$8 DIY Variable Digital Power Supply
Intro: $8 DIY Variable Digital Power Supply
Hi in this instructable I'll show you that how can you make a variable 12v power supply, that can be used to design electronics projects or as a project power supply. The device is based on the LM2596 NC Voltage Switching Regulator, that is a very effective integrated circuit. I bought mine from Amazon with a voltage display. It's easy, and very glad to use. All link appears in the "Parts" step. Of course you can use this circuit for battery charging, powering up an electronicts project. I think every hobbyist needs a lab bench power supply, but I'm usually using Arduino for my project and I don't work with more then 12 volts, so I don't want to buy an expensive lab bench power supply. That's why I made this cheap and simple power supply. For me cost only 8 bucks because I should buy only the main circuit that was 7.99 dollars. But almost every hobbyist has the other parts in his inventory.
It's easy to use there are four buttons:
- if you press "+" the voltage will increase with 0.1 volt, if you press and hold the voltage increases with 1 volt
- if you press "-" the voltege decreases with 0.1 volt...
- if you press "I" the build in voltmeter measures the input voltage
- if you press "O" the voltmeter measures the regulated output voltage
The maximum current of this circuit is 2A, this is more then enough to power up Arduinos. It's simply amazing! Now let's see what else will you need!
STEP 1: Parts and Tools
- Soldering Iron
- Glue Gun
- Wire Cutter/Stripper
- DC 12v adapter
- 2 male and 2 female DC power barrel jack
- the LM2596 NC Voltage Switching Regulator
- a plastic sheet
- 2 crocodile clips (black and red)
STEP 2: Step 1
Use your soldering iron and and solder one short and one longer wire to the DC barrel input jacks. Usually the positive pin is on right and the negative is on the left (look at the 3rd image).
STEP 3: Step 2
You should use agian your soldering iron to solder the crocodile clips to the DC barrel jack. If you want you can connect the crocodile clips directly to your circuit, but I think this is a better solution.
STEP 4: Step 3
Use your srewdriver and connect the cables to the circuit.
STEP 5: A Quick Test
Power up the circuit and try it out. Mine works fine.
STEP 6: Step 4
Now you are close to finish this project, just glue the parts on a plastic sheet just like me. Well, you can make a better case, but isn't neccesary. I wanted to make this gadget portable, this is very important for me. When I'm working with Arduino I need sometimes a small and portable power supply.
STEP 7: The End
Thanks for watching, I hope you liked!
17 Comments
Col68 6 years ago
InfiswiftC 7 years ago
Can you add a potentiometer to the output to regulate the current?
Kerekes Tamás 8 years ago
Imetomi 8 years ago
brian32768 8 years ago
Aren't you supposed to either (a) make a case with a very expensive laser cutter or (b) put it in an Altoids tin? We have traditions around here!
Would be nice to see the input and output traces on a scope to see if the PSU is any good.
Imetomi 8 years ago
Imetomi 8 years ago
mrlengyel 8 years ago
...or make a 3d printed case...
gravityisweak 8 years ago
Nice! It's very similar to mine. I used an small etch a sketch toy as a case. I like the way you added the plugs. Interesting that yours uses buttons to adjust the voltage. Most of the ones I've seen (mine included) use a potentiometer.
https://www.instructables.com/id/Etch-A-Sketch-Power-Supply/
Imetomi 8 years ago
MichielV3 8 years ago
There is no control to limit current on that supply, it will put out whatever it can up to its limit or the limit of the input supply. You need something fancier if you want to set a max current; I saw someone here yesterday using this:
http://www.banggood.com/DP30V3A-NC-Programmable-Po...
It looks like it might have a settable limit based on the very poorly translated manual.
voblak 8 years ago
DIY Hacks and How Tos 8 years ago
Cool power supply.
Imetomi 8 years ago
