijayanmk 3 years ago
made the clock as per the provided drawing didn't work no display can you provide detail drawing and hex files for both common anode and cathode.
thanks
vijayan.mk@gmail.com
man864864864 4 years ago
Email: fdelec22@yahoo.com
riyasrio 5 years ago
muhammedriyaskt0@gmail.com
ank19982 6 years ago
please send me source code of this clock on gaur.ankit1998@gmail.com
TrishiaI 9 years ago
Hi can u please send me the hex file maeituralde@gmail.com thanks,
darkie25 9 years ago
good morning i asking how to use buzzer?
email: johnrayrodriguez25@yahoo.com
rene alfredo 10 years ago
Email : ingalfred2@gmail.com
md jewel 10 years ago
Email : jeweljisan@yahoo.com
