8x4=2 (2 Tables From 1 Sheet of Plywood)
Intro: 8x4=2 (2 Tables From 1 Sheet of Plywood)
Use a simple template to create 2 tables from a single sheet of 24mm ply or 1 table from a single sheet of 12mm ply.
We use an early version of this table as work benches in our studio. We had them laser cut out of oriented strand board, sometimes known as stirling board.
In retrospect we realised that water jet cutting would have been a better option - the 'burned' edges from the laser cutting look quite cool but tends to leave you with black marks on your hands.
STEP 1: Download the Cutting Template
If you want to cut the table by hand then download the 1:10 scale pdf drawing
or the dimensioned 1:10 scale pdf drawing
Alternatively you can use the dxf cutting template and have the timber CNC cut, laser cut or water jet cut.
I will add some links to waterjet cutting people here soon.
STEP 2: Cut the Ply
If you are brave enough to cut this by hand you will need to mark up the upper face of a 1220mmx2440mm sheet using the downloaded drawing.
The design is fairly tolerant of inaccuracy in the jigsaw cutting but you will need to cut the slotted holes in the lid to provide a tolerant holes for the tabs on the leg frames.
If you are using 12mm ply you will need to glue and clamp the pairs of table tops and legs to eachother. PVA glue will do the trick. You should clamp the leg frames on their tabs and about 10cm from the end of each leg. The table top needs clamping over the slotted holes.
STEP 3: Admire Your New Table
If you want to add additional rigidity the table top can be screwed through to the edge ply of the leg frames. Use the lotted holes as a guide for where the legs are beneath and drill a small diameter locating hole through from above before countersinking a posi-head woodscrew.
If you like this table you might like other things I do....
barnaby gunning architects
32 Comments
mbones 4 years ago
Have a great day!
mizzdmartin 6 years ago
the links to the PDFs don't work anymore!!!!
Tomasricardo 8 years ago
What about dooing it with a Router, will one have to wor a lot changing messurements in the joinst?
Kuuran 8 years ago
Nice design. Just got to some thinking and, if using a 24mm board to build two tables, you may get symetrical legs just by changing the way they are curved. The two tables will look slightly different from one another, though.
richardsan 12 years ago
Emiliano Valencia 12 years ago
techfix1 13 years ago
This is one nice looking table and practical!
macrumpton 15 years ago
GeeDeeKay 15 years ago
barnabygunning 15 years ago
trialex 15 years ago
(http://www.design21sdn.com/challenges/15 )
competition. Entries close June 2nd, 2009
russ veinot 15 years ago
static 16 years ago
barnabygunning 16 years ago
gosub 16 years ago
static 16 years ago
teaching with joy 16 years ago
Gonazar 16 years ago
kosmicslop 16 years ago
