8 Foil Life Hacks
Intro: 8 Foil Life Hacks
In this project, I will show you different ways that you can use foil to get benefits..
STEP 1: Sealing a Plastic Bag With Foil
You can seal plastic bags with aluminum foil as seen in the video...
STEP 2: Small Pocket Heater
You can use a AA battery and a foil sheet to warm up your pockets and hands.
STEP 3: Perfectly Press Tie
You can use a foil sheet to press a perfect tie.
STEP 4: Cell Hack
You can use foil sheet to fit a AAA cell in AA sockets by create a small foil ball as foil sheet conduct electricity so it was a good trick if you run out of batteries
STEP 5: Clean Grills Using Foil
You can use a Foil Sheet to Clean Oven Grills Can be Seen in the Video Above.
STEP 6: Use Foil During Paint Activities
Use foil paper to protect different objects from getting paint accidently...
STEP 7: Sharpning Scissors With Foil
Use Foil Sheet to Sharp the Scissors
STEP 8: Light Up Fire With Foil Paper
You can use foil paper to create fire can be use in extreme conditions when low resources are available.
